zak
A380 Evac Tests With 873pax Planned In Nov
Fri Aug 26, 2005 9:55 pm
according to der spiegel airbus will do the evac tests for 873 people in hamburg after flying msn001 there late october/early november.
link in german:
http://www.spiegel.de/wirtschaft/0,1518,371561,00.html
10=2
OldAeroGuy
RE: A380 Evac Tests With 873pax Planned In Nov
Fri Aug 26, 2005 11:20 pm
Interesting, considering a thread earlier this week from an internal Airbus source said the test would take place early in 2006.
Which is it?
garpd
Fri Aug 26, 2005 11:23 pm
Are they still being allowed to conduct the test in daylight only with slides pre-deployed (there fore biasing the test considerably)?
[Edited 2005-08-26 16:24:07]
arpdesign.wordpress.com
solnabo
Fri Aug 26, 2005 11:24 pm
873 people!!
I would löööve to see that evac. test. Why so many, I wonder??
Mike//SE  Confused
Airbus SAS - Love them both
leelaw
Fri Aug 26, 2005 11:29 pm
Quoting OldAeroGuy (Reply 1):
Which is it?
Interesting, must be Plan B, Revision 1.
Lex Ancilla Justitiae
RedDragon
Fri Aug 26, 2005 11:34 pm
Quoting Solnabo (Reply 3):
873 people!! ...Why so many, I wonder??
So they can certify it at its maximum capacity perhaps?
Quoting GARPD (Reply 2):
Does anyone know if the time taken for the slides to inflate will taken into account in this test? In any event, they have to inflate fully within ten seconds as I recall anyway don't they?
Rich
zak
Sat Aug 27, 2005 1:27 am
873 people!!
I would l���ve to see that evac. test. Why so many, I wonder??
to be more accurate the text says "873 passengers and crew members" hence the 873 represent crew, pax and possible replacement crews. maybe someone with a clue about the pax cabin crew ratio can derive the max pax that they will certify for from that number. 855 pax + 2 flight deck+ 16 cabin crew seems a bit low on the # of cabin crew for me and has no second crew for the flight deck.
hence 873 seems to indicate a very short haul setting or airbus is confident and wants to precertify for the -900!
10=2
Boogyjay
Sat Aug 27, 2005 2:48 am
Quoting Zak (Reply 6):
No it's actually 857 pax.
So what are the remaining 16 people?
- 14 cabin crew + 2 pilots?
- 16 cabin crew only?
I bet it's the later, 2 crews per door = 8 doors, as pilots have theoretically nothing to do with evac, don't they?
RedDragon
Sat Aug 27, 2005 3:03 am
Quoting BoogyJay (Reply 7):
You've still got to evacuate the flight crew safely, so I'd assume that they'd be included in the 90s rule. I believe at least one cabin crew member is needed for each pair of doors (?), but beyond that I can't remember the numbers for the A380.
Rich
