MSYtristar
Air Canada Jazz CRJ705 @ MSY
Sat Aug 27, 2005 7:55 am
The CR7 was in here today, as well as several days last week. Does anyone in the loop know if we should expect to see more CRJ-705 service into MSY to replace the CR2's? Certainly the 705's offer more passenger comfort on the 2.5 hour flight.
AC777LR
RE: Air Canada Jazz CRJ705 @ MSY
Sat Aug 27, 2005 7:56 am
I think it will be used a lot more on that route, it might even go to an EMB 175/190 at times too, from what I have heard at least.
Member since April 2000
MSYtristar
Sat Aug 27, 2005 8:00 am
AC777LR, thanks a lot for the info.
It would be nice to see some more capacity in the market since we were seeing a daily 319 until about a year ago. I'll take a CR7/E70/E95 over a CR2 any day of the week.
AC777LR
Sat Aug 27, 2005 8:11 am
all of Air Canada's new planes will have PTVs in all classes, and leg room around 34" in Coach class. These new CRJs are quite nice from what I have heard, have leather seats as well. I am not sure whats going on with the CRJ100/200 fleet upgrade, I would like to know too?
N1120A
Sat Aug 27, 2005 9:23 am
From what I can tell by looking up fares from YYZ for my girlfriend to come visit me, they are filling that CR2 and getting crazy high fares for it. Their Tango fares are something like 550 CDN each way. She mostly flies out of BUF anyway, but it is interesting to note that AC appears to be getting loads and yields out of the route and would be well suited to use a larger aircraft
MSYtristar
Sat Aug 27, 2005 9:32 am
I remember back in 1998 when the route was started with a daily DC9-30 with much fanfare. It then switched to a 73S operated by Canadian Airlines, then a 73S operated by AC when AC bought out CP, then to a 319 (some days a 320), and now a CRJ ever since the SARS epidemic hit. It is good to see some potential increase in capacity. Clearly some demand is there since they have been serving MSY for seven years.
ERJ170
Sat Aug 27, 2005 9:40 am
how many daily flights are there to MSY? Is it just the 1? Why not just add a frequency instead of upgrade?
When I checked flytecomm earlier (and yes, I know they are not correct all the time), it stated it was a CR9...
Aiming High and going far..
N1120A
Sat Aug 27, 2005 9:52 am
Quoting ERJ170 (Reply 6):
Because they don't want to fly 2 flights a day with horrible CASM numbers instead of 1 flight that can actually make them a fair bit of money
That would be nice to see.
ERJ170
Sat Aug 27, 2005 9:59 am
Quoting N1120A (Reply 7):
So flying a 319/320 (former aircraft on the route) would create a horrible CASM instead of 2 CRJ?
Likewise, flying 2 CRJ would create that much more problems than flying the 90+ seat CR9?
MSYtristar
Sat Aug 27, 2005 10:02 am
The CRJ-705 is the same as a CR9 as far as dimensions go. I don't think AC technically operates CR9 aircraft.
CRJ-705 holds F10Y65 I think.
N1120A
Sat Aug 27, 2005 10:03 am
Quoting ERJ170 (Reply 8):
No, flying an A319 or A320 on the route would have a very positive effect on CASM
VonRichtofen
Sat Aug 27, 2005 10:59 am
Quoting MSYtristar (Reply 9):
Correct on both points  Smile
Kris
acjazzame
Sat Aug 27, 2005 2:28 pm
The PTV are not scheduled to be installed until late next year.
ACJAZZAME
acjazzame
Sat Aug 27, 2005 2:31 pm
( MSYTristar)
I don't know about that, have you ever been on one? Just don't sit in business class or at the back of the airplane unless you have ear plugs!
ACJAZZAME
N1120A
Sat Aug 27, 2005 3:04 pm
Quoting ACJAZZAME (Reply 13):
Why would the front be so loud?
acjazzame
Sat Aug 27, 2005 3:27 pm
[quote=N1120A,reply=14]Why would the front be so loud?[/quote
I wish I could explain it but honestly I can't give you a real answer, the only way is to try it out for yourself. You would think with the engines being that far back that it would be quiet. I think IMO that there seems to be a lack of insulation (not enough) to block all that wind noise the long fuse seems to pick up. Believe it or not, a DHC-Q400 is a lot quieter!!
ACJAZZAME
MSYtristar
Sat Aug 27, 2005 9:58 pm
Well i've been on a couple of Horizon CRJ-700's and I thought they were far superior to the Comair/Skywest CRJ-200's that i've been on. I''m only basing my opinion on that. The only nice CR2 i've been on was flown by JI. And even so, looking down out those tiny windows is annoying to say the least.
acjazzame
Sat Aug 27, 2005 11:08 pm
You are right about the CRJ-700/900 being far superior to the CRJ 200 and those little windows on the 200 make me want to puke everything I look out of them. The 700 might be a little different than the 700 in terms of noise considering that it is shorter, but I was a bit shocked about the 705 (900). It is comfortable inside but that noise is annoying.
My  twocents
ACJAZZAME
cgojz
Sat Aug 27, 2005 11:34 pm
Quoting MSYtristar (Thread starter):
The upgauges have been to cover for unservicable CRJ200's
Flight Plans all indicate CR9
Quoting ACJAZZAME (Reply 12):
Since when?
I've sat in row 1, and row 28. In cruise, in row 1 you can easily hear conversations in the first couple rows of Y - and in row 28, it gets very loud during the start, but after that IMO it isn't any noisier than any other new generation rear engined aircraft.
