Pe@rson
O&D From ATL To AL, MS And LA
Tue Aug 30, 2005 2:27 am
How does DL and AirTran perform - in terms of O&D customers - on routes from ATL to places in AL, MS and LA? Also, what about O&D on routes within GA and to NW FL, e.g. Ft Walton Beach, Penescola, etc.? Cheers.
[Edited 2005-08-29 19:39:01]
[Edited 2005-08-29 19:39:37]
BHMNONREV
RE: O&D From ATL To AL, MS And LA
Tue Aug 30, 2005 3:15 am
I can only speak for DL on the ATL-BHM route, but as would be expected O&D is nearly non-existent due to the close proximity of the two cities, which can be reached in approximately two hours by auto. And with advance purchase fares approaching $200.00 r/t, fighting the airport hassle is just not really an option.
Delta's market share in BHM has steadily declined over the past several years, with WN #1 in passenger boardings, AFAIK. BHM used to see a steady diet of 757's from ATL-BHM every day, but now these are down to a mix of MD-88's and 737-200's. Quite a reduction in available seats...
Pe@rson
Tue Aug 30, 2005 3:18 am
Quoting BHMNONREV (Reply 1):
I expected that. Is it the same case for, say, MGM?
ejmmsu
Tue Aug 30, 2005 3:24 am
I'm sure there is a lot of O&D on the ATL-MSY route.
"If the facts do not conform to the theory, they will have to be disposed of"
BHMNONREV
Tue Aug 30, 2005 3:29 am
Quoting Pe@rson (Reply 2):
I would imagine so, ATL-MGM is only slightly farther than ATL-BHM, and it is served via interstate (I-85). I figure the same would hold true for ATL-HSV as well. ATL-MOB may see some more significant O&D numbers though..
FlyPNS1
Tue Aug 30, 2005 3:38 am
For Pensacola (PNS), the O+D to ATL is relatively low as well. It's about 110-140 (each way) daily depending on the season. However, DL and Airtran offer somewhere between 1300-1600 seats (each way) daily depending on the season. So, O+D traffic makes up only about 10% of the passengers.
The O+D has grown a bit with the arrival of Airtran in 2001. Before Airtran, the O+D was less than 50 passengers.
BNAflyer78
Tue Aug 30, 2005 3:56 am
Quoting BHMNONREV (Reply 4):
ATL-HSV is not an easy drive. There is no interstate, so you either have to drive I-65 to BHM and across I-20, or take US 72 to CHA and down I-75.
Long live the Widget!
BHMNONREV
Tue Aug 30, 2005 4:19 am
Quoting BNAflyer78 (Reply 6):
It's not really too bad. Most folks I know take 431 to Anniston then I-20 to ATL. Takes about three hours.
Point is, with DL being the only carrier on the route they tend to grab you by the 'nads and squeeze real hard to get those O&D dollars. That alone pretty much prices them out of the market..
717-200
Tue Aug 30, 2005 4:24 am
Does AirTran still rely on the subsidies from the Beau Rivage on its
ATL-GPT, TPA-GPT, and FLL-GPT routes?
72S 733 734 735 73G 738 742 752 763 E190 M82 M83
