UA744Flagship
IAD Fuel Supply Shortage & Carrier Effects
Sat Sep 03, 2005 12:16 am
I've heard that since IAD gets its fuel from the Gulf, that there is a possible Jet A shortage going on there.
Anyone know or hear of any unusual flight cancellations, possibly due to this fuel shortage? Is Independence Air operating normally?
no wire hangers!
FutureFO
RE: IAD Fuel Supply Shortage & Carrier Effects
Sat Sep 03, 2005 12:23 am
Usually what happens is they will tanker fuel in from other areas and just keep them on the planes they came in on. But that could possibly mean weight restrictions to keep the fuel, causing more of a loss in actual revenue.
Sean from MCO and MKE
I Don't know where I am anymore
captover
Sat Sep 03, 2005 4:54 am
Independence has said that IAD has about 9 days worth of Jet A. They will be doing reverse tankering, which means they will be refueling at cities that have fuel available instead of always refueling at IAD. I don't know if any other Independence cities are having a potential fuel shortage.
HT
Sat Sep 03, 2005 5:55 am
Quoting UA744Flagship (Thread starter):
"From the Gulf" ? AFAIK Jet A comes from a refinery. If Katrina has a massive effect on Jet A-production, IAD will not be the only airport to suffer from.
IN addition to what Captover indicated, AFAIK every airport is legally required to hold stock of fuel for so-and-so many days of operations ...
BTW: Which way is IAD supplied with Jet A ?
Speaking for two airports I´m familiar:
FRA gets one part of its fuel via pipelines directly from refineries downstream the river (IIRC more than 1 pipeline; at least one of them is or was a military pipeline). In addition to this, the operator of FRA has its own quay on the river Rhine (or is it on the river Main ?) to offload tank-ships. IIRC railcars are used only should ice block shipments on the rivers and the stocks decrease.
HAJ gets its supplies by road tanker, but a pipeline (~ 20 km) from a nearby quay on a canal should be under construction now (saving a lot of trucks per day).
-HT
UALPHLCS
Sun Sep 04, 2005 12:48 pm
Quoting HT (Reply 3):
I don't know for sure but with all the refining capacity around Baltimore Harbor which is a very industrial harbor IAD would probably get its Jet A from Baltimore or other Chesapeake ports. Gulf capacity I understand is piped to ATL.
A little less Hooah, and a little more Dooah.
Cubsrule
Mon Sep 05, 2005 6:36 am
Quoting Captover (Reply 2):
CLT and ATL do, and I would imagine that GSO, GSP, and RDU might also have problems.
goodmanr
Mon Sep 05, 2005 7:21 am
Quoting UALPHLCS (Reply 4):
I don't think this is correct. I think IAD isn't supplied anywhere close to locally but I'm not 100% sure.
USAirways - Chairmans Gold
JeffB
Mon Sep 05, 2005 8:40 am
From the Washington Post:
"The Metropolitan Washington Airports Authority denied a trade report yesterday that said Dulles International Airport was one of 10 that could face jet fuel shortages. Dulles and National are supplied by the Colonial and Plantation pipelines, and they have a two-week supply of fuel on hand, the authority said."
http://www.washingtonpost.com/wp-dyn...le/2005/08/31/AR2005083102652.html
Basically, IAD/DCA use two pipelines that get their Jet A from Gulf Refineries. Which is probably a hell of alot cheaper than having it trucked in!
Also, AFAIK, there are no refineries in Baltimore. I know of the fuel depots down in Curtis Bay and there are chemical plants over near Sparrows point/key bridge... but I didn't think any were Petrol refineries. If there are, where are they?
.jeff
ERJ170
Mon Sep 05, 2005 11:03 am
Quoting Cubsrule (Reply 5):
Actually, I think that RDU is doing well as far as jet fuel goes. The pipeline (1 of 2) that supplies RDU has been re-establish. It also serves ATL & CLT, so I believe they are out of the water, also.
Aiming High and going far..
flybyguy
Mon Sep 05, 2005 11:32 am
I guess having to reverse tankering during the fuel shortage at IAD for Independence Air will become a logistics nightmare in assigning new flights... especially if several flights end up short on fuel, but there are a lot of relatively long flights sheduled at that particular time.
"Are you a pretender... or a thoroughbred?!" - Professor Matt Miller
lightsaber
Crew
Mon Sep 05, 2005 12:32 pm
Its not just IAD, its all of the airporst fed by the Colonial and Plantation pipelines, see below:
Quoting JeffB (Reply 7):
Ugh, the Colonial and Plantation pipelines were the ones down. If they have two weeks supply on hand, they'll be ok. Here is a release saying by the weekend the larger Colonial pipeline will be back at 86% capacity:
http://today.reuters.com/investing/f...RGY-COLONIAL-PIPELINE-UPDATE-3.XML
I would *love* to know what the tankering is costing the airlines.
Remember, the gulf refineries did a little more "specialization" in Jet fuel than is normal. I'm guessing due to the presence of the two finished product pipelines giving them a ready market in the southeast and eastern seaboard.
Lightsaber
Go3Team
Mon Sep 05, 2005 12:53 pm
In today's local paper (RIC), they had a write up on how we get our fuel. It indicated that a batch of fuel, transported by Plantation Pipeline, takes about 20 days from the time it leaves Baton Rouge, LA to get to Dulles. The Plantation pipeline has tank facilities near GSO, CLT, ATL, and places closer to Baton Rouge.
For the Colonial Pipeline, they indicate travel time from Houston to New York, is 18.5 days. They have more tank facilities than Plantation, so I assume they have more storage capacity. Here is a link to the story, but it does not have the graphic I am looking at to recite what they said:
http://www.timesdispatch.com/servlet...icle&c=MGArticle&cid=1031784858769
Its possible that IAD can tap from these tank farms if necessary. The article also states, that it is possible for the pipeline to reverse flow, but that it is not set up for it.
Here in Richmond, all fuel is brought in by truck. Since this is a shit town for air travel, they only receive a few loads a day.
Yay Pudding!
