daron4000
AA MD80's To East Coast
Mon Sep 05, 2005 8:45 am
I was wondering why so many ORD-East Coast flights, basically all of them, are operated on MD80's when United fills those same routes, often at similar times, with larger aircraft like A320's (I know pretty similar) and much bigger 757's. Couldn't some markets like ORD-LGA warrent bigger service.
AA 777
RE: AA MD80's To East Coast
Mon Sep 05, 2005 8:54 am
The only real domestic plane that AA has at ORD is the S80 (ok, there are a few 757's here and there). AA got rid of the 737 at ORD and moved them to MIA and taking the S80's out of MIA and moved them to ORD. This saves AA a ton of money for many reasons - parts, crew bases etc. While some routes could use a 757 for a few flights, AA has opted to go for frequency, with LGA-ORD being a good example - 18x a day.
AA 777
CRJ-700 FO
commavia
Mon Sep 05, 2005 9:52 am
Quoting Daron4000 (Thread starter):
Because UA is bigger at ORD, and because AA has -- very smartly -- recognized that it is not worth it to fly many aircraft types, at ORD or across its entire network, just so they can highly customize their capacity per departure. Instead, AA no longer flys 737s at ORD or F100s at all, both of which used to fly extensively to the east from ORD, and as such are now saving millions each year on spare parts, equipment, staffing, maintenance, training, etc. AA is profitable, UA is not.
UA may fly bigger planes on ORD-LGA than AA, but AA easily beats its ORD rival in the market, with eighteen flights per day against less at UA. AA has more flights and more seats than UA.
apodino
Mon Sep 05, 2005 10:31 am
Quoting Commavia (Reply 2):
Not true, United has sixteen flights per day between ORD and LGA. most of them are on 737's, but there are a couple on the 320 and even a 757 thrown in for good measure. Capacity on the route is probably similar between the carriers.
commavia
Mon Sep 05, 2005 10:53 am
Quoting Apodino (Reply 3):
Nope.
AA flies 19 daily MD80s, for a total 2,584 daily seats.
UA flies 3 daily A319s, 3 daily A320s, 4 daily 757s, 4 daily 737-300s and 2 daily 735-500s, for a total of 2,190 daily seats.
All AA flights seat 136 passengers, while UA’s average is 136.9. AA has 18% more capacity than UA on this route. I’d say that’s a big difference.
Venezuela747
Mon Sep 05, 2005 12:07 pm
Daron,
Have you seen DFW Terminal C it is packed with MD80s......MD80 is probably the only Domestic aircraft....they use the other when loads are high are necessary other wise MD80 it is
ROLL TIDE!!!
dfwagt
Mon Sep 05, 2005 2:42 pm
And who likes to fly on MD-80s?
Longhornmaniac
Mon Sep 05, 2005 3:24 pm
Quoting Dfwagt (Reply 6):
MD-80s are really good airplanes. I would much prefer a 757 on my short hop from AUS-DFW, but thats just because I like the size and the roar of the 75' engines. MD-80s are really dependable workhorses, and actually very comfortable inside, really quiet.
Quoting Venezuela747 (Reply 5):
There are several other kinds of planes that make regular appearences at terminal C. The 738 and 757 to be more specific.
Cameron
jetBlue
Mon Sep 05, 2005 3:25 pm
I do if I'm sitting forward of the wing. Haven't been on one in a while and am in denial.  wave
jetBlue
We know for you it's not just a seat on a flight to a place. It's a seat on a flight to your life.
kappel
Tue Sep 06, 2005 1:50 am
Quoting JetBlue (Reply 8):
How are the interiors? I recently was on IB's MD 88's (EC-FOF and EC-FPJ) and especially the interior of FOF looked terrible! It's obvious that IB is planning to replace these planes. My seat cushion was completely flat and I could take it off the seat. But I did like the plane. I was seated ahead of the wing, and it is really quiet up there. I was actually surprised how quiet.
L1011,733,734,73G,738,743,744,752,763,772,77W,DC855,DC863,DC930,DC950,MD11,MD88,306,319,320,321,343,346,ARJ85,CR7,E195
StarCruiser
Tue Sep 06, 2005 2:02 am
I do. It's quiet, a bit roomier with 2 X 3 rather than 3 X 3 and it's a great plane which has worked for AA for a long time.
ckfred
Tue Sep 06, 2005 3:17 am
AA used to use a variety of aircraft on many routes. In the early 90s, ORD-DFW had 727-100, 727-200, MD-80, 757, 767-200, and DC-10.
Since then, AA has gone with the model of having 1 basic aircraft type and a route, and to fly more frequently. When AA flew 6 different types on ORD-DFW, it had 10 to 12 roundtrips daily. Now, it flies 19 roundtrips, and had 23 roundtrips before September 11th.
ORD-LGA has been pretty much MD-80s since the mid-90s, although it used to have one or two 757s scedule during morning and evening rush.
ORD-LGA used to have a more aircraft types, including DC-10s and 767s, but the widebodies were phased out as AA increased service between New York and DFW.
saxman66
Tue Sep 06, 2005 5:10 am
Those MD-80's are truly the workhorse of the airline. AA plans to keep them for a very long time, (because they can't really replace them right now). Many pilots I talked to really like the MD-80 as there are many good lines to bid from, and it really is capable of alot. Fuel efficiency wise, its not up to todays standards, but AA is determined to make it as efficient as possible. For example, one little brass washer then went somewhere use to cost them $25 each. Now AA has learned to make many of their own material and they can make those same washers for under $5 each. Thats just one way they are trying to make the MD80's extremely efficient.
I just get tired of the MD-80 becuase they are hard to avoid whenever you fly AA.
Ride Amtrak!
qqflyboy
Tue Sep 06, 2005 7:06 am
Quoting Kappel (Reply 9):
Actaully, they are very decent. AA installed new interiors on all of it's MD-80s starting in 1999. The TWA MD-80s were finally standardized to AA's interior, although the coach seats may vary on some TWA birds... not all TWA birds have adjustable headrests in coach. All AA MD-80s now feature expanded bins on the three seat side and power ports.
Here's some pix of AA's MD-80 cabin:
(The first photo was taken prior to extensions being added to the overhead bins.)
Photo © AirNikon
Photo © Matt Lave
The views expressed are mine alone and do not necessarily reflect my employer’s views.
MarshalN
Tue Sep 06, 2005 7:15 am
But it does get noisy if you're sitting in the back though... and sometimes they have that occasional annoying high pitched noise that I notice that won't go away.
lastordu
Tue Sep 06, 2005 7:20 am
Quoting Saxman66 (Reply 12):
That is because they have 346 of them and that is as of 06/06/05
LAStoRDU
"Remember, Remember the 5th of November" from V for Vendetta
