ssides
PAP Not Safe?
Wed Sep 07, 2005 4:29 am
I saw signs at DFW and MIA this weekend that said the FAA has determined that PAP does not employ sufficient security procedures.
If that is the case, is AA still allowed to fly MIA-PAP? I'm surprised that (1) AA would fly the route if the airport was deemed unsafe, and that (2) the FAA would allow flights originating at PAP to land in the US.
Does anyone have info on this?
"Lose" is not spelled with two o's!!!!
commavia
RE: PAP Not Safe?
Wed Sep 07, 2005 4:49 am
Quoting Ssides (Thread starter):
Yes, although AA does not RON any aircraft at PAP overnight. It has three morning originators -- one each from FLL, JFK and MIA that all get to PAP in the late morning or afternoon, sit on the ground there for just long enough to unload and reload passengers and cargo, and refuel, and then its out again, and then a second MIA flight that comes in and leaves in the late afternoon.
AA turns those planes fast so they aren't sitting long on the ground in PAP -- they turn the JFK A300 in 70 minutes, and the two MIA A300 flights in 73 minutes.
AA flies to FLL-PAP, JFK-PAP and MIA-PAP for one reason: the money.
Because of the intense security situation, the level of air capacity into and out of Haiti is extremely low. Thus, the few airlines that do fly there derive huge yields from very high fares to and from PAP. Let's put it this way -- not too many Haitians in PAP are logging on to Orbitz.com to get a $199 RT fare.
ssides
RE: PAP Not Safe?
Wed Sep 07, 2005 6:00 am
I knew AA's PAP flights were very profitable, but I'm still a bit surprised that the FAA would allow flights to the US from there. I guess since AA is a US carrier, they have good access to all the flight manifests, and AA is probably doing a decent job of controlling who gets on the plane at PAP.
Do any other US carriers serve PAP?
BigGSFO
RE: PAP Not Safe?
Wed Sep 07, 2005 6:10 am
In addition, I do not think AA's flight crews overnight or even leave the airport in PAP.
MAH4546
RE: PAP Not Safe?
Wed Sep 07, 2005 6:21 am
Quoting Commavia (Reply 1):
This is the slow season, though. November through August, AA operates three daily MIA-PAP, and during the summer they add a fourth daily. American Airlines is the single largest airline into and out of Haiti. The other major airlines serving Port Au Prince are Air Canada (Montreal), Air France (Miami and Pointe A Pitre), and Copa (Panama City via Kingston).
a.
Francoflier
RE: PAP Not Safe?
Wed Sep 07, 2005 6:44 am
As said above, no matter how unsafe it is, the money is the leading horse.
They charge astronomical sums for a 1h30 mins flight with crappy service, and they don't care since nobody else flies the route.
They have been giving that disclaimer for a while now, probably because the FAA requires them to, and to avoid annoying legal involvements.
When departing Haiti, you go through the airports' security checkpoints first. There are two of them, one before entering the check-in terminal and one after you check immigration. For an AA flight you go through one additionnal checkpoint (a little more thourough) and then you are led into AA's (and AC's) waiting room.
It's daunting...
AA has never had any problems in terms of operating safety in PAP, they have always flown there even when there were civil disturbances early last year, and up to the very last minute (we realized they knew better than anyone what was going on...).
There is an area of the town that's right on the 2 miles final to runway 10 and which is in the hands of the rebels. Even the UN don't go there (then again, they ain't doing much of anything here...). Some aircrafts have been shot at on final already, even an AA A300 once, but apparently it didn't really affect their operation here.
ssides
RE: PAP Not Safe?
Wed Sep 07, 2005 7:14 am
Quoting Francoflier (Reply 5):
I know the flight is very profitable, but I just checked MIA-PAP in November and got $269 round-trip (before taxes). Hardly seems unreasonable.
On a related note, who pays these astronomical fares? I know Haiti is a very, very poor country, and while there's business there, it surprises me that there's that much demand.
MAH4546
RE: PAP Not Safe?
Wed Sep 07, 2005 7:27 am
Air France flies MIA-PAP. Better service too, they actually offer hot meals on the flight.
Quoting Ssides (Reply 6):
The average fare on the route is closer to $450. That is on the low side. Also a lot of last minute traffic.
If you can want/need to travel to Haiti, chances are you can afford the fares. Also, Fort Lauderdale has a very wealthy Haitian ex-pat community that travels back frequently (FLL-PAP is AA's best performing single Haiti flight).
a.
2travel2know
RE: PAP Not Safe?
Wed Sep 07, 2005 8:17 am
CM is one of the few airlines which fly to PAP but it has seldom happened that the PAP flights have been cancelled due to the situation in Haïti.
The PAP / KIN route may be CM most profitable one; maybe because CM still only flies there twice per week and maybe because it seems that one's the only flight from Latinamerica (don't want to discuss if PTP/FDM is Latinamerica too) to PAP and KIN. Those PTY - PAP / KIN flights would be ideal with B737 Combi.. the amount of cargo the passengers take with them is amazing.
Having said this, I must add that the notorious CM PAP / KIN flights are the most neglected and forgotten when it comes to passenger attention.
It's said that the flight attendants will try to avoid working that specific flight.
And there's even more, often prestigious CM has cancelled (cancelled, not changed the flight times) the PAP / KIN flights and told passengers to wait a couple of days until the next CM available flight!
A decent responsible airline doesn't behave like that.
If CM is such a good airline, They should be good on ALL their routes.
I don't work for COPA Airlines!
luisca
RE: PAP Not Safe?
Wed Sep 07, 2005 8:40 am
The flights are a money making machine becouse of the cargo that they carry, the A300 has a very good cargo capacity and these people carry huge amounts of cargo, and they dont mind paying 100 or 200 for overweight.
Same thing with CM in pty.
About how CM treats its PAP/KIN flights, don't you think their is a reason why crews hate that flight, the behavior of some of the passengers is unbelievable, while in the chekin counter in panama, I saw these people arrive to the counter for the PAP flight and they were carriying 14 bags, paid 300 dollars for overwieght, no problem. They then went into the bathroom of the airport and changed, etc, and were carriying food, and the smell was just awfull, no wonder crews hate this flight.
If it ain't Boeing (or Embraer ;-)) I ain't Going!
2travel2know
RE: PAP Not Safe?
Wed Sep 07, 2005 9:52 am
Quoting Luisca (Reply 9):
Those PAP and KIN bound passengers don't behave the same way when flying out of MIA or JFK?
MAH4546
RE: PAP Not Safe?
Wed Sep 07, 2005 10:20 am
Quoting 2travel2know (Reply 10):
Nobody said or implied otherwise.
a.
2travel2know
RE: PAP Not Safe?
Wed Sep 07, 2005 11:22 pm
Let's concentrate to the subject of this topic.
A lot could be said of the peculiarities of the flights to PAP, but that's for another topic.
I believe PAP airport still is a safe airport, If AA does fly there, it must; a US airline won't venture in an unsafe airport with commercial flights if it was unsafe.
Maybe DL (from JFK or ATL - this one if they get good connecting traffic) or CO (from EWR) should study flying to PAP.
PRAirbus
RE: PAP Not Safe?
Thu Sep 08, 2005 12:07 am
AA has its own security personnel in PAP therefore it has another layer of protection besides what PAP Airport authorities provide. There are also many things going on "backstage" not visible to the customer(s) that ensure safety. The same happens in other airports and other carriers operate to places clasified "unsafe" by the FAA.
mirrodie
RE: PAP Not Safe?
Thu Sep 08, 2005 12:39 am
That service warning regarding PAP has been at FAA security checkpoints since AT LEAST June 2001.
I remember it well simply because that was the summer I noticed the sign whilst traveling to Sydney AND, well, some of my family are living in Haiti still(so I take notice of things pertaining to Haiti).
It is a MONEY route, no doubt. The planes are usually full and especially full of cargo.
As I have an aunt working at AA, even she has had a very difficult time trying to fly standby to visit her mom(my grandmother) so she'd buy the ticket instead.
Haiti's violence seems to wax and wane. We just flew my paralyzed-on-one-side grandmother out of PAP a month ago when we heard the political situ was crazy. It was an overnight decision to move her to NY. She came on AA and again spoke of the usual packed route.
Also, our neighbor across the street is Haitian. She is one of the FA's for AA that work that routeJFK-MIA. Man, when she comes over, you have to hear the stories about those flights! Truly sad, though sometimes funny.
Also, as an aside, dont they also list an airport in Kuala Lumpur too?
Forum moderator 2001-2010; He's a pedantic, pontificating, pretentious bastard, a belligerent old fart, a worthless st
