HPRamper
Help Me Identify This Aircraft At PDX
Fri Sep 09, 2005 2:22 am
For over a month now I've noticed a 737 (either -100 or -200, I can't tell from the road) parked in back of the Flightcraft business aviation area at PDX and not far from United Cargo. I have no idea if it leaves the airport on a regular basis since I'm only there in the morning, but it is there almost every morning very predictably. It is all white with a dark blue tail and no other markings, no company logo or name, I believe the tail number is N746AP. Unmarked planes at PDX come by occasionally but I figured a 737 is a little big for a GA or business traveler, unless you're Paul Allen in your 767. Anyone know anything about it?
Also, how do you track down this sort of information? All I know about it Flytecomm but it isn't very detailed, often sketchy on information and only lists regularly scheduled commercial flights...for the most part.
Thx
Bluewave 707
RE: Help Me Identify This Aircraft At PDX
Fri Sep 09, 2005 2:38 am
N746AP is a 737-281 (c/n 21770), that may have been from WestJet. Others with the reg N74_AP have been either leased or sold to airlines in Indonesia and other in the market for 2nd-hand jets. 746 may be awaiting its next assignment.
"The best use of your life will be to so live your life, that the use of your life will outlive your life" -- D Severn
rampkontroler
Fri Sep 09, 2005 2:42 am
Well, a Google search for a registration number is one way...the registration you provided came up with this from the FAA database:
FAA Registry
N-Number Inquiry Results
N746AP is Assigned
Assigned/Registered Aircraft
Aircraft Description
Serial Number 21770 Type Registration Corporation
Manufacturer Name BOEING Certificate Issue Date 09/02/2005
Model 737-281 Status Valid
Type Aircraft Fixed Wing Multi-Engine Type Engine Turbo-Jet
Pending Number Change None Dealer No
Date Change Authorized None Mode S Code 52404342
MFR Year None Fractional Owner NO
Registered Owner
Name WELLS FARGO BANK NORTHWEST NA TRUSTEE
Street 299 S MAIN ST 12TH FL
MAC U1228-120
City SALT LAKE CITY State UTAH Zip Code 84111
County SALT LAKE
Country UNITED STATES
So, this at least confirms that your registration number does indeed match that of a 737. Then I took the aircraft type and serial number and entered it into another Google search to come up with this:
Photo © Marlo Plate - Iberian Spotters
And from this, you can go just about anywhere!
There's all sorts of databases to work with, but mostly I use Google, because it will connect to a lot of the major databases.
N774UA
Fri Sep 09, 2005 2:44 am
Hello,
the plane is former C-FAWJ from Westjet. There was a topic about it (I think) a while ago. If memory serves me well it is bound for a new eastcoast based carrier.
When searching American regs, this can be a useful link. In the case of this plane it stops at the leasing company; Wells Fargo.
http://162.58.35.241/acdatabase/NNum_inquiry.asp
regards
N774UA
...follow his instructions, switch off at the stand.
N774UA
Fri Sep 09, 2005 2:46 am
Ok,
I was't typing fast enough. Big grin Big grin
N774UA
HPRamper
Fri Sep 09, 2005 7:52 am
Great, thanks! Now I can sleep at night..er, day.
