baw716
United: The Vision And The Plan Pt III
Fri Sep 09, 2005 10:03 am
The first two times I tried to do this, our friendly moderators pulled both threads. I guess they did not like what I was doing or I wasn't following the rules. One or the other.
In any case, I think I have made a work around so that you do not need to register in order to access the plan. So here is the information.
The web location is still the same: http://groups.msn.com/UnitedTheVision
Once you are there, you must log in as a member. You can only log in once at a time, so there may be some issues with multiple log ons. The problem is that I haven't been able to find anyone yet to host this on their site. I still am working on it, but I did promise by Friday, so I am trying to meet the promise I made.
Log In: united-vision@hotmail.com. Password: dream2005
That should put you into the group as a member. You can then access the files from there. Note: You will not be able to change the files, you can only read them.
If you have an existing hotmail account, you may sign in as yourself and get access immediately. This will add you to the list of members to the site.
To delete yourself as a member, simply to to the member section and just delete yourself from the group. Your information is not kept in the file, only your e-mail address and if you wish to make an alias for yourself that hides your actual e-mail, you can do that as well. The idea is not to collect your e-mails, it is to get this information out to you.
As soon as I have someone to host the files, I will let you all know. Hopefully, our friendly moderators will not yank this notice again on the premise that I am soliciting your e-mail address. By my adding the one above, you are free to use that to access the site even if you have your own hotmail account. It just might take a while if there are a lot of you trying to access it at once.
Good luck and happy reading!
baw716
David L. Lamb, fmr Area Mgr Alitalia SFO 1998-2002, fmr Regional Analyst SFO-UAL 1992-1998
srbmod
RE: United: The Vision And The Plan Pt III
Fri Sep 09, 2005 10:05 am
Quoting Baw716 (Thread starter):
A word of warning. You may be flirting with a ban for posting this a third time after it was deleted twice.
baw716
Fri Sep 09, 2005 3:25 pm
I think I am ok this time. I think the problem was the registration issue. Now that I have taken that away, I believe the moderators should have no problem with you having access without having to give away your information.
I also just discovered the second one was not deleted. It is back in the forum.
Looks like the moderators reread the intent of the thread.
Thanks for the heads up though. I do want to play by the rules.
baw716
alphascan
Fri Sep 09, 2005 11:11 pm
Don't have time to read your plan right away.
Just one question, did you include selling excess gates....as in DEN?
"To he who only has a hammer in his toolbelt, every problem looks like a nail."
