YULWinterSkies
Boeing Versions And Engine Manufacturers
Sat Sep 17, 2005 2:31 am
Hi,
I'm wondering if there's an easy way, when you see a Boeing aircraft type, let's say 747-430, that stands for the 747-400s of LH, to know with which engine it is equipped. If you see an Airbus 340-541, that immediately tells, thanks to the 4 in 541 that it has RR engines. Anything like that at Boeing?
Thx
(for those who may wonder, Airbus uses 0 for GE, 1 for CFM56, 2 for PW, 3 for IAE, 4 for RR, and soon 6 for Engine Alliance)
When I doubt... go running!
DfwRevolution
RE: Boeing Versions And Engine Manufacturers
Sat Sep 17, 2005 2:40 am
No... Boeing uses "customer codes" instead of power plant configurations like Airbus does.
A Boeing 777-222/ER is a 772ER sold to UA
USAF336TFS
Sat Sep 17, 2005 2:42 am
I believe that the model number on Boeing aircraft, tell you the Customer, i.e .the example you used was a 747-400, and Boeing Customer number "30" - Lufthansa.
That's a great question though... I'm wondering how you would find out the engine manufacturer?
336th Tactical Fighter Squadron, 4th Fighter Wing, Seymour Johnson AFB
sammyk
Sat Sep 17, 2005 2:50 am
Quoting DfwRevolution (Reply 1):
While your example is correct it is not always sold to the airline that corresponds with the code. The aircraft is built for a certain airline but may never serve that airline yet it will carry that code for life.
airxliban
Sat Sep 17, 2005 2:51 am
You'd go to www.jetphotos.net and look in the jetliner database  Wink
Or just look up a picture of the plane in question and figure it out from there.
