797
Painting A Frontier Jet...
Sun Sep 18, 2005 2:33 pm
Hello guys,
Well, today I bought Airliners magazine, and one of their articles is about Frontier. I've seen those tail pictures several times, and I think they look gorgeous, but I asked myself how do they paint them and how much would it cost them...
I bought a magazine a while ago talking about painting a jetliner, and many factors apply here. In Frontier's case, it's pretty simple (all white paint) until you get to the tail. For what I've seen, they use spray painting to paint the fuselage, but when they get to the highly-detailed tail, how do they do?. Is it a huge sticker or they get painters to do that?
Photo © Michael Carter
Photo © Jan Kertzscher
This doesn't only apply in Frontier's jets, but also many airlines that use promotions showing pictures on their fuselages.
Photo © Bob Durey - Aviation Photography of Miami
Well, thanks guys!
Greetz!
Enrique.
FlagshipAZ
RE: Painting A Frontier Jet...
Sun Sep 18, 2005 3:05 pm
On F9's tails, they use decals. The rest of the aircraft is painted. I know, because I was trained to de-iced Frontier's 737s at LAX, in case it ever snowed there. All the manuals refered to the animals on the tails as decals, or huge sectional stickers if you wish. I was trained not to aim the de-icing nozzle directly at the seams on the decal. In the year I was with F9 at LAX, it did not snow once. Lucky me. Regards.
"Beer is living proof that God loves us and wants us to be happy." --Ben Franklin
797
Sun Sep 18, 2005 3:18 pm
Quoting FlagshipAZ (Reply 1):
Geez! Imagine those printers! haha.
Well, but this means that it would be more expensive than using common paint, right?
AR1300
Sun Sep 18, 2005 3:23 pm
no.Stickers are very cheap.They are used to promote things.They are cheap, reliable and replaceable.
Mike
[Edited 2005-09-18 08:24:17]
You are now free to move about the cabin
GARUDAROD
Mon Sep 19, 2005 3:50 am
FlagshipAZ,
I think you can safely say it hasnt snowed at LAX for at least the last
50years or so if not longer.
Cargo doesn't whine, moan, or complain
GentFromAlaska
Mon Sep 19, 2005 12:03 pm
Here' a blurb from the F9 website about the decals
"How are the wildlife decals on your tails applied?
Images are printed on adhesive-backed vinyl that is similar to contact paper. The image is tiled in 18 to 20 34-inch-by-96-inch panels with 2 inches of overlap. They are applied starting at the rear base of the tail, moving toward the leading edge of the tail. After all the tiles have been applied, the tail is covered with two coats of clear coat to seal the image and prevent corrosion. Any panel that gets damaged may be replaced individually. The panels are printed in Denver and applied in Hamburg, Germany.
Man can be taken from Alaska. Alaska can never be taken from the man.
SkyexRamper
Mon Sep 19, 2005 12:41 pm
Actually the stickers hold up well and are fairly cheap for end result, a photo on the tail. Plus these stickers last 5 years.
Good Luck to all Skyway Pilots! It's been great working with you!
Jetmek319
Mon Sep 19, 2005 12:51 pm
Mostly correct... The decals are lasting 3-4 years with some maintenance. And they're not exactly cheap. They run upwards of $15-20,000 for the set. The edge sealing is done to prevent peeling and wind erosion. Because the tails are completely composite material, we don't have too many problems with corrosion.
Never, ever moon a werewolf !!
BandA
Mon Sep 19, 2005 12:55 pm
it looks like they use the same stuff used on wrapping vehicles with advertisments, like vinyl.
We recently had a whole Ford Navigator wrapped for under $3000 full (4color) and the vinyl is probably not as good as the stuff they use on aircraft.
The way we did it we sent Photoshop/Illustrator art in CMYK format to the printers who print this stuff using wide-format printers on vinyl. The Vinyl then comes either pre-cut to meet vehicle dimensions or uncut for installer to cut later. Then is applied using adhesives and lasts decent amount of time.
[Edited 2005-09-19 05:56:46]
[Edited 2005-09-19 05:59:02]
"They [Terrorists] never stop thinking about new ways to harm our country and our people, and neither do we." - GWB
Jetmek319
Mon Sep 19, 2005 1:08 pm
Exactly how it is done. We tried a polyester film that didn't work so well (the parrot), so we went back to the vinyl material.
AsstChiefMark
Mon Sep 19, 2005 1:22 pm
In the emergency and commerical vehicle business, vinyl and Scotchlite can be much less expensive than paint.
Red tail...Red tail...Red tail...Red tail...Red tail...Red tail...Red tail...Red tail...Damned MSP...Red tail...Red tail
flyabunch
Mon Sep 19, 2005 2:19 pm
The process is done using digital printers directly to pressure sensitive vinyl. Most of the newer machines are large format inkjet but 3M also makes an electrostatic system that has very high durablility. My guess is that they are using large format inkjet. The prices quoted by JETMEK319 are in line with high quality inkjet with an protective overlay.
Mike
DLKAPA
Mon Sep 19, 2005 2:23 pm
LMAO!
N1120A
Mon Sep 19, 2005 2:26 pm
 rotfl  rotfl  rotfl  rotfl
As a native Angeleno, that is so funny, it brings a tear to my eye
Quoting BandA (Reply 8):
Lincoln, lest Superfly come and get you
lincoln
Mon Sep 19, 2005 2:34 pm
Quoting GentFromAlaska (Reply 5):
I don't know how F9 Runs MX, but it would seem more logical to me that the panels were printed in Hamburg, Germany and applied in Denver rather than the other way around... Does Frontier really shuttle their aircraft across the atlantic for repainting/redecaling?
N1120A
Mon Sep 19, 2005 3:16 pm
Quoting Lincoln (Reply 14):
They want to do the decals locally. Beyond that, they need access to them if they need to make an emergency fix
No, I do believe that is just for the original application, then F9 has the ability to do it in their hangars at DEN
