drinkstrolley
What's Smoking In This Picture?
Thu Sep 22, 2005 5:47 am
This VS 747 hasn't just touched down (unless it's just flown with a tow truck attached to it for the duration of its flight!) so it's not tyres so what else could it be?
Or is it exhaust from the tow truck?
Cheers!!
Photo © Piotr Pluciennik
Btriple7
RE: What's Smoking In This Picture?
Thu Sep 22, 2005 5:52 am
The exhaust was probably coming from the engine. When you start up a jet engine a small puff of smoke can normally be seen. I am not sure why (you need an aviation expert for that explanation).
Btriple7
[Edited 2005-09-21 22:52:50]
Just...fly.
greasespot
Start up of the engines. More noticiable on a cooler day.
GS
Sometimes all you can do is look them in the eye and ask " how much did your mom drink when she was pregnant with you?"
drinkstrolley
Thu Sep 22, 2005 5:53 am
I'm not doubting you, but I've never seen that!!
dogfighter2111
Thu Sep 22, 2005 5:55 am
Yer, it is just the engines starting.
If you own a Diesel powered engine (in your car) then when you start the engine, a lot of smoke comes out of the exhaust.
Mike
B742
The smoke usualy happens when a engine starts up, it is very visible on cold mornings or evenings at LHR!
Here's some more examples:
Photo © David Sullivan
Photo © Jussi Kettunen
Rob!  Smile
As smooth as silk
Btriple7
Thu Sep 22, 2005 5:57 am
Here is another pic. Read the remark:
Photo © Harri Koskinen
Just...fly.
drinkstrolley
Thu Sep 22, 2005 6:03 am
Quoting Dogfighter2111 (Reply 4):
Mine doesn't!! I've got a Transit van as well with a 180,000 miles on the clock and that doesn't smoke either! (Mind you it's rare to get the f*cker started at all these days!!!)
I had no idea these jet engines smoked when it was cold, makes sense I suppose - hot air into cold etc etc.
midnights
Thu Sep 22, 2005 6:27 am
Fuel vapor.....if the conditions are right (temp, humidity and such) this happens quite often. Also, if the pilot or mechanic running the eng. puts the fuel on even a hair too soon you can get a nice stream of vapor out the tailpipe.
dogfighter2111
Thu Sep 22, 2005 6:30 am
Quoting Drinkstrolley (Reply 7):
hehe, well my Step Dads Citroen Xantia does. lol
Mind you, that is 10+ years old. (He doesn't want to get rid of it, because it is so reliable. I wish he would though, the shape isn't all that nice  Smile )
Mike
