MFEFlyer
CO And Its Aircraft....
Fri Sep 23, 2005 1:19 am
I had a question, I understand that there are severl topics relating about CO, and hurricane rita etc...
But I have a quesiotion and anybody that could help will be great.
CO or any other airline will fly there aircraft else where in the event of a hurricane. To what airports do they send there aircraft to.
For example will they send them south to MFE,HRL, or BRO
or will they send them to there hubs, but I know sometimes they send aircraft to non hubs.
any facts will be greatly considered.
Valley Approach.....
flyXJT
RE: CO And Its Aircraft....
Fri Sep 23, 2005 1:31 am
CO, like most other airlines, will try to reposition the aircraft anywhere theres room to stick them. Ideally it would be close enough they don't burn as much fuel getting them safe, however, certain cities only have so much room.
In addition, CO is usually very proactive when it comes to bad weather, so they will end up canceling IAH turns and routing usually as far out as today. This means a IAH-STL flight that supposed to turn back to IAH will spend the next few days at STL, thus maximizing revenue flying and cutting back on the ferry flights.
There is also a problem of places like CLE and EWR then getting all these extra planes due to changed routing, and both places are rather squeezed on space as it is. In that case cities close to EWR and CLE with some room may get some ferry flights (ABE, GRR, MKE, BUF, ERI, etc) just to get them out of the way, and so when the time comes, the aircraft can be quickly dispatched.
Hope this helps, I'll let you know more when I go back to work tomorrow and see how things are, or aren't going.
pw
MFEFlyer
Fri Sep 23, 2005 1:59 am
So what are the odds of CO aircraft coming down to Airports in deep South TX, especially in MFE, because if so, I have some spotting to do!
STT757
Fri Sep 23, 2005 2:02 am
I think CO is going to send alot of their IAH aircraft to EWR, CLE and MCO where they have a maintenance base.
BostonGuy
Fri Sep 23, 2005 2:04 am
Quoting MFEFlyer (Reply 2):
Most unlikely.
This isn't like the Air Force which flies it's plane out of a hurricane's path and then parks them until they can go back.
We're dealing with airlines that have to carry passengers to pay for the planes that are being re-scheduled.
Tornado82
Fri Sep 23, 2005 2:10 am
Quoting FlyXJT (Reply 1):
ABE is also often a diversion airport (mainly for ExpressJet ERJ's) for storms/wx in EWR, so I'll definitely be taking a trip up Airport Road to see what can be seen hanging out up there.
As for ERI, considering only Commutair goes there (out of CO), and the runway is relatively short, I'm not too sure about there, but if you work for ExpressJet and say so, I'll take your word for it.
flyXJT
Fri Sep 23, 2005 2:13 am
Quoting Tornado82 (Reply 5):
ERI has long been used as an alternate for CLE. The main question is if they will need to displace any aircraft there because, as of right now they have started parking planes in the outstations.
Tornado82
Fri Sep 23, 2005 2:16 am
Quoting FlyXJT (Reply 6):
That settles that, but it leads to one question:
Is that for when CLE is getting 1/8 mi VIS in heavy snow at 3" per hour, and ERI is only getting "flurries" (as the locals would call it) of 1/4mi VIS in moderate snow at 1" per hour?  Wink
boeingfever777
Fri Sep 23, 2005 2:22 am
Any chance that AUS will get any diversions on Sat? Also where is Peter Max? I bet they are protecting that 777 being it's so famous. Hope all goes well at IAH and HOU.
Faire du ciel le plus bel endroit de la terre.
Tornado82
Fri Sep 23, 2005 2:32 am
Quoting BoeingFever777 (Reply 8):
More like, I bet they are protecting ALL AIRCRAFT being they're SO VALUABLE! D'uh.  Yeah sure  Silly 99% of non-A.netter's/aviation geeks probably don't even know there is a gaudy plane painted by an artist that 99% of non-art fans have never heard of.
optionscle
This isn't entirely true. While the gate space is an issue at peak bank times, there is a lot of room to park aircraft at CLE. There is CO maintinence, Air Services, the IX Center ramp (which is very large) and the pads that used to be runway 18/36. I'd imagine that some of the CLE-IAH flights will end up being parked at CLE for a while.
MFEFlyer
Fri Sep 23, 2005 2:39 am
How about the flights inbound to MFE,HRL,BRO, will they be cancelled, and if so, where would the aircraft go?
erj-145mech
Fri Sep 23, 2005 5:56 am
Quoting MFEFlyer (Reply 11):
Since they would be cancelled, they would most likely be at another outstation because they couldn't make it into IAH.
MFEFlyer
Fri Sep 23, 2005 6:07 am
Quoting Erj-145mech (Reply 12):
That means that the aircraft would be to the prior airport before it gets to IAH, then makes the next connection to Valley airports, right?
MFEFlyer
Fri Sep 23, 2005 6:22 am
Hey a.netters, I've read some threads about CO canceling flights and what not
I need help on something, I was checking flight availabilities on CO's website, and I input a flight from MFE-IAH and back for 9-23, and 9-24, there's only 1 or 2 flights round trip. I'm pretty sure this is because of the hurricane, but I noticed that they're sending 737-800's and 1 737-300, why not send larger aircraft, maybe like a 757-200/300 since there's only such avalible flights.
Also checked for BRO and HRL, and it seems there are no flights avalible, why is this?
Is it because of expressjet?
[Edited 2005-09-22 23:30:58]
MFEFlyer
Fri Sep 23, 2005 6:47 am
Help would be helpful. Thanks
ikramerica
Fri Sep 23, 2005 7:11 am
Quoting MFEFlyer (Reply 14):
Maybe because those planes will be in LAX, SEA, MCO, EWR, CLE, TPA, etc.
ejmmsu
Fri Sep 23, 2005 10:48 am
What are the chances that cities that don't normally get CLE service ( OKC , GSO , and many more) getting flights to CLE to help get people where they need to go ?
"If the facts do not conform to the theory, they will have to be disposed of"
EMBQA
Fri Sep 23, 2005 11:07 am
Most will not be sent anywhere. They will just cancel the return segment to IAH and the aircraft will remain were it is. If gate space gets tight at that airport, they'll just push it off the gate to a remote parking spot.
Falcon84
Fri Sep 23, 2005 11:52 am
Quoting Ejmmsu (Reply 17):
Won't happen.
Work Right, Fly Hard
iahcsr
Fri Sep 23, 2005 4:48 pm
Quoting EMBQA (Reply 18):
 praise
This is almost exactly the plan.... CO will operate 48 morning arrivals and 55 pre-noon departures on the 23rd. The aircraft will ramain at that destination city until Sunday the 25th (...Or Perhaps longer.. Depending on what Rita does to IAH)
There will be NO CoEx/CoCn Flights at all Fri/Sat ..  redflag   raincloud   scared   splat
A340Spotter
Fri Sep 23, 2005 4:57 pm
BoeingFever777,
Since you asked, currently Peter Max is enroute from HKG-EWR as of 0800z.
I'm working him tonight...
Jeffrey
"Irregardless, it's a Cat III airplane, we don't need an alternate!"
Flyawa
Fri Sep 23, 2005 11:06 pm
Any updates on where CO and COEx are placing their fleet besides out-stations and other hubs? Have they secured enough crews to evacuate from IAH after ops are suspended?
Better than most, not as good as some.
MFEFlyer
Sat Sep 24, 2005 12:27 am
ATTENTION: my question and topic was answered!
Just in from the local News paper here in McAllen, Texas
from Airport Director Darald Lary quote: "McAllen has offered safe haven for up to seven Boeing 737s and as many as 10 regional jets at the airport, Lary said. While those airplanes likely won’t have passengers, McAllen also could receive airplanes diverted away from Houston that are carrying passengers, probably from Central America and South America."
haj96
Sat Sep 24, 2005 12:43 am
I just heard that Rita has sligthly changed her path so Houston is not directly in her way anymore. So any news/update what´s going on in IAH and HOU ?
haj96
ARGinLON
Sat Sep 24, 2005 12:48 am
Quoting Haj96 (Reply 24):
I guess the operational damage is made and therefore I don't thing it would be possible for CO to reinstate (if it as possible) some of the flights. Having said that, I still think that the predicted 80MPH winds will shut the airport anyway
haj96
Sat Sep 24, 2005 1:16 am
Thanks ARGinLON. Just found this article that IAH will be closed soon (sorry, only in German).
http://www.netzeitung.de/reise/flugverkehr/359436.html
So my question has been answered.
haj96
tjwgrr
Sat Sep 24, 2005 2:06 am
Looks like ELP, DFW, and ABQ
Airline Continental
Flight Number 9944
Departure City (Airport) Houston, TX (IAH)
Departure Time 09/23/2005 09:13 AM
Arrival City (Airport) El Paso, TX (ELP)
Arrival Time 09/23/2005 09:40 AM
Remaining Flight Time 00:00
Aircraft Type Boeing 757-200
Current Altitude 0 feet
Current Groundspeed 0 mph
Flight Status Arrived
Airline Continental
Flight Number 9943
Departure Time 09/23/2005 11:27 AM
Arrival Time 09/23/2005 11:57 AM
Remaining Flight Time 00:57
Aircraft Type Boeing 737-500
Current Altitude 36,000 feet
Current Groundspeed 539 mph
Flight Status In Flight
Airline Continental
Flight Number 9940
Departure Time 09/23/2005 11:52 AM
Arrival City (Airport) Albuquerque, NM (ABQ)
Arrival Time 09/23/2005 12:40 PM
Remaining Flight Time 01:48 (planned)
Aircraft Type Boeing 737-300
Flight Status Planned
Airline Continental
Flight Number 9945
Arrival City (Airport) Dallas, TX (DFW)
Arrival Time 09/23/2005 12:35 PM
Remaining Flight Time 00:43 (planned)
Airline Continental
Flight Number 9941
Departure Time 09/23/2005 11:54 AM
Arrival Time 09/23/2005 12:20 PM
Remaining Flight Time 01:18
Aircraft Type Boeing 737-700
Current Altitude 3,000 feet
Current Groundspeed 270 mph
Direct KNOBS, maintain 2700' until established on the localizer, cleared ILS runway 26 left approach.
jetpixx
Sat Sep 24, 2005 3:02 am
Quoting A340Spotter (Reply 21):
BoeingFever777,
A good place for Peter Max to ride out the storm would be BPT or LCH!
ABE, BIL, BOS, BUF, CAE, CAK, CHS, CLE, CLT, CVG, DAY, DFW, DTW, EWR, FLL, GSO, IAD, IAH, IND, ISP, JAX, JFK, LAS, LGA, M57, MDW, MEM, MHT, MIA, MKE, MLB, MSO, MSP, OMA, ORD, PBI, PHL, PIT, PVD, RDU, SEA, SFO, SLC, SJU, STL, SYR, TLH, TMB, TUL, YVR
bond007
Sun Sep 25, 2005 10:03 pm
Sorry to disappoint you, but the plan must have gone wrong  Wink
El Paso got at least 12 from IAH.
UTC time: 12:56 on Sun, 25th Sep(Note: ALL Times are UTC/GMT)
Previous Arrivals/Departures
Flight# Type Dep Time Arr Time Date
COA9973 B752 IAH 02:37 AMA 03:39 09-23-2005
COA9944 B752 IAH 14:13 ELP 15:40 09-23-2005
COA9943 B735 IAH 16:27 ELP 17:55 09-23-2005
COA9941 B737 IAH 16:54 ELP 18:23 09-23-2005
COA9945 B733 IAH 18:12 DFW 18:48 09-23-2005
COA9940 B733 IAH 17:08 ABQ 18:50 09-23-2005
COA9961 B735 BWI 19:56 CLE 20:45 09-23-2005
COA9948 B735 EWR 17:56 IAH 20:55 09-23-2005
COA9957 B737 IAH 19:57 ELP 21:26 09-23-2005
COA9953 B764 IAH 20:18 ELP 21:47 09-23-2005
COA9962 B738 IAH 20:22 ELP 21:49 09-23-2005
COA9958 B737 IAH 20:32 ELP 21:56 09-23-2005
COA9989 B739 IAH 20:42 ELP 22:12 09-23-2005
COA9955 B733 IAH 20:13 CLE 22:19 09-23-2005
COA9963 B738 IAH 21:00 ELP 22:30 09-23-2005
COA9964 B738 IAH 21:05 ELP 22:34 09-23-2005
COA9987 B739 IAH 21:20 ELP 22:49 09-23-2005
COA9988 B739 IAH 21:23 ELP 22:52 09-23-2005
Jimbo
willbdsp
Mon Sep 26, 2005 11:22 am
There are two ExpressJet planes parked at BHM...one at the gate and one near a hangar.
acidradio
Mon Sep 26, 2005 2:13 pm
It seems like they sent a couple (or more) aircraft to each station. Everyone seems to have a couple spare CO aircraft sitting around. Here at MSP, we've had 2 735's sitting around doing nothing. Worked out well in one circumstance - had one aircraft break, so we actually (begrudgingly  Wink ) swapped to another airplane, which is rare for an outstation.
Ich haben zwei Platzspielen und ein Microphone
