1MillionFlyer
Finals Versus Final - Correct Terminology
Tue Sep 27, 2005 1:13 pm
Many people on A.net incorrectly use the term "finals" to describe the final approach segment of flight.
The final approach is a singular activity not a plural activity hence the singular form of the word.
"Finals" is non standard ICAO phraseology. This is not just a "US English" versus "British English" issue.
http://www.faa.gov/ATpubs/PCG/F.HTM
FINAL- Commonly used to mean that an aircraft is on the final approach course or is aligned with a landing area.
(See FINAL APPROACH COURSE.)
(See FINAL APPROACH-IFR.)
(See SEGMENTS OF AN INSTRUMENT APPROACH PROCEDURE.)
FINAL APPROACH [ICAO]- That part of an instrument approach procedure which commences at the specified final approach fix or point, or where such a fix or point is not specified.
a. At the end of the last procedure turn, base turn or inbound turn of a racetrack procedure, if specified; or
b. At the point of interception of the last track specified in the approach procedure; and ends at a point in the vicinity of an aerodrome from which:
1. A landing can be made; or
2. A missed approach procedure is initiated.
I do agree that US English is incorrect in using "Math" as a term instead of the correct British term "Maths" since the science is Mathmatics, not "Mathmatic".
Golf Foxtrot you are cleared for departure
TinkerBelle
RE: Finals Versus Final - Correct Terminology
Tue Sep 27, 2005 1:44 pm
lol.. Maybe you should have been an English teacher huuh! Bottom line is we all know what one means by 'finals' although I do agree with you though  box
If you are going through hell, keep going.
NAV20
Tue Sep 27, 2005 1:59 pm
Quoting 1MillionFlyer (Thread starter):
Agree entirely, 1MillionFlyer. Except that I recall that, at flying club slang level, the expression 'I'm/he's on finals' tended to include being established in the later stages of a landing circuit (maybe on the downwind or base leg) rather than 'on final approach' (which I agree should ALWAYS be called that, since it means that you are committed to landing).
[Edited 2005-09-27 07:01:22]
"Once you have flown, you will walk the earth with your eyes turned skywards.." - Leonardo da Vinci
1MillionFlyer
Tue Sep 27, 2005 2:15 pm
Quoting NAV20 (Reply 2):
Good to know slang in Australia! I love that country, except for the 14,5 hour flight it took to get there  Smile
When I was doing flight training we called it "in the pattern" here in the US.
Thanks for the information.
OPNLguy
Tue Sep 27, 2005 2:17 pm
The only exception I can readily think of is when we're referring to multiple runways. For example, at DFW, there are 17L, 17C, 17R, 18L, and 18R when landing to the south, and should someone (for the sake of argument) in a little GA airplane fly east-to-west across the north side of the airport, that aircraft is cutting across the finals at DFW. It could just as easily be a big thunderstorm affecting the finals at DFW.
1MillionFlyer
Tue Sep 27, 2005 2:19 pm
Quoting OPNLguy (Reply 5):
Now that works, because there are multiple of them being used at once
[Edited 2005-09-27 07:20:37]
MarshalN
Tue Sep 27, 2005 2:37 pm
I have a slightly related question...
When you are flying in, about to land on runway 13 at Kai Tak in the good old days, when does Final begin? After the last turn?
Type-Rated
Tue Sep 27, 2005 2:40 pm
I would say that in the given example, the GA plane is not cutting in front of the finals, but rather crossing over the other aircrafts final approach paths.
I have heard "in the pattern" and "in the circuit" used interchangably.
Fly North Central Airlines..The route of the Northliners!
NAV20
Tue Sep 27, 2005 2:57 pm
MarshallN, final approach started out over the water, and came in over the city (Kowloon?). There used to be a big black-and-white visual marker at the point (called 'Checkerboard Charlie') where pilots had to start the final turn; maybe it's still there.
I believe that approaching from the other direction, over Victoria Harbour, was just as hair-raising in its way, because of the solid wall of mountains in front of you. A friend once showed me the 'Pilot's Notes' for Kai-tak; for that approach, under 'Go-Around Procedures', it just said something like, "Go-Around procedures should not be attempted when landing on Runway 31."  Smile
ba321
Tue Sep 27, 2005 6:14 pm
In the UK even from basic PPL training we always call it final, indeed the tower at Denham when hes bored corrects people who say finals, as the correct phraseology in the UK is final.
Fly safe, ba321
VH-KCT*
Tue Sep 27, 2005 7:35 pm
Wouldn't it be more simple to save final for the leg of the circuit that is actually known as final. Rather than using the term for base and downwind as well? Your circuit seems to have upwind, crosswind, final, final and final.
I've never heard finals used anywhere other than here on A.net. And final is a term I've very rarely used except for maybe;
  • turning final: for turning onto the leg of the circuit known as final
  • mid-final: the location of a check height
  • short final: saved for the broadcast when you're over the threshold at 50 ft and the tower has forgotten to clear you to land. Or use very short final for added dramatic effect.  Smile
  • I am The Stig
    1MillionFlyer
    Tue Sep 27, 2005 9:59 pm
    Quoting VH-KCT* (Reply 11):
    That is why I posted this on A.net. I have been a licensed pilot sine I was 17 which is shockingly 20 years ago and I have also never heard the term "finals" any place except here on A.net.
    FlyPIJets
    Tue Sep 27, 2005 11:40 pm
    I agree, when I read finals in a post, it reads as if a 10 year old is writing and making a mistake. But I think I understand why or how the term finals has come into use.
    For illustration, take the term petrol. Singular petrol means gasoline. But the plural, petrols, would imply any petrochemical, or at least a variety of gasolines.
    The term, final, is an aviation technical term, used by ATC and pilots, and refers to a specific phase of flight. However, we have all been a pax and heard a flight attendant indicate that we have begun our final decent into... That confuses the term final.
    So, enter the plural, finals, ambiguously indicating some stage of arrival of a flight. It is the ambiguity in the term, finals, that rubs the wrong way.
    At least, that is how I read it. When a poster uses finals, they are being unclear. Maybe approach would be a better term.
    Rex Kramer: Get that finger out of your ear! You don't know where that finger's been!
    Sabenaboy
    Wed Sep 28, 2005 12:10 am
    ...rather than 'on final approach' (which I agree should ALWAYS be called that, since it means that you are committed to landing).
    Hi NAV20,
    Just wanted to let you know that I've been flying for over 25 years now.
    I've been on final thousands of times by now...but I've never been committed to land before. You are only committed to land when a go-around is not an option anymore. I hope that I'm never in such a position.
    (The only times I was committed to land until now was in gliders)
    Sabenaboy
    1MillionFlyer
    Wed Sep 28, 2005 2:02 am
    Quoting FlyPIJets (Reply 13):
    Absolutely. I am just hoping once and for all we can wipe out "finals" from the A.net lexicon.
    Pihero
    Wed Sep 28, 2005 7:07 am
    Well said.
    I don't think so as you have four stages of approach : initial, intermediate, final and missed.
    That attitude defeats the object of R/T discipline , which is to give the people around you -and the tower- an accurate knowledge of your position.
    Quoting NAV20 (Reply 9):
    Strange airline your friend was working for. There cannot be an instrument approach without a published go-around (or rather "missed approach" ) procedure. That trajectory had to be adhered to quite accurately, for the relief you mentioned. Besides, RWY 31 was also used for take-off.
    Contrail designer
    FlyPIJets
    Wed Sep 28, 2005 7:29 am
    Quoting Pihero (Reply 17):
    Look at these two sentences:
    As I looked out of the window, I noticed we were on finals for the airport.
    As I looked out of the window, I noticed we were approaching the airport.
    Using the term finals in the first sentence makes the sentence unclear. The second sentence is very clear. The second sentence could be more precise in describing the stage of approach, but, the sentence is also clear in not doing so.  Smile
    1MillionFlyer
    Wed Sep 28, 2005 11:29 am
    The first one also sounds weird  Smile
    hawker
    Wed Sep 28, 2005 3:24 pm
    Don't know what the practice is in various countries but when flying a square pattern for a particular runway at smaller airports, a pilot will either report on the downwind, base or final approach legs as required.
    As noted by VH-KCT in reply 11, you need to advise the tower when on final approach usually by calling turning final or on short final.
    One think that does puzzle me though, I have never heard the term long final used. It is of course possible to be cleared for a straight in approach.
    1MillionFlyer
    Wed Sep 28, 2005 10:21 pm
    Quoting Hawker (Reply 20):
    Usually when doing instrument approachs at uncontrolled airports in the US if you are on a long final you usually announce 5 mile final, etc. I have heard people say long final as well.
    gerardo
    Wed Sep 28, 2005 11:51 pm
    And I thought, this science was called "Mathematics"....
     Smile
    Gerardo
    dominguez(dash)online(dot)ch ... Pushing the limits of my equipment
    1MillionFlyer
    Thu Sep 29, 2005 12:02 am
    Quoting Gerardo (Reply 22):
    Touche'! Yes it is, but the edit function quit working and I couldn't change it.
    It's nice to see another literate person posting. LOL
    MarshalN
    Thu Sep 29, 2005 2:06 am
    That is indeed a strange thing to see, since they do takeoffs and the alternative to a go-around (landing at high risk, I presume) is running into the road, the bridge, and then the buildings in front of the runway. Might not be a good thing. I believe the standard takeoff (and I think the only viable one) is a sharp left turn to avoid Lion's Rock.
    Pihero
    Thu Sep 29, 2005 8:16 am
    Actually, I can only remember two cases where the word "final" is used by pilots on IFR :
    - Calling "long final" when (s)he has been cleared for a straight-in approach, on the first contact with the tower. To which the reply would be :"Call outer marker inbound" or "Leaving 2000 on the glide", or "...call 5 mile final..." (very common at LHR and about nowhere else)
    - On a multiple runway operation :"XXX on final (RWY) 26", to confirm one's position and previous clearance.
    The term "long final", btw, has no official meaning, as the definition of "final approach" implies that the aircraft is at the last segment of its flight and has passed the approach fix...But as we all know, old habits die hard.
    Contrail designer
    1MillionFlyer
    Thu Sep 29, 2005 11:03 am
    Usually in the US at controlled airports you hear:
    "Tower XXX checking in for the right side" or "Tower, XXX with you at (Insert outer marker name here). or during VFR, Tower, XXX with you at the (Insert landmark here).
    Silver1SWA
    Crew
    Thu Sep 29, 2005 1:33 pm
    The use of the term "finals" here at a.net is something I have never understood.
    1MillionFlyer
    Fri Sep 30, 2005 5:05 am
    Quoting Silver1SWA (Reply 27):
    I am hoping we can put an end to it once and for all (A guy can dream)  Smile
    Molykote
    Sun Oct 02, 2005 10:46 pm
    What about bad pilots who need multiple landing attempts? scratchchin
    Speedtape - The aspirin of aviation!
    1MillionFlyer
    Tue Oct 04, 2005 7:55 am
    Quoting Molykote (Reply 28):
    They would conduct a missed approach or go around followed by another final  Smile
    DCrawley
    Tue Oct 04, 2005 12:01 pm
    Quoting Hawker (Reply 19):
    Reporting positions in a rectangular pattern at an uncontrolled airport could be: crosswind, entering on the 45 for downwind, midfield, turning base, turning final.. and of course, you should include the runway. I rented a Piper Cherokee last month and was flying to an uncontrolled airport and I entered the pattern, then I heard some guy come on claiming he was in a Bonanza, in the pattern, and at the same position I was currently at (turning downwind to base). I opted to abort the approach and find out where this guy was. Turns out he was flying a right-traffic pattern for a standard (left-pattern) pattern runway. He must have been training because he was doing full-stop taxi-back's, so when I came around to land, I made it very clear to call my turns and their direction (a la "5TW turning LEFT base for runway 34") so he could not endanger anyone else.
    I don't usually hear long final, only things like "on 3 mile final", where they call the distance of the a/c from the runway.. you could have a longer final approach because of an "extended downwind" where the tower will "call your turn".. but instead the forget about you until you call them to let them know you're goin' to bust Bravo airspace if your turn isn't called.. lol
    "Weather at our destination is 50 degrees with some broken clouds, but they'll try to have them fixed before we arrive."
    Tue Oct 04, 2005 12:15 pm
    The only time I hear "Final" used is when cleared by ATC "Cleared for Final", e.g they clear you descend to a lower altitude and intercept the LLZ, once established on the LLZ they may say "cleared ILS" or "cleared final", have the same meaning.
    If wanting to report the position in the circuit, correct terminology is "FINAL Runway XX"
    AirNZ
    Tue Oct 04, 2005 1:30 pm
    I fully agree that the 'slang' here on A.Net can be somewhat weird and, while slightly off topic, my biggest bugbear regarding misuse is why so many members persist in using the word 'aircrafts'!!
    There is no such word and I would honestly have thought that everyone was aware that the plural for aircraft is still....aircraft!
    As stated in posts above, the use of such 'errors' by people who should know better is exactly like a young child would write.
    Flown:F27/TU134/Viscount/Trident/BAC111/727/737/747/757/767/777/300/310/320/321/330/340/DC9/DC10/Dash8/Shorts330/BAe146
