planesailing
A319 London - New York
Thu Sep 29, 2005 9:37 am
The Airbus website states the following:
A319 operational flexibility provides range possibilities of 3,700 nm./6,800 km., and longer for non-stop trans-Atlantic flights.
It is possible with a cabin of 8F/116Y to make this route, and make it profitably?
FlySSC
RE: A319 London - New York
Thu Sep 29, 2005 10:23 am
Quoting Planesailing (Thread starter):
Yes it is.
That will depend only on the fares proposed, airline management, load factors, etc ...
mNeo
Thu Sep 29, 2005 10:40 am
Techincally no. The landing fees would be way to big to support a 116Y config. More likely would be 14xweekly flights with a 319CJ in a 40J seat config, with a dedicated check in and security(one can only dream). Otherwise the Big Boys(AA VS BA UA CO) take the win.
Small Jets are profitable if 1)they run high Jclass markets (Privat air comes to mind) and 2) if they do many cycles a day (LCCs) The longhaul Narrow body in an mostly Y config has basically no chance.
Also can an A319 make LON-NYC with a full payload? Any ETOPS restrictions if operating with a full load?
[Edited 2005-09-29 03:43:10]
Powered by Maina
FlySSC
Thu Sep 29, 2005 11:53 am
Quoting MNeo (Reply 2):
LON-NYC = 5583km / 3015nm / 3469mi
Range of an A319* with full PAX playload + Baggage allowance + fuel reserves + other airline operating rules (such as weather conditions, head/tail wind) :
3700nm / 6800km.
* figures for a "standard" A319-100, not an A319CJ.
No particular ETOPS restrictions on this route.
ETOPS doesn't have anything to do with full/not full load.
Tornado82
Thu Sep 29, 2005 12:01 pm
What about CO's 757's??
Paul
Fri Sep 30, 2005 12:15 am
I would not pay to go that flight, the First Class would be terrible unless decent 50inch seat pitch recliners or beds were installed. But that would obviously take up a lot of room. It would be pretty stuffy in that thin stubborn tube.
Paul
Veni, vidi, vici.
N1120A
Fri Sep 30, 2005 12:30 am
ACT equipped A32S have proven not to have the range claimed. In fact, the added weight of the tank burns off the extra fuel. The ACT was designed for the A321 and only really works on that, hence there are no 3,700nm A319s out there
No
N770WD
Fri Sep 30, 2005 12:40 am
For an A319 operating LON to JFK during the winter, block fuel is 44,000, contingency and reserves (assuming ETOPS) would vary by carrier but likely around 9,000, for total fuel of about 53,000 lbs. With a max takeoff weight of 166,500 and empty weight of about 96,000 pounds, that would leave:
166,500 TOW
-96,000 OEW
-53,000 Fuel
17,500 payload
That translates to about 75-80 passengers on average.
Note the aircraft must have at least 2 auxiliary center tanks installed to make it with ETOPS reserves. 53,000 pounds of fuel is about 7,850 gallons. Standard A319-100 fuel capacity is 6,300 gallons. 2 ACTs buys you 7,885. So an A319ER with 2 ACTs has the fuel capacity to run the route. An A319LR buys you 9,354 gallons of capacity with four ACTs.
This also assumes the aircraft is operated ETOPS/180. With less ETOPS capability the payload will go down quickly. Note that you can load additional aux fuel tanks, but the fuel comes 1:1 from payload as the MTOW is capped at 166,500.
So the A319 can work in an all-business configuration (44 pax * 255 lbs = 11,000 pounds of payload) but not in a mixed configuration at that stage length -- and aux fuel tanks don't solve the problem.
cloudyapple
Fri Sep 30, 2005 3:13 am
Why would I want to limit my choice by flying on a once a day A319 over the almost hourly regular widebodies?
A310/A319/20/21/A332/3/A343/6/A388/B732/5/7/8/B742/S/4/B752/B763/B772/3/W/E145/J41/MD11/83/90
mNeo
Fri Sep 30, 2005 5:35 am
Quoting Tornado82 (Reply 4):
Do any of CO's 757 compeate with any other airlines?
Also the 757 seats about 70 passengers more than the A319
Powered by Maina
3201
Fri Sep 30, 2005 5:50 am
Quoting FlySSC (Reply 3):
That's not necessarily true. If the ETOPS divert scenarios require extra fuel uplift beyond what would normally be carried for the trip and all the contingency fuel, it can reduce payload. In the winter especially, if many divert airports aren't available due to weather, and icing conditions exist everywhere, ETOPS can cause extra fuel uplift that limits payload on aircraft operating near their range-payload limit, plus can force the route to be non-optimal to ensure coverage. Ask European charter operators about Carribbean ops in the winter and what effect ETOPS can have on payload.
7 hours aint long-haul
airman99o
Fri Sep 30, 2005 7:56 am
Skyservice airlines was going to operate the 319 from YHZ to Malaga I think?? Not too sure what happend to that routing. Hmm wait now I think I do Conquest was to be the provider for that flight. not sure if that is a longer flight. and we have 144 passengers on the 319. BLAH what a horrible way to fly across the pond! Hmmm alomst as bad as the 757 in the fleet :P
airman99o
Safety is Everyones Responsibility.
JAGflyer
Fri Sep 30, 2005 8:35 am
Not sure if it was already mentioned but Privatair runs flights from ORD and EWR (I think) to MUC using A319s in all J class configurations.
Support the beer and soda can industry, your recycle old airplanes!
Scotland1979
Crew
Fri Sep 30, 2005 10:06 am
No way!!
I have been on A319 before on a short hop from Heathrow to Frankfurt. It is small tube and I couldn't imagine the London-New York flight. Flight across Atlantic Ocean, the wind out there too much tubulence for a small plane like A319 - alot of passengers might throw up....
I would go for 757 instead but I would say 744 and 772 suit best for transatlantic  melting
Jesus said "I am the Way and the Truth and the Life. No one comes to the Father except through Me" - John 14:6
Tornado82
Fri Sep 30, 2005 11:01 am
Quoting Scotland1979 (Reply 13):
HAHAHAHA. People fly in Biz jets across the pond regularly, I'm sure an A319 could survive it if people do it in stuff like Challengers. Likewise, there's more turbulence in places like crossing the Rocky Mountains than in the middle of the ocean. Sure there's alot of wind in the Atlantic, but it's not mountain-generated wave turbulence or something over a flat expanse like that.
Av8rDAL
Fri Sep 30, 2005 10:57 pm
I do recall reading a trip report a while back of someone taking a PrivatAir (operated for LH) flight from DUS-EWR in the 737NG. I think it was 50 pax in an F configuration. Smooth flight and good, attentive service. The only complaint was the higher cabin noise since the 737 is apparently noisier than a widebody due to sound insulation or cabin size or what have you.
The 319 is also used by PrivatAir...and I think their model is the only way it could be profitable. You just would have to make it an exclusive experience with a few pax paying a high fare for pamper-me-continuously service if you wanted to gain market share from those who already have a great First Class product in that market (BA, VS, AA).
Could be done, maybe. After all, Concorde did it all these years. The A319 does not cost as much as Concorde to operate, however.
Maintain thine airspeed, lest the Earth rise up and smite thee.
babybus
Fri Sep 30, 2005 11:44 pm
Flying UK-east coast USA/Canada isn't a particularly long route.
Flying in a A320 class aircraft could be rather nice as you get served quicker and more intimate, relaxed, service.
I'd give it a go.
Cheers  Smile
and with that..cabin crew, seats for landing please.
gigneil
Sat Oct 01, 2005 4:10 am
Quoting N1120A (Reply 6):
Ugh, this again?
The ACT doesn't work great on the A320. Clearly the ACT works great on the A319 since even further additional tankage is added to make it a 319CJ.
N
2travel2know
Sat Oct 01, 2005 5:16 am
Is the A319 or A318 (or the B737-600/700 for that matter) LCY certified?
I'm just thinking loud; and too bad LGA doesn't have US inmigrations and customs or LCY a overseas US Federal Inspection...
I don't work for COPA Airlines!
FlySSC
Sat Oct 01, 2005 11:45 pm
Quoting Av8rDAL (Reply 15):
44 PAX
J (Business) Configuration.
Quoting 2travel2know (Reply 18):
Definately not the A319.
A Steep approach certification process for the A318 has started ...
http://www.airliners.net/discussions...general_aviation/read.main/2277769
boysteve
Sun Oct 02, 2005 1:47 am
Quoting MNeo (Reply 9):
...and the 757 lands at airports such as BRS, and soon NCL, which presumably have lower landing fees than LHR for example. I can see the A319 making it JFK-LHR, but I wonder how often the westbound return would have to but down at Halifax (Nova Scotia) to take on more fuel
CXH
Sun Oct 02, 2005 8:30 am
Quoting Airman99o (Reply 11):
It was going to be true...
Conquest as the Tour Operator announced in early 2002 and started to sell YHZ-YYT-LGW for Summer 2002 (or was Summer 2003?) using the Skyservice A319. It was going to be YHZ-YYT-LGW and return 2x week. However, they cancelled before the first flight.
I don't see why flying any narrowbody transatlantic would be a pain versus a wide body. What really counts is seat pitch and design, IFE, service quality, etc. As someone mentioned, private jets do it all the time.
I've seen the future, I can't afford it. - Martin Fry
ikramerica
Sun Oct 02, 2005 8:43 am
What about BOS? I could see 737NG,A32X service between BOS and smaller airports in Ireland, for example...
