Adam T.
Transferring Between Two Different Airlines At LAX
Fri Sep 30, 2005 1:37 pm
I have a question concerning connection between two separate airlines. In November i'll be flying from AKL to LAX on Qantas and then flying LAX-ORD-CLT on United all in the same day. I've never changed airlines before and was curious if it was in anyway different and if I would possibly be able to have my luggage checked all the way through to Charlotte when I check in for the Qantas flight in Auckland.
I should mention that my Qantas flight arrives in L.A. at 10:30 AM at Terminal 4 and then the United flight to Chicago departs at 2:00 PM from Terminal 7. I'm thinking that will be plenty of time and even takes into account the possibility of delays on the Qantas flight. About how long is the walk from T4 to T7? The reason I ask is because I think those transfer busses at LAX are a pain in the ass, especially with luggage which is why I prefer walking...LOL  Smile
Adam  Smile
as739x
RE: Transferring Between Two Different Airlines At LAX
Fri Sep 30, 2005 1:45 pm
Plenty of time. That connection is walkable. Just walk out from of T4, turn right and you can walk to T 6-7 which is used by UA. Tha is way more then enough time.
ASSFO
vega
Fri Sep 30, 2005 1:56 pm
Easy walk. Fortunately you do not have to cross the airport and there are no street crossings just one long sidewalk. Done it many times. Look here : http://www.lawa.org/lax/terminalMap.cfm
We are but a moment in this vast Universe and when gone we will never have existed.
PER744
Fri Sep 30, 2005 2:03 pm
You'll have to collect your baggage at LAX to clear customs. At AKL ask if your bags can be tagged all the way through (this is usually even possible if you're on seperate tickets). Once you clear customs you simply take your bags to the re-check area before leaving the terminal (it's clearly signposted with quite a few staff around to assist you).
After that it's about a 5-10 minute walk to Terminal 7. (try not to choke on the diesel fumes!)
Adam T.
Fri Sep 30, 2005 2:19 pm
Thanks guys for your help, yeah i've walked between terminals at LAX before and there were some fumes but the guys form the LAPD on their bikes made for good eye candy (when planes weren't insight of course)...LOL.
PER744....does United have a transfer desk at the customs facility in T4 even though United only operates out of T6,T7, and T8?
One other question.......my flight on United was purchased through US Airways (flew US to LAX back in June, see Trip report Charlotte to Wellington). On the e-ticket receipt it reads US flight #### operated by United Airlines. Would that be a problem or will the agents at Qantas be able to look it up and see what United flights to transfer it to?
Thanks again guys for all your help  Smile
Trolley Dolley
Fri Sep 30, 2005 2:35 pm
Hey Adam. I'd double check with QF direct about the through check-in. The transfer area is a non airline specific tarsnfer desk. They'll tag your bags, but you still may have to check in at T7 if you don't have your boarding pass. Last time I flew through LAX, on that bl**dy 64hr trip home from South America, I remember I had to lug my bags from Tom Bradley to T4. No big deal, you'll get a luggage cart to push and your legs will normally be wanting a bit of a stretch after the flight up from down under. Bruce
Trolley Dolley
Fri Sep 30, 2005 2:46 pm
Forgot to say, the T4 transfer desks are multi-airline. It's not so much a place where you can check-in, more leave the bags to be transfered to the correct terminal if they've already been through checked. Most airlines are cool with codeshares. The friendly team at AKL will let you know what they can/can't do.
Still, I've had my luggage "lost" on quite a few occassions. Sometimes the hassle of walking it to the correct terminal is worth it. Imagine losing all your Dan Carter memorabilia now? he he he
Adam T.
Thanks Bruce,
So the transfer desk is used by all airlines? Yeah, i'll probably call Qantas and ask them about it. Worst case though i'll just lug them around with me to T7...LOL.
Trolley Dolley
Fri Sep 30, 2005 2:48 pm
See reply above yours. We must have been thinking about the same thing and hit send at the same time, buddy.
Halophila
Fri Sep 30, 2005 2:59 pm
Quoting Adam T. (Thread starter):
I've had mixed success with this. I've tried on separate tickets to go on the NZ side from ZQN to AKL and then a separate ticket from AKL to LAX, and they wouldn't let me go the whole way through; nor checking in from LAX to AKL and separate ticket from AKL to CHC. But looks like other know a lot more about transferring onto domestic flights here in the US.
Around 10 mins, depends on how fast you walk! But it's an easy walk - my advice is stick to the ground level since negotiating the upstairs skycaps and curbside check-ins can be difficult, if you still have bags with you between terminals. Incidentally, if you're looking for a coffee place, then I'd backtrack to TBIT since there aren't any roadside (as opposed to through security) between T4 and T7.
And delays at immigration too... that T4 line is pretty horrendous some days, but getting better. 3.5 h should give you plenty of time.
Incidentally, I thought QF26/107 came into TBIT, has this recently changed? Of course they may still do the immigration processing in T4.
Flown on 707, 717, 727, 732 733 734 735 73G 738 739 741 742 743 744 74SP 757 753 762 763 772 773 77W D10 DC9 M11 M80 M87
Halophila
Fri Sep 30, 2005 3:01 pm
Oh one more thing, I'm sure you know, but should mention anyway. Whereas QF allows you 2 x 70 lb bags (max), UA has recently changed it's policy (I think) to allow 2 x 50 lb bags. So, if you need to re-check them, don't have them 50 - 70 lbs or they'll slap you with some kind of excess baggage.
Best
Halophila
Adam T.
Fri Sep 30, 2005 4:41 pm
Quoting Halophila (Reply 9):
According to the Qantas North America website it say's that Qantas flight 25 arrives into Terminal 4 and that Qantas flight 155 arrives into TBIT. QF 26 and 156 to Auckland both depart from TBIT.
Quoting Halophila (Reply 10):
Thanks for the warning. It's going to be close with one of my bags being at the 50 lb. mark.
Adam
Adam T.
Fri Sep 30, 2005 5:44 pm
Quoting Trolley Dolley (Reply 6):
You've just convinced me to check it through to LAX and then walk it to T7.....my Dan Carter memorbillia is VERY important...LOL  Smile
EurofleetLHR
Fri Sep 30, 2005 6:16 pm
I transferred from a QF flight to a domestic flight in the US from LAX in Mar2003. What a pleasure it was to be the only flight clearing US Immigration in T4!!
Try and get a seat as far forward as possible on the QF flight - the quicker you are off the flight at LAX, the further forward you will be in the queue at Immigration (and the QF flight will probably be full !!!).
All bags - regardless of final destination - must be cusutoms cleared at LAX, so getting them labelled through to CLT from AKL will not save any time here.
Good Luck
EFL.
Halophila
Sat Oct 01, 2005 4:48 am
Quoting Adam T. (Reply 11):
I see. The plane will likely come into TBIT (southern side), then they herd you through this underground passage to clear customs in T4, where you eventually emerge. Makes for a nice walk if that's the case! Good to stretch your legs.
Quoting EurofleetLHR (Reply 13):
Completely agree. And when you get off to go through customs - RUN! It's a bit of a race really to get to the desks. But don't worry. They're actually getting faster than they used to be maybe 3 years ago.
Quoting Adam T. (Reply 4):
He he. And some immigration officers are the same  Smile
Adam T.
Sat Oct 01, 2005 8:50 am
Quoting Halophila (Reply 14):
Thanks, I was actually towards the front of the plane when I flew to AKL and I was one of the first to go through customs on our flight, even with a bathroom stop I still went through fairly fast. When I looked behind me there was this whole crowd moving in. The thing is though I really want to visit the cockpit of the 747. However, i'll ask a.net user airnewzealand if he can arrange this for me in AKL instead of LAX.
Thanks for all your help,
Adam
Trolley Dolley
Sat Oct 01, 2005 8:54 am
Dude, you are a yank. You'll be through customs in your home town faster than I ever could in LAX. In all my LAX experiences, even with priority baggage, I've cleared customs quickly, only to end up waiting for the bags in the reclaim hall. You'll be fine.
