centrair
A332 & 767 Range/usage: Long Thin Routes?
Thu Oct 06, 2005 2:17 pm
Yesterday while discussing NGO's AA replacement and today in the form about KIX, many people mentioned that by the time the 787 comes online we might see more airlines into places like NGO and KIX.
That got me thinking about the A332 and the 767-200ER & -300ER.
The A332 has a stated range (by Airbus) as 6750nm.
The 767-200ER has a stated range (by Boeing) as 6600nm. The 767-300ER has a range of 6105nm.
Of course these numbers are possible, but airlines operate them differently with different requirements. EX: DL's 767-300ER have a range of 5703nm (400nm less than Boeing page). OZ's A332 have a range of 8207nm (1457nm MORE than Airbus page...That can't be right. Bad Math maybe.)
But using the above numbers, it would be possible to do some longer thin routes with currently available equipment. Example; JFK-SHE (5792nm), SFO-CTS (4167nm) and LHR-VVO (4614nm) would be possible with nm to spare. (Even though the market might not be there quite yet)
Would it be possible for airlines (until the 787 and A350 are available) to start setting up thin routes using 767s or A332s? If an airline can do US East Coast to Europe with 757s, why not from Europe and the North America to Asia using 767s and A332s?
My name is Centrair but HND is closer. Let's Japanese Aviation!
ikramerica
RE: A332 & 767 Range/usage: Long Thin Routes?
Thu Oct 06, 2005 2:34 pm
767 can do it from certain places to NRT, but you are pushing the limits, and not the 764, only the 762 and sometimes the 763. But not really economically.
330 and DC10 can do it, too, with similar limitations, and you don't get a lot of cargo from anywhere.
London is a different story. You can serve LHR to much of Asia with any 767 model, but demand is usually such on those routes for a larger plane, so at least 777s, with more pax and cargo, are used.
But who knows, in the very long run, when the newer 762ERs need somewhere to go as 788s take over some of their routes, you could see such routes on CO EWR-NGO or whatever. That plane doesn't take much cargo anyway...
FlySSC
Thu Oct 06, 2005 3:54 pm
Quoting Centrair (Thread starter):
... Or to provide seasonal extra capacity on heavy routes.
That's already what AF did by adding this summer a third DAILY flight on its prestigious CDG-NRT route.
AF272/279 is operated by an A332. This is the longest regular flight operated by this a/c type (9734km/5256nm/6048mi).
Due to the success of this new frequency, this flight will operate also this winter 5 x Weekly.
The two other Daily flights are operated by more "traditional" B772ER & B773ER on that route.
Photo © Kazuteru Sugawara
trex8
Thu Oct 06, 2005 8:52 pm
Quoting FlySSC (Reply 2):
thats a long way! thought TPE-HNL and ICN-PRG, 4500nm was the longest A332 flight before this info.
A360
Fri Oct 07, 2005 12:14 am
^I think the ICN-PRG flight, is done using an A330-300, which has less range than the -200.
ktachiya
Fri Oct 07, 2005 12:29 am
Quoting Ikramerica (Reply 1):
Yes as far as YYZ. AC flies that route during the winter schedule on a B767-300ER which is quite suprising and impressive at the same time. That's what? like 13 hours or so in a 2-3-2 configuration which is good for the pax.
Flown on: DC-10-30, B747-200B, B747-300, B747-300SR, B747-400, B747-400D, B767-300, B777-200, B777-200ER, B777-300
N1120A
Fri Oct 07, 2005 4:37 am
That is very bad math. The A332 doesn't have a chance at doing anything close to that
DL's numbers represent the actual range of the plane, not the still air range.
The reason that airlines can use an aircraft like the 787 to start up longer, thinner routes is the 20% savings in operating costs over 767s of the same size (and even greater savings over the heavier A330). It is not so much an issue of capacity but of actual operating cost, especially considering the 787 will not cost much more than a 767
757s are incredibly efficient aircraft. They are significantly lighter than either 767s or A332s and are thus able to serve these smaller markets at a much lower risk.
ikramerica
Fri Oct 07, 2005 12:11 pm
And the 767 just can't make it from JFK, ATL, DFW, LAX, ORD, etc. 762 from some northern cities, but flying a 762 to it's limit on NRT when you have other routes to send it on, well it doesn't make a lot of sense. But, as I said, if the 788 takes over 762 routes to south america and europe, for example, you might see an airline like CO using it on a non-cargo route similar to how they deal with the 757. But as N1 says, the 767 is designed to carry cargo, so taking it on a route without it would really hurt the economics.
N1120A
Fri Oct 07, 2005 3:52 pm
Quoting Ikramerica (Reply 7):
The 763ER can make LAX-NRT rather easily, but why put such a small plane on such a high traffic route?
What most people don't understand about the 767 is that, yes it has the disadvantage of not being able to hold side by side LD3s all the way back, but it still can carry WAY more cargo, and WAY heavier cargo than a 757 ever could. There is a reason that when CO took the 777 off of MAN they didn't switch to 2 752s, rather they went with 1 752 and 762ER. It is cargo.
Fly2CHC
Fri Oct 07, 2005 4:05 pm
Are these figures correct? Great Circle Mapper has a range from SIN-LHR of 5879nm, and I am sure a B767 could not make that non-stop. The B742 never even did that route without an intermediary.
N1120A
Fri Oct 07, 2005 4:10 pm
Quoting Fly2CHC (Reply 9):
Actually, I do believe that the 747-200B did make the non-stop in later times. The 763ER could do the route, though only just barely.
FinnWings
Fri Oct 07, 2005 5:13 pm
A few words about ranges... One should consider that there are very many variables when considering of the range. Usually the range data of particular aircraft includes of course full tanks during take-off and only minimum legal reserve fuel at the time of landing. However in a real life you must add a lot extra, like fuel for the planned alternate airport and perhaps to the secondary alternate as well. This will decrease your real range a lot, depending of course how far away those alternates are. Those fuel calculations to alternate of course include one missed approach from your destination airport too and such a maneuver will burn tons of fuel.
Now you must also consider winds... manufacturers suppose zero winds when they announce maximum ranges. However, like we all know winds aren't ever zero in the upper airspace, in fact, you might easily have 150kts headwind for a whole trip. Then there is the age of the aircraft... just like with your car the manufacturer has promised that brand new aircraft (or car) will achieve those performance figures. However, as aircrafts gets older their fuel consumption increase, due the aging engines, increased drag due the stressed airframe etc... Every airline does have a performance office which makes necessary calculations for each individual aircraft on a regular basis, which almost always means that they are decreasing the performance of the aircraft from original values. The manuals and data will be of course updated to match with reality.
When considering all these and some other variable factors the usable economical range of a long haul aircraft might be even 1000nm less than the revealed maximum range by manufacturer. So be always very cautious when considering of the range...
I hope this helps!
Best Regards,
FinnWings
