cloudyapple
Stansted To Redesignate In December
Sat Oct 08, 2005 2:21 am
It will be 04/22 from Airac 0513.
A310/A319/20/21/A332/3/A343/6/A388/B732/5/7/8/B742/S/4/B752/B763/B772/3/W/E145/J41/MD11/83/90
IanatSTN
RE: Stansted To Redesignate In December
Sat Oct 08, 2005 6:06 am
Any body have any idea why the runway is being reassigned? Anything to do with future expansion?
Ian.
Ian@STN ::
noelg
Sat Oct 08, 2005 6:37 am
They redesignate runways every now and then as the magnetic heading changes over time. A while back LHR had 28/10 before they went down to 27/09.
Are any other airports due to change at the same time?
Noel.
mhodgson
Sat Oct 08, 2005 6:57 am
I believe MAN is to redesignate soon; the date hasn't been announced yet. Presumably it will go to 05/23
IanatSTN
Sat Oct 08, 2005 5:34 pm
Thanks for the info Noel, does anyone know how long STN has been 05/23 and if it was ever designated anything else?
Ian.
Ian@STN ::
GAWZU
Sat Oct 08, 2005 5:47 pm
Interesting news... 04/22 sounds even worse for photography than 05/23!
Quoting IanatSTN (Reply 4):
Ian, as far as I'm aware the main runway at STN has never been anything other than 05/23. The two other wartime runways were 12/30 and 18/36 but these are obviously long, long gone! That said, the remainder of 12/30 forms the main taxiway into the stands on the northside. And a chunk of 18/36 still exists where it intersected the northerly end of 12/30 over at the northside.
Hope this helps,
Adam
www.adamrowden.co.uk
BHXFAOTIPYYC
Sat Oct 08, 2005 6:26 pm
Quoting NoelG (Reply 2):
I never knew this... but how does it change? North is still north, and everything else is still in it's relative position.
Breakfast in BHX, lunch in FAO, dinner in TIP, baggage in YYC.
boysteve
Sat Oct 08, 2005 7:02 pm
Quoting BHXFAOTIPYYC (Reply 6):
It is a little confusing, if you followed magnetic north on a compass you wouldn't actually end up at the north pole, just somewhere nearby, and where you end up would change over time, but only slightly.
What may of happened recently is that Earth's magnetic field has moved by half of 1 degree but if that turns a runway heading from 244.5 degrees to 245.0 degrees then it will redesignate its runway from 24 to 25. Obviously this will only affect very few airports as a change from, say 240.5 to 241.0 degrees will not change the designation 24.
What is even more alarming is every so many hundred thousand years or so the magnetic poles flip over, meaning a compass would point South!
BHXFAOTIPYYC
Sat Oct 08, 2005 7:16 pm
Thanks Boysteve. Good explanation.
Consider yourself promoted to Mansteve.
