CO737800
CO To Put The 733 On The YVR Run
Sat Oct 22, 2005 3:02 pm
It looks like CO will be putting the 737-300 on the YVR route. I thought the 737-300/700 had about the same pax load, if so why would they do this. I love the 700 and will miss the tv's for the 4.5hour flight. My wife was on a CO 733 and told me no tv's and found it boring.
optionscle
RE: CO To Put The 733 On The YVR Run
Sat Oct 22, 2005 3:35 pm
Some of the CO 733's do have TV's and I'd imagine that they would be the ones to fly this route. CO has 735's on the IAH-YYC route, that seems like a long way to go without any IFE, but then again, NW doesn't have IFE on any of it's international A320 flights and I didn't find MSP-YVR that bad.
Islandboy
You didn't specify from where their putting it on. I don't think the 733's have the range for EWR-->YVR so its either IAH or CLE. The B73G might be needed for its range elsewhere in the system.
Looks like the fresh wind has gone stale
CO737800
Sat Oct 22, 2005 3:39 pm
They have already put them on the Vancouver-Houston run, so they must have the range
Islandboy
Sat Oct 22, 2005 3:43 pm
Quoting CO737800 (Reply 3):
Yes for IAH-->YVR.
But you never specified from where. You simply said they changed your flight from a B73G to a B733. So i said the B733 doesn't have the range for EWR->YVR nonstop. SO it must be originating in IAH (Houston) or CLE (Cleveland).
N1120A
Sat Oct 22, 2005 3:44 pm
YVR-IAH is 399nm/about 500 sm shorter than YVR-EWR, so range could factor in here. Still, 2111 nm is doable for the 733 on most days, particularly considering neither YVR or EWR is particularly high up or hot (EWR can get hot in the summer, but this isn't the summer, now is it?)
CO737800
Sat Oct 22, 2005 3:59 pm
They have had the 733 on the route all summer long. In the summer they have a 2 flights a day to Houston from YVR.They had the 8am flight as a 733 and the noon flight as 73G
N1120A
Sat Oct 22, 2005 4:19 pm
Quoting CO737800 (Reply 6):
YVR-IAH should not be a problem anyway.
