tripple7
MD-11 Open Hatch At Take Off Question
Tue Oct 25, 2005 5:06 am
Looking at this picture, it seems that a hatch (just in front of the engine) on the KLM MD-11 is still open.
Photo © Steven Filipowicz
Where is this hatch used for. And can it do any harm when it is open when the aircraft takes off?
dtwclipper
RE: MD-11 Open Hatch At Take Off Question
Tue Oct 25, 2005 5:08 am
This has been talked about before. I believe if you do a search on it, you will find a lot of answers.
Look under the DC-10 topics.
Compare New York Air, the Airline that works for your Business
cbphoto
Tue Oct 25, 2005 5:09 am
This should be a Tech-Ops question, but I believe it has something to do with the Cabin Pressurization system. I think it the door that allows the bleed cabin pressure out. But I might be mistaken!
ETOPS: Engines Turning or Passengers Swimming
HS748
Tue Oct 25, 2005 5:24 am
I think it's the pressurisation outflow valve. It closes as the aircraft pressurises during the climb and opens as it depressurises during descent. You can see it on most aircraft types.
airfoilsguy
Tue Oct 25, 2005 10:06 am
I would not worry about that hatch.
Photo © JetPix
This hatch on the other hand may cause a problem  Smile
It's not a near miss it's a near hit!!
Cadet57
Tue Oct 25, 2005 10:09 am
Quoting Airfoilsguy (Reply 4):
Ive seen that picture dozens of times. Whats the story behind that?
airfoilsguy
Tue Oct 25, 2005 10:47 am
Quoting Cadet57 (Reply 5):
Hatch opened up during takeoff from Miami. Plane turned around and landed safely. Not sure why the hatch opened though
WestWing
Tue Oct 25, 2005 11:24 am
Look at What's This Little Door On The DC-10? (by Starlionblue May 2 2005 in Tech Ops) .
The best time to plant a tree is 40 years ago. The second best time is today.
LongbowPilot
Tue Oct 25, 2005 2:18 pm
Lets not forget all the luggage you can find on tops of buildings throughout ORD, ATL, DFW, JFK due to open luggage bins.
Tue Oct 25, 2005 5:45 pm
Main Outflow Valve.
How did the Door get Pressurised Hydraulically to Open.Any link.
regds
MEL
sfilipowicz
Tue Oct 25, 2005 10:56 pm
Once I remember an aircraft taking off from AMS with the doorsteps still attached to the aircraft!! It was long ago but I still remember seeing the pictures on tv.
airfoilsguy
Wed Oct 26, 2005 7:54 am
Quoting LongbowPilot (Reply 8):
Are you serious?  Wow!
airfoilsguy
Wed Oct 26, 2005 7:57 am
