prosa
Wilma's Effects At PBI - Picture
Wed Oct 26, 2005 11:06 pm
Quite an image, courtesy of the Weather Underground:
http://www.wunderground.com/wximage/...e&handle=HistoricEvidence&number=6
"Let me think about it" = the coward's way of saying "no"
HAJFlyer
RE: Wilma's Effects At PBI - Picture
Wed Oct 26, 2005 11:18 pm
Quoting PROSA (Thread starter):
Quite an image
 rotfl
Seems like that L 1011 wanted to get intimate with the shed. How inappropriate.  Wink
7LBAC111
Wed Oct 26, 2005 11:19 pm
This is another amazing shot of it!
:D
7LBAC111
Debate is what you put on de hook when you want to catch de fish.
PhilSquares
Wed Oct 26, 2005 11:26 pm
Quoting HAJFlyer (Reply 1):
Only problem is it's a 727-100.
Fly fast, live slow
ACYWG
Thu Oct 27, 2005 12:14 am
Quoting PhilSquares (Reply 3):
Yeah, definitely a 727, but we'll give him the benefit of the doubt, it looks like a L1011 if you minus the eyebrows
FLAIRPORT
Thu Oct 27, 2005 12:16 am
definently looks like a small corperate plane.
NEXT FLIGHT: FLL-ATL-HPN on FL
lamedianaranja
Thu Oct 27, 2005 12:34 am
Quoting 7LBAC111 (Reply 2):
Happens to be my first name too... I got a lot of jokes about it.
I wish that all skies were orange and blue!!
CruzinAltitude
Thu Oct 27, 2005 12:38 am
Hope someone didn't forget to set the parking brakes! They would be getting a pink slip effective immediately!
Cadet57
Thu Oct 27, 2005 1:07 am
Anyone know if the A/C is written off? Sad to see another 727 gone...
tjwgrr
Thu Oct 27, 2005 1:12 am
Quoting CruzinAltitude (Reply 7):
What idiots would leave a 727 at an airport in the path of a Cat II or Cat III hurricane? Should have been ferried out somewhere..........
Direct KNOBS, maintain 2700' until established on the localizer, cleared ILS runway 26 left approach.
mika
Thu Oct 27, 2005 1:32 am
Quoting ACYWG (Reply 4):
And minus the fuselage mounted engines 1 and 3.
PipoA380
Thu Oct 27, 2005 1:42 am
What about the fence? Strange the building seems to have been "bent" by the airplane, but the fence still stands! I knew buildings in america were usually very weak, but I didn't know fences were so solid!  Wink
It's not about AIRBUS. it's not about BOEING. It's all about the beauty of FLYING.
A340Spotter
Thu Oct 27, 2005 5:03 am
Think that is N720DC, the former Dick Clark Productions 727-100, if I have my color schemes right. Been parked near the Galaxy hangars for a couple of years...
Photo © Pier Picone
Jeffrey
"Irregardless, it's a Cat III airplane, we don't need an alternate!"
MiCorazonAzul
Thu Oct 27, 2005 5:25 am
That plane is ALWAYS parked in the same spot at the airport. Every time I drive by, I see it in the exact location. Looks like it FINALLY got moved....HAHA.....
Live for Today.....tomorrow is NOT guaranteed.
DLKAPA
Thu Oct 27, 2005 5:29 am
Quoting FLAIRPORT (Reply 5):
I think if you look very closely you'll notice it's a Baron.
aloges
Thu Oct 27, 2005 5:37 am
Quoting PipoA380 (Reply 11):
Easy one: The building was hit by the fuselage, the fence was hit by the radome. The radome doesn't exactly need to be as strong as the fuselage.
zippyjet
Thu Oct 27, 2005 5:54 am
Momma said there'd be days like this!  hissyfit
I'm Zippyjet & I approve of this message!
jetdeltamsy
Thu Oct 27, 2005 11:05 am
Might be a -200. How can you tell?
Tired of airline bankruptcies....EA/PA/TW and finally DL.
jeffry747
Thu Oct 27, 2005 11:23 am
Quoting Jetdeltamsy (Reply 17):
All 727-100 models (minus those modified with RR engines for UPS) have oval shaped intakes for the #2 engine. All -200s had circular shaped intakes. This is unmistakably a -100.
C'mon Big B, FLY!
ikramerica
Thu Oct 27, 2005 11:36 am
what a stupid statement. especially the usually part.
I've been to switzerland, and you have a lot of sheds and shacks there, guy. they are called "rustic" and "quaint" and "charming."
you just don't get hurricanes with 145 mile an hour gusts blowing airplanes into them. If you stuck a swiss chalet in front of a 727 rolling at it, it would be flattened.
Fact is, it's just more practical to build "out buildings" like in the picture to a lower standard, since it would be cheaper to repair it once in a while than building it to Cat 5 standards. It's also easier to move the structure later when not made of concrete or heavy steel.
The fence, on the other hand, is meant to protect the airport perimeter and should be strong. It should withstand bumps by airplanes and ramming by trucks and such. Obviously, it can be knocked down, but a composite nose cone of a jet shouldn't do it.
Thus the result you see. All by design, my friend. All by design...
jetdeltamsy
Thu Oct 27, 2005 11:44 am
Quoting Jeffry747 (Reply 18):
Now I know. Thank you.
My nephew loads ULD containers for UPS @ DEC.
Peace.
dl757md
Thu Oct 27, 2005 12:37 pm
Parking brakes are only effective for around 8 hours after hydraulic system pressure is removed. The parking brake accumulator supplies pressure during this time but because of normal internal leakage in the system it loses it's pressure after about 8 hrs. So if the plane had been left for more than 8 hours it had no parking brakes even if the parking brake lever had been left in the set position.
DL757Md
N243NW
Thu Oct 27, 2005 1:31 pm
You learn something new every day! Thanks for sharing this with us.
-N243NW bigthumbsup
cgagn
Thu Oct 27, 2005 2:36 pm
..or in this case, you learn two new things everyday. I didn't know the parking brake lost its effectiveness after 8 hours of no hydraulic pressure. Guess those chalks are more important that I thought.
C-GAGN
Widebodies flown on:A330-300,A340-300,A380-800,747-400,767-200ER,767-300ER,777-200A,777-200ER,777-200LR,777-300ER,787-9
ukkiwibird
Thu Oct 27, 2005 2:51 pm
Just found these on the web.
All i can say is ,that was some mighty wind to be able to shift that plane to that angle.
http://www.thesun.co.uk/article/0,,2-2005490732,00.html
miamix707
Thu Oct 27, 2005 3:11 pm
Quoting A340Spotter (Reply 12):
It has, when i saw it a few years ago it was on the other side of the field, I thought it was an Ariana Afghan 727 at first sight!
..your color schemes right? So you're able to recognize every private aircraft's paintschemes??    That's just scary.
geez, talk about a "weak" joke...
[Edited 2005-10-27 08:12:21]
haj96
Thu Oct 27, 2005 4:28 pm
Quoting DLKAPA (Reply 14):
Never ever!! It´s definately a Cessna 172  biggrin
haj96
JeffSFO
Thu Oct 27, 2005 5:44 pm
Quoting Tjwgrr (Reply 9):
The USAF.
When my father was stationed at Homestead back in the 60s, they had the KC-135s powered up on the ramp and facing into the wind. I'll have to ask him about the exact details, but it's not unheard of.
Anyone have any current info on USAF hurricane procedures?
-Jeff
PipoA380
Thu Oct 27, 2005 8:09 pm
Quoting Ikramerica (Reply 19):
I hope you didn't only see chalets. We have other buildings too  Wink
It was a joke mate!  Silly
WDBRR
Thu Oct 27, 2005 8:10 pm
It reminded me of after hurricane Andrew in 1992, there was an
abandoned Braniff III plane (red?) left at MIA and the front landing
gear collapsed, I think this was shortly after their third shutdown,
saw pictures of it....anyone have a copy?
BR715-A1-30
Thu Oct 27, 2005 8:33 pm
Quoting Zippyjet (Reply 16):
There'd be days like this Momma said...  Wink
Quoting Dl757md (Reply 21):
Wow, I never knew that.
Quoting N243NW (Reply 22):
Here Here
Puhdiddle
N323ER
Thu Oct 27, 2005 11:25 pm
Most of the planes that were left and damaged where in line for the chop shop more thank likely. For those that weren't have not flown for a while might have had expired airwortheness cert
RYAN
RIACREW
RYAN SCAIFE
AnMCOSon
Fri Oct 28, 2005 10:59 am
Quoting BR715-A1-30 (Reply 30):
Quoting Zippyjet,reply=16:
Yeah, thank's alot, I read this topic this morning, seen your post's, and had that song playing in my head all day....
It drove me nut's.... banghead  Silly
What the? Did everything just jump around? Or did my brain just stroke off there for a second?
