Sabena332
Amsterdam IATA Code Question
Thu Oct 27, 2005 7:37 am
Hi all,
I know the the airport of Amsterdam has the three-letter IATA code "AMS". I remember also that I saw in a timetable of an airline - which I can not remember anymore - that they used the code "SPL".
Is SPL a valid code for Amsterdam? If yes, why has it two IATA codes? Is there any difference when I use the AMS code instead of the SPL code or vv.?
Patrick
coolsan
RE: Amsterdam Iata Code Question
Thu Oct 27, 2005 8:11 am
From what I was able to look up, the valid IATA code is AMS, and SPL is the vor/dme id. at Schiphol. Maybe someone can add some more technical input..
Santiago.
"This is the life we chose, the life we lead. And there is only one guarantee: none of us will see heaven"
AMS
Thu Oct 27, 2005 9:49 am
Although AMS is the official code for Amsterdam, Schiphol Netherlands, some airlines sometimes may use SPL as for example Royal Jordanian used to do on their Flights JFK-AMS-AMM (AMMAN, Jordan) as AMS and AMM would be very similar and sometimes confused by Baggage staff. Also many airline companies at AMS use SPL as an address as SPL stands for Schiphol Airport.
AMS
BOEING787
Thu Oct 27, 2005 3:55 pm
From AMADEUS:
Apparently SPL is Schiopl Railway station!
DAC SPL
A:APT B:BUS C:CITY G:GRD H:HELI O:OFF-PT R:RAIL S:ASSOC TOWN
CITY :
AMS*C AMSTERDAM /NL:NETHERLANDS
RAIL-BUS STATION :
SPL R SCHIPHOL RAIL STATION /NL - 0K
Mir
Thu Oct 27, 2005 4:06 pm
Quoting Coolsan (Reply 1):
That is correct, but the IATA has no use for VOR codes, so it looks like it's the train station, as BOEING787 said.
-Mir
jwenting
Thu Oct 27, 2005 6:21 pm
I've seen many airlines use SPL instead of AMS.
Garuda does it as well, and not just on passenger documentation.
When I worked for them for a few months writing software they wanted SPL to be used instead of AMS everywhere, including official IATA documents (airway bills for example).
Officially AMS means the city and all its airports I understood, SPL the specific airport.
Of course there's only one airport (so no opportunity for confusion) and many people find AMS easier to understand because they're flying to Amsterdam so many companies use AMS.
I wish I were flying
Sabena332
Fri Oct 28, 2005 1:02 am
Thanks for the replies!
So it seems that there is no difference between the AMS and the SPL code. Maybe they reserved the SPL code in advance in case that Amsterdam will get a second airport in the future?
Patrick
HT
Fri Oct 28, 2005 1:55 am
Quoting BOEING787 (Reply 3):
According to www.airlinecodes.co.uk the IATA-code for the rail station is ZYA.
My database of IATA-codes (but I can´t remember where I downloaded the list from years ago) lists both AMS and SPL for Amsterdam Schiphol.
-HT
petertenthije
Fri Oct 28, 2005 3:26 am
I was once explained a long time ago that SPL stands for Schiphol, and AMS for Amstelveen (near Amsterdam). Don't know if it is true though. Because Schiphol is closer to Amstelveen then it is to Amsterdam the AMS code stuck.
Attamottamotta!
Yazoo
Fri Oct 28, 2005 3:38 am
Same applies for the country, some refer to it as "The Netherlands" while other as "Holland".
... and to add more confusion, the inhabitants are called "Dutch". Don't know how they came up with that one...
Purple Pride!
LJ
Fri Oct 28, 2005 4:28 am
Quoting Sabena332 (Reply 6):
Officially there are already two airports in Amsterdam. The first is called "Schiphol" and the second is called "Schiphol-Oost" (Schiphol-East)
AMSSpotter
Fri Oct 28, 2005 5:47 am
Quoting Yazoo (Reply 9):
Don't know either. My guess is that it has been derived from the word "Diets". The Dutch language in medieval times was called Diets or "Middel-Nederlands" (Middle-Netherlands). But that's just my guess.
lijnden
Fri Oct 28, 2005 9:00 am
SPL: Old Schiphol East from the old days. Schip's hol (ship hole) was the corner that is now Schiphol east where many ships wents down due to strange currents.
AMS: Current main airport that was build as Schiphol Centrum in the late 60's
Be kind to animals! Next trip: ORF-ORD-NRT-IAD-ORF
HT
Fri Oct 28, 2005 1:53 pm
Quoting LJ (Reply 10):
Quoting Lijnden (Reply 12):
I first was tempted to believe that "Amsterdam Oost" would be "Lelystad" in FR-terminology !
Wasn´t is "Hell" instead of "hole" ?
First of all, we have to take into account how the country is called in the native language !
Apart from that, there are a number of other names like:
- Holland
- The Netherlands
- Les Pay-Bas
- Die Niederlande (but more frequently "Holland" is used in German language, though this has a slight negative historical background, and therefore I don´t use that term out of respect for the The Netherland´s people - just a bit of political correctness).
IIRC, it derives from the french occupation several hundred years ago, that the term "Les Pays-bas" (--> "The lowlands") was coined, which afterwards was translated into the other languages. IIRC further, "Les Pay-Bas" were in contrast to those lands at slightly higher elevation to the south which is now the part "Valonie" (spelling ?) of Belgium (wasn´t "Flandres" originally also part of what the French called "The pays-Bas" by then) ?
So much for some history lessons for now ... Big grin
-HT
petertenthije
Fri Oct 28, 2005 2:29 pm
Quoting HT (Reply 13):
Correct, however the name Pays-Bas was typically translated as the Low Lands which is the name for NL and Flanders. The Netherlands are just NL and assorted colonies (you know, those tiny mudholes in the carribean).
Attamottamotta!
OH-LGA
Fri Oct 28, 2005 2:39 pm
IATA's Code Identifer Demo at their website defines SPL as the following:
http://www.iata.org/ps/publications/codes/demo.htm
Location ID SPL
City Schiphol
Location Name Off-line Pt
Country Netherlands
Country Code NL
I'm personally not sure what to make of it, other than it doesn't define Amsterdam/Schipol airport (which AMS does).
Kai
Head in the clouds... yet feet planted firmly on the ground.
JGPH1A
Fri Oct 28, 2005 3:54 pm
Quoting Jwenting (Reply 5):
There is a difference. SPL refers to the Railway Station at Schiphol. AMS is both the city code for the city of Amsterdam, and the airport code for Schiphol Airport - there are a lot of codes that refer to both city and airport, e.g.
CITY :
HKG*C HONG KONG /HK:HONG KONG -SAR OF CHINA-
AIRPORT-HELIPORT :
HKG A HONG KONG INTL /HK - 0K
HHP H H K HELIPORT /HK - 0K
CITY :
JNB*C JOHANNESBURG /ZA:SOUTH AFRICA
AIRPORT-HELIPORT :
GCJ A GRAND CENTRAL /ZA - 0K
JNB A JOHANNESBURG /ZA - 0K
QRA A RANDGERMISTON /ZA - 0K
HCS H RANDBURG HPT /ZA - 0K
CITY :
DEN*C DENVER /USCO:COLORADO
AIRPORT-HELIPORT :
APA A ARAPAHOE CO /USCO - 0K
BFK A BUCKLEY ANGB /USCO - 0K
DEN A DENVER INTL /USCO - 0K
CITY :
AIRPORT-HELIPORT :
AMS A SCHIPHOL /NL - 0K
RAIL-BUS STATION :
ZYA R AMSTERDAM RAILWAY /NL - 0K
CITY :
LAX*C LOS ANGELES /USCA:CALIFORNIA
AIRPORT-HELIPORT :
JCX A CITICORP /USCA - 0K
LAX A LOS ANGELES INTL /USCA - 0K
VNY A VAN NUYS /USCA - 0K
WHP A WHITEMAN /USCA - 0K
CCD H CENTURY CITY /USCA - 0K
JID H CTY IND HPT /USCA - 0K
JSN H SHE OAKS HPT /USCA - 0K
JLX H UNION STN HP /USCA - 0K
JUC H UNIV HPT /USCA - 0K
RAIL-BUS STATION :
JBP B COMMERCE BUS /USCA - 0K
JWC B WARNER BUS /USCA - 0K
Young and beautiful and thin and gorgeous AND BANNED ! Cya at airspaceonline.com, losers
A319114
Fri Oct 28, 2005 4:37 pm
Officialy 'our' country is called 'The Netherlands'. Holland only applies to North- and South-Holland (the provinces), though you're right it is sometimes used as a name for the entire of The Netherlands.
And indeed, Belgium used to be part of the Netherlands as well untill in 1830 they decided to start their own little country  Smile
Destruction leads to a very rough road but it also breeds creation
