swissgabe
SU Service Into LAD, More Than 24h Ground Time?
Fri Nov 04, 2005 7:19 am
I noticed, that the Aeroflot service into LAD which flies every second week has a quite long ground time at Luanda.
Schedule as follows:
...4... SVO LAD 1405 2135 SU 345 IL6
....5.. LAD SVO 2235|1200 SU 346 IL6
Do they operate charter flights in between or what does the SU Aircraft do at LAD for more than 24 hrs?
Smooth as silk - Royal Orchid Service /// Suid-Afrikaanse Lugdiens - Springbok
Sabena332
RE: SU Service Into LAD, More Than 24h Ground Time?
Fri Nov 04, 2005 7:28 am
A few weeks ago I posted data from an old Interflug timetable here on A.net and I noticed that IF used to have pretty long ground times on a few of their flights as well, for example:
SXF dep. 20:40
KHI arr. 07:35 (+1)
KHI dep. 08:45 (+1)
HAN arr. 15:55 (+1)
HAN dep 10:00 (+2)
KHI arr. 13:45 (+2)
KHI dep. 14:45 (+2)
SXF arr. 21:40 (+2)
Ground time in HAN from 15:55 until 10:00 on the next day.
SXP dep. 18:30
SVO arr. 23:00
SVO dep. 00:01 (+1)
PEK arr. 12:05 (+1)
PEK dep. 05:30 (+2)
SVO arr. 10:00 (+2)
SVO dep. 11:00 (+2)
SXF arr. 11:20 (+2)
Ground time in PEK from 12:05 until 05:30 on the next day.
Patrick
swissgabe
Fri Nov 04, 2005 7:31 am
Where those flights also operated by IL6 aircrafts?
MAH4546
It has to be there for such a long time. Aeroflot's Moscow-Luanada service operates fortnightly (every other week), so the plane has to park for 24 hours for the crew can rest. The same crew who flies SVO-LAD flies LAD-SVO the next day.
a.
Sabena332
Fri Nov 04, 2005 7:33 am
Quoting Swissgabe (Thread starter):
I just thought of this: Maybe the same crew is flying the plane back to SVO since they only have service into LAD every second week? I can imagine that it is quite pricey for SU to let a complate IL6 crew stay in a hotel in Luanda for two weeks. I think that the crew must get a compulsory rest of ~24 hours before they can operate the return flight.
Patrick
Sabena332
Fri Nov 04, 2005 7:34 am
Quoting Swissgabe (Reply 2):
Yes, those were also IL6 flights.
Quoting MAH4546 (Reply 3):
You was two minutes faster than me.
Patrick
[Edited 2005-11-03 23:37:00]
swissgabe
Fri Nov 04, 2005 7:53 am
I should have thought of that. Thanks a lot ...
Just btw: The lowest fare available seems to be an AP Fare (restricted) from SVO to LAD and return which is 1000 USD. What is traffic like on this sector, are there a lot of Russian oil companies in Angola?
LH459
Fri Nov 04, 2005 10:47 am
Quoting Swissgabe (Reply 6):
These flights seem to be full most of the time. For instance:
24NOV THU SVO/Z‡3 LAD/-2
SU RESPONSE ** DIRECT CONNECT PARTICIPANT **
7SU 345 J3 C3 D0 Y0 S0 B0 M0 H0 K0*SVOLAD 1405 2235 IL6
X0 V0 T0 Q0 W0 L0
and the return:
25NOV FRI LAD/Z‡1 SVO/‡2
7SU 346 J0 C0 D0 Y0 S0 B0 M0 H0*LADSVO 2359 1225‡1 IL6
K0 X0 V0 T0 Q0 W0 L0
swissgabe
Fri Nov 04, 2005 3:43 pm
Well, not full but well booked I would say. Not even the lowest class is closed.
