scbriml
Airbus Launches A318 Elite
Fri Nov 11, 2005 3:23 am
Airbus announces a new bizjet, the A318 Elite!
http://www.airbus.com/en/presscentre...ses_items/11_10_05_A318_Elite.html
A Swiss company called Comlux has become the launch customer for Airbus latest bizjet, the A318 Elite. The company has ordered 3 A318 Elites and 1 A319CJ in a deal signed today.
http://www.airbus.com/en/presscentre...ems/11_10_05_A318Elite_Comlux.html
123
RE: Airbus Launches A318 Elite
Fri Nov 11, 2005 4:00 am
Doubtlessly with Airbus entering the business aircraft segment with their smallest jet, is a huge threat to Dassault's largest aircraft segment.
It' s also about time Dassault thinks about reentering the commercial aviation segment.
skibum9
Fri Nov 11, 2005 4:27 am
Quoting 123 (Reply 1):
I am not sure that is necessarily true. The operating costs will still probably be much higher, given the A318s size and weight, when compared to Dassault.
Tailwinds!!!
123
Fri Nov 11, 2005 6:02 am
Quoting Skibum9 (Reply 2):
Yes... and no. Dassault 3-engines should cost more in maintenance. I´m sure one of our a-netters can give us more details. Let´s wait for feedback!
A342
Fri Nov 11, 2005 6:08 am
Not really. The A318 is just trice as big as the Falcon 7X.
Quoting 123 (Reply 3):
Again, the engines are more than trice as big on the A318.
You mean airliners ? Not very likely. A cooperation with EADS on military projects has started, so this could continue into airliners. But 2 big manufacturers are enough for the market, and Dassault would nearly have to start at zero (customer relations, maintenance etc.).
Exceptions confirm the rule.
Tornado82
Fri Nov 11, 2005 6:11 am
The maintenance price for one extra engine would be nowhere near the fuel prices for 3x the plane.
Rj111
Fri Nov 11, 2005 6:26 am
To put it beyond any doubt, wouldn't the Dassult, with three smaller engines, avoid Etops unlike the A318?
And any idea of the max range of the A318E? I assume it retains the extra fuel tank options, like the A319CJ.
md90fan
Fri Nov 11, 2005 11:25 am
Quoting Rj111 (Reply 6):
In the PR it sad 4000nm allowing NYC-LON flights to be done  Smile
http://www.devanwells.blogspot.com/
Boeing Nut
Fri Nov 11, 2005 11:39 am
Hardly. The 7X is a much more capable aircraft than the 318 Elite could ever dream of being. This is nothing more than a PR stunt. All that Comlux did was approach Airbus and showed interest in the A318 and they smacked the "Elite" to it and, Vwalla! an A318 Elite is born.
A350
Fri Nov 11, 2005 12:52 pm
Airbus ...can now offer an even more affordable alternative for customers that are happy with a shorter cabin and less range
Why less range? Normally it should have more range? Or did Airbus fit extra-weak engines?
A350
LawnDart
Fri Nov 11, 2005 3:32 pm
Yes, their last venture into the commercial market was such a resounding success...
FCKC
Fri Nov 11, 2005 6:29 pm
123
I do not think Dassault will go Airliners.They still remember the Mercure story.......
They are still studying a supersonic biz jet.
Also rumoured is they'll perhaps enter again the mid size biz jet market , with a plane comparable in size with the Falcon20.Will see.......
A319XFW
Fri Nov 11, 2005 7:41 pm
The ACT's won't fit into the A318, as the cargo door is smaller..... The range should be slightly higer than a normal A318, as the payload it has to carry is less.
speedbird128
Fri Nov 11, 2005 7:48 pm
Are bizjets bound to ETOPS rules??
A306, A313, A319, A320, A321, A332, A343, A345, A346 A388, AC90, B06, B722, B732, B733, B735, B738, B744, B762, B772, B7
airforum
Sat Nov 12, 2005 12:57 am
Quoting Speedbird128 (Reply 13):
And how about Charles Lindenbergh? Did he avoid ETOPS when flying the Spirit of St. Louis?
 innocent
What goes up, must come down. Let's hope the sky never went up.
HiJazzey
Sat Nov 12, 2005 1:57 am
The press release makes a mention of "A320 prestige". I've never heard of it. Is there a larger corporate jet than the A319CJ?
Mir
Sat Nov 12, 2005 1:59 am
The A318 is in an entirely different class from the Falcons. The Falcons are going to outperform the 318, and be cheaper to operate while doing it.
But if you've got 20 executives you want to haul around in the lap of luxury, a Falcon's not going to do it. That's where the market for the 318CJ (and 319CJ and BBJ) is.
-Mir
BlueSky1976
Sat Nov 12, 2005 2:54 am
Quoting Boeing nut (Reply 8):
I wonder if you'd be saying the same words if Comlux wanted Boeing to make a 737-600 into BBJ3... It's not like only Boeing listens to their customers.
...btw it's spelled VOILA
POLAND IS UNDER DICTATORSHIP OF JAROSŁAW KACZYŃSKI AND HIS PUPPET GOVERNMENT. DEMOCRACY SHALL PREVAIL.
N1120A
Sat Nov 12, 2005 3:03 am
Except of course the the Falcon's engines are much simpler and smaller, making maintenance cheaper
General Aviation aircraft are not subject to ETOPS rules
Quoting A350 (Reply 9):
The A318 is too small to fit the extra fuel tanks that an ACJ or BBJ can have, so it can't add as much range.
A319XFW
Sat Nov 12, 2005 3:53 am
Quoting HiJazzey (Reply 15):
If somebody with enough money wants an A320 with a luxury cabin, I'm sure Airbus won't say "No"
I guess this would be an A320 Prestige..
http://www.airliners.net/open.file/931956/M/
skibum9
Sat Nov 12, 2005 8:25 am
Quoting Airforum (Reply 14):
ETOPS doesn;t cover the Spirit of St. Louis. ETOPS is for TWINS, the St. Louis was a single engine. They would need to come up with ESOPS to cover that.
Tailwinds!!!
KELPkid
Sat Nov 12, 2005 9:23 am
Nope. Part 91 (business) of the FARs, unless chartered, then part 135 rules apply. (Of course, I only know the U.S. regs...your mileage may vary).
There are rules on over water survival gear and flotation devices, depending on how many pax are on board.
milan320
Sat Nov 12, 2005 10:22 pm
Quoting KELPkid (Reply 21):
According to Wikipedia:
Private jets are exempted from ETOPS by the FAA, but are subject to the ETOPS-120 minute rule in the JAA's jurisdiction. Several commercial airline routes are still off-limits to twinjets because of ETOPS regulations. They are routes traversing the South Pacific, Southern Indian Ocean such as Perth, Australia to Johannesburg, South Africa and Antarctica such as Auckland, New Zealand to Buenos Aires, Argentina.
-Milan320
I accept bribes ... :-)
