nosedive
COex Use Of Twin Otters In The 80s
Sat Nov 12, 2005 2:17 am
Photo © Brian Peters
Did COex use their twin otters on intra-Colorado routes?
[Edited 2005-11-11 18:18:39]
STT757
RE: COex Use Of Twin Otters In The 80s
Sat Nov 12, 2005 2:55 am
They also used twin Otters on flights to Atlantic City Bader Field, Bader field is the small close in airport used by General Aviation aircraft. It's runway is only 3,000ft long.
CO had a Connection partner in the Late Eighties flying from EWR and DCA to Bader Field with Twin Otters.
Photo © Robert Friedlander
Later they operated EWR-ACY (Atlantic City International) with ATR's.
nkops
Sat Nov 12, 2005 5:03 am
Quoting STT757 (Reply 1):
And then even later than that... they did ACY-CLE in the ERJ's.... and none of them worked!!! Actually, the twin otters were operated by Southern Jersey Airways out of Bader Field
:evil:
EMBQA
Sat Nov 12, 2005 6:57 am
You need to remember the Continental Express back then was nowhere near what it is today. Back then it was several independently operated airlines flying as a code share. Today you have one airline, ExpressJet a direct subsidiary of Continental flying as Continental Express. We have also recently added a few 'Connection' carriers to the mix....
FlyHoss
Sat Nov 12, 2005 1:45 pm
Quoting Nosedive (Thread starter):
Yes, and more.
After Rocky Mountain Airways (RMA) began receiving DHC-7s, the Twin Otters (DHC-6) was normally assigned to "Front Range" routes, such as:
DEN-COS
DEN-PUB
DEN-ALS
DEN-CYS
DEN-BFF
RMA was purchased by CO parent, Texas Air in 1986 (April, I think) and become part of Continental Express (along with Britt Airways and Bar Harbor).
A little bit louder now, a lil bit louder now...
uadc8contrail
Sat Nov 12, 2005 4:23 pm
flyhoss,
dont forget den-avon on the dh7 and t-otter
bus driver.......move that bus:)
FlyHoss
Sun Nov 13, 2005 12:20 am
Quoting Uadc8contrail (Reply 5):
flyhoss,
After the DHC-7s arrived, the Twin Otters saw limited service into the mountains, though I do recall some scheduled DHC-6 flights into SBS. After a few years, the city of Avon changed the zoning for the Avon STOLport that permitted only DHC-7s. So whenever the microwave approach system (TALAR, not the FAA style MLS) needed to be flight tested, RMA had to get approval for a temporary zoning variance to do the flight check if using a Twin Otter.
Also, IIRC, RMA operated DHC-6s to Leadville and Granby, though that was way before my time there.
