jasond
Fake Accident Pictures?
Mon Nov 14, 2005 10:24 am
I am sure all of these are fakes given what seems to be some Photoshop trickery at work. Comments welcome.
Interestingly one of them appears to have the remains of an ANet watermark that has been deliberately fudged out.
Cadet57
RE: Fake Accident Pictures?
Mon Nov 14, 2005 10:30 am
first one idk but it is a a.net photo, second is fake see www.snopes.com and also an a.net photo. and third idk either.
pilotdude09
Mon Nov 14, 2005 10:31 am
The AA one looks quite real, but who knows
cheers
Qantas, Still calling Australia Home.........
OPNLguy
Mon Nov 14, 2005 10:32 am
1/ The fact that the photographer's name has partially been erased flags this one as a fake, not to mention we'd have read about it the incident.
2/ Widely discussed here on a.net as a hoax, and identifiable as such due to the "fire" not showing up in the reflection of the same engine on the fuselage.
3/ I thought that one was real, based upon what I recall was the photo's listing here on A.net, but after looking at this one, it almost looks like the one in the original post could have been taken a second or two after this one....
Photo © Michael Arcellana
I don't use Photoshop, and am thus no expert on it, so I'll defer to those that are...
[Edited 2005-11-14 02:48:11]
jasond
Mon Nov 14, 2005 10:37 am
I am unsure about the third one. The second seems to be 'confirmed' as a fake. The only things that lead me to believe the first is a fake is that there appears to be no evidence of gear compression on the starboard side and the fact that the 'smoke' etc looks to layered over the top.
flypdx
1 looks the most realistic of the three.
EMBQA
Mon Nov 14, 2005 10:38 am
Fake, Fake, Fake.....
JrMafia90
Mon Nov 14, 2005 11:12 am
Pretty bad editing. You can tell they are fake.
jasond
Mon Nov 14, 2005 11:29 am
Quoting OPNLguy (Reply 3):
I reckon the image you posted was what this 'fake' was based on. The position of the vertical tail is in the same position in relation to the buildings in the background. Given the speed of the aircraft at the time if it were two different pictures you would see some distance between the two I would have thought. Looks like a simple rotation done in Photpshop to me. For what it is worth I think all of these are fakes and as 'interesting' as they are, is there a place for them on ANet? I'm not sure. Incidently they were sent to me by a colleague who is a non aviation enthusiast. He thought they were real. Thankyou all for your comments.
Quoting JrMafia90 (Reply 7):
My sister uses Photoshop professionally and although she has no background in aviation at all she thought the work was very poor.
GEEZ
Mon Nov 14, 2005 11:33 am
All fake!
What kind of sad, lonely, pathetic, morbid, juvenile kind of twat would sit there and take time to edit a picture to create that effect anyway???
If the idiots responsible for those pics are viewing this...
GET A LIFE!!!!
Chris  wave
If it ain't broke, don't try to fix it... UNLESS it's a crap AFCAD!
Mon Nov 14, 2005 11:37 am
Trolley Dolley
Mon Nov 14, 2005 11:55 am
All faked poorly.
1) If you look at the far right hand tire of the right and main body gear, you can see the very bad cutting job they've done. It's not circular.
2) Apart from the afore mentioned lack of fire reflection in the fuselage, there is absolutely no black smoke from the burning petrol. Just think of the awful pictures of Concorde or the 9/11 impacts.
3) You can clearly see the egding around the tail where it has been cut out.
BMIFlyer
Mon Nov 14, 2005 12:03 pm
Ok, this.....
is actually a cut up, turn and paste job of this.....
Photo © Daniel Werner
It is a very bad edit  Yeah sure
How do I know it was this pic?
Look at the grass in front, and the treeline in the background, and the runway markings.
Lee
MarshalN
Mon Nov 14, 2005 12:25 pm
The third one is a fake because the aircraft was already in the air. The "runway" in that one is clearly a taxiway/runway in the back. The aircraft just happens to be riding over it -- the actual runway is the thing you see in the bottom.
AR1300
Mon Nov 14, 2005 1:03 pm
MMM.....don't think so.Is rotating.Look at the shadow(dim one).But still a fake.
C'mon, all look so fake!!!Is there a need to explain???
Mike
You are now free to move about the cabin
N766UA
Mon Nov 14, 2005 2:43 pm
Yeah all 3 are fake. You don't even need proof just take a close look and it's obvious. Gotta love how the one is an airliners.net photo too. If I were the photographer I'd be royally pissed.
This Website Censors Me
QantasHeavy
Mon Nov 14, 2005 10:55 pm
3rd one is an optical illusion... it is not landing on the "top" runway... it is a few feet above the bottom one. FAKE taikl strike skid added to top runway which is actually in the background... just that wheels are in just the right spot.
A319XFW
Tue Nov 15, 2005 3:48 am
Quoting Zeke (Reply 10):
Fake
I actually saw the same picture of the fake 747 blowing up with AC livery.
If I'm not mistaken, the rear fuselage of the aircraft is taken from a video/picture of a test done on a 747 (at RAF Bruntingthorpe?) to see what happens when a bomb explodes in the rear cargo bay of an aircraft (post Lockerbie).
ANITIX87
Tue Nov 15, 2005 3:49 am
Quoting QantasHeavy (Reply 16):
I don't think this one (the REAL one) actually is an optical illusion. It seems to me that you can see the jet-blast coming out of the engine and then being deflected parallel to the ground on which the aircraft appears to be. This tells me it is actually in contact. Plus, the near runway is a LOT closer then the far one, and I think if it were actually above the closer one the plane would appear much larger relative to the buildings.
Just my two cents, I could be wrong.
TIS
Newark777
Tue Nov 15, 2005 3:57 am
Quoting ANITIX87 (Reply 18):
You can also tell that it's still on the ground because of the angle of the main gear. If they had left the ground, they would be angled like this:
Photo © Remi Dallot
Harry
alasdaironeil
Tue Nov 15, 2005 6:13 am
1 is a fake because a wing wouldn't break like that.
The wing is far more flexible and if it was to break, it would break further down the span.
If you watch the static loading tests, the wings break further down the span, not near the tips.
失去在翻譯 - Lost in Translation
jmc757
Tue Nov 15, 2005 7:23 am
Ok they're all fakes, but they're not too bad and look fairly impressive (in a strange kind of way!).
Quoting GEEZ (Reply 9):
Its not these people you have to worry about. Ok, its may be a little strange, but the people who made these are just having a little fun playing around in photoshop. They're not hurting anyone, and I for one think the results are fairly impressive (again in a strange kind of way!)
On the other hand, there are some very strange morbid, even twisted people that do something rather different - faking ACTUAL accident photos. Helios 737 photos come to mind as well as a number of 9/11 "photos". That another level all together.
TheCheese
Tue Nov 15, 2005 7:30 am
In the third one, you can see that the 'shopper duped the windows on the building on the left to cover where the plane had been: the four rows of windows at the top of the building are identical with the four rows below that.
Also, if you look at the nose gear, you can see that they didn't bother trimming the eave line of the building behind the gear out, and they left the shadow of the nosewheel on the hangar door.
Plus, that picture has the look of someone using Unsharp Mask to hide the artifactation left behind from the photomanipulation. That's the fuzziness; the real picture is in focus.
So. Very. Fake.
MissedApproach
Tue Nov 15, 2005 10:03 am
Quoting N766UA (Reply 15):
I often see A.net photos floating around in emails & powerpoints, usually with the copyright cut off the bottom. Very irritating. What are they trying to hide?
Oh, & I think all the photos at the top are pretty blatantly altered.
Can you hear me now?
AlitaliaMD11
Tue Nov 15, 2005 10:10 am
The B747 looks so cute in this photo! dopey
No Vueling No Party
