Cory6188
Spanish Language On Emergency Exit Doors
Thu Nov 17, 2005 6:42 am
When I flew down to PBI this past weekend on CO, I was able to get exit row seats in both directions.
It sounds like a stupid question, but the door said the words "Pull" and "Hale". In Spanish, the verb "jalar" means to pull, which means that the logical usted command form (for any of you who know Spanish) would be "jale".
Why do they use "hale" instead?
MAH4546
RE: Spanish Language On Emergency Exit Doors
Thu Nov 17, 2005 7:09 am
Jalar means "to pull" as in "to haul/tow", like "the truck pulls the cargo" . "Halar" means "to pull" as into to "pull foward", as in "pull the exit door foward".
a.
ikramerica
Thu Nov 17, 2005 7:11 am
What are they in Swedish? Just out of curiosity.
Cory6188
Thu Nov 17, 2005 7:12 am
Huh - I never knew that. Thanks for pointing that out. I asked my Spanish teacher, and she had never heard of halar versus jalar.
DCAYOW
Thu Nov 17, 2005 7:27 am
On Southwest I think it said "Jale" - but it was for the device that you pulled to disengage the exit window.
Retorne ao céu...
luisca
Thu Nov 17, 2005 7:30 am
JALE is mainly used in Mexico, in almost all of the other spanish speaking nations the correct form is HALE from the verb HALAR which means to pull.
The doors in comerciall places usually say push or pull, I have only seen JALE in Mexico, in the rest of latin america all doors say HALE
The "Real Academia de la Lengua Espanola" Dictionary (equivalent to Websters in English) gives both words the same definition, it does not specify which term is correct.
Each country has its own local office of the Real Academia, they each publish their own dictionary, in the Panamanian dictionary which is the one I know HALE is the correct word. JALE is not even mentioned.
JALE is a regionalism. HALE is the most common form and used in the majority of countries. That said, the fact that each country has its own dictionary is proof of how diverse spanish is. You really appreciate this here in Miami, were I learn a new word all the time.
[Edited 2005-11-16 23:34:15]
If it ain't Boeing (or Embraer ;-)) I ain't Going!
ContnlEliteCMH
Thu Nov 17, 2005 7:31 am
I find it ironic that you must speak English to sit in an exit row on an American carrier. And yet, the instructions are in Spanish as well. Funny, funny...
Christianity. Islam. Hinduism. Anthropogenic Global Warming. All are matters of faith!
sflaflight
Thu Nov 17, 2005 7:37 am
You are correct MAH4546. I never knew that either. As a latino who grew up in the US, I never even knew there was a difference. But here is the catch.... I'm confused... My vox dictionary from Spain has both entries, but my North American English-Spanish dictionary doesn't make the distinction. Could it be dialectal or is one dictionary just wrong? But, remember that the pronunciation would be different. The letter j is pronounced h in Spanish, which would be [hale] phonetically. The letter h is silent, so hale would be pronounced [ale] phonetically. So, while the look similar in English, they're not even the same word. Ah, the things we learn on this board!!! See, and mom says I waste my time on this thing!
 Confused
luisca
Thu Nov 17, 2005 7:52 am
Quoting Sflaflight (Reply 7):
Read my post #5
Mexicans pronounce haalei the rest pronounce aalei
it is a regionalism
Lan_Fanatic
Thu Nov 17, 2005 9:08 am
Quoting MAH4546 (Reply 1):
Wow, I didn't know that! Thanks for the info.
The words jalar and halar are practically non existant in the chilean spanish vocabulary. Instead we use for push/pull empuje/tire
AR1300
Thu Nov 17, 2005 9:13 am
ditto here  Smile
Mike
You are now free to move about the cabin
sflaflight
Thu Nov 17, 2005 9:24 am
Quoting Luisca (Reply 5):
Trust me Luisca, living and working in Miami as well, I go through this quite often also. And thanks to Reggaeton, still changing by the minute!
 Wink
Quoting Lan_Fanatic (Reply 9):
Absolutely, actually, because I also speak French and Italian, they would be my first choice. Tirez, Tirare!
PDPsol
Thu Nov 17, 2005 9:48 am
As with Chile, no one uses the term "jale" or "hale" in Argentina or Uruguay when referring to "pull".
Regional accents and terms are radically different in various parts of Latin America. Someone from say, Mexico, would most likely need quite some time in Bs.As. if he/she wanted to pick up the 'rioplatense' accent and learn all the local terms [and vice-versa].
