Tiger119
U.S. FARs/Foreign Carrier Routes/Regulations
Thu Nov 17, 2005 9:45 am
Can carriers based outside of The United States fly routes leaving an airport in The United States with a destination city in a third country? Example, can MX fly a route say from IAH to YYZ? I know a "foreign" carrier cannot fly between two U.S. airports unless it is one leg of two, like the JL flight from LAS to LAX then on to Japan, and the QF flight from Australia to LAX then on to JFK. What FAR do these rulings come under?
Photo © Youri Thonon - Contrails Aviation Photography
Flying is the second greatest thrill known to mankind, landing is the first!
commavia
RE: U.S. FARs/Foreign Carrier Routes/Regulations
Thu Nov 17, 2005 9:52 am
Quoting Tiger119 (Thread starter):
It depends on the nationality of the foriegn airline, and the bilateral aviation treaty that nation has with the U.S.
What you refer to -- if I understand you right -- is called the 5th Freedom right, allowing an airline from Nation A to fly to Nation B, pick up passengers, and then carry them on to Nation C. Some countries have these types of arrangements with the U.S. -- like Spain, for example, and Canada as of next year -- while others do not. It just depends on the country.
yvrsr
Thu Nov 17, 2005 12:09 pm
Yes.
Currently, CX flies between YVR and JFK. Before HKG-SFO nonstop started, CX used to fly HKG-YVR-SFO, with full 5th Freedom rights between YVR and SFO. Philippine Airlines flies between YVR and LAS. There may be other examples with YYZ being the intermediate point, but I don't know off hand.
I don't know the general rules -- may differ country to country, as mentioned in the previous post.
loisencroach
Thu Nov 17, 2005 12:15 pm
As stated earlier, it depends on the bilateral agreement between the two nations. For instance, Cathay flies from Toronto to Anchorage, and then on to Hong Kong. However, the pax aren't allowed to deplane, nor does Cathay sell tix for the ANC-HKG leg, because no bilateral agreements have been established between Hong Kong, Canada, and the U.S.
Gemuser
Thu Nov 17, 2005 12:58 pm
Quoting Loisencroach (Reply 3):
There are bilateral agreements between HKG & the US and between HKG & Canada. Its just that the ANC stop falls outside either bilateral treaty. It is approved as a "technical stop", generally MOST countries will agree to these outside bilateral treaties.
QF is shortly to resume services SYD-SFO-YVR, apparently they have 5th freedom rights SFO-YVR. They also have 5th freedom rights JFK-LHR, which are not currently being used.
Gemuser
DC23468910;B72172273373G73873H74374475275376377L77W;A319 320321332333343;BAe146;C402;DHC6;F27;L188;MD80MD85
loisencroach
Thu Nov 17, 2005 1:20 pm
Quoting Gemuser (Reply 4):
You're right. I should have clarified that they don't have bilateral agreements concerning cabotage rights from ANC.
ANother
Thu Nov 17, 2005 7:52 pm
Quoting Loisencroach (Reply 5):
YYZ-ANC isn't cabotage. If authorised in both ASAs it would be a 5th freedom sector.
Air New Zealand operates LAX - LON with full 5th freedom rights.
The freedoms of the air (or at least the first 5) come from the Chicago convention.
loisencroach
Thu Nov 17, 2005 9:36 pm
Quoting ANother (Reply 6):
Oops, you're right. Cabotage would be two domestic points operated by a foreign carrier. Thanks for the correction.
