UNITED777ORD
Flying US Airways Out Of LAX
Mon Nov 21, 2005 10:11 am
I am flying US Airways on Thanksgiving Day for a 7:25am flight to Pittsburgh. How early do I need to check-in. I know that Southwest dominates Terminal 1 and I have heard about the congestion. Also, with the possibilities of a major storm approaching the east coast, should I expect my flight to be delayed? Also, are there any good restaurants in Terminal 1 @ LAX? How is the AirMall at PIT? Thanks in advance for any feedback/suggestions.
jfrworld
RE: Flying US Airways Out Of LAX
Mon Nov 21, 2005 10:24 am
I would arrive at least 2 hours before your departure. In my experience, the early morning flights create a huge rush. Since most major airlines start their day with 6 or 7 am flights, it creates a huge rush at security that doesn't seem to exist later in the day.
swabur
Mon Nov 21, 2005 10:27 am
You probably need to be at the terminal two hours prior to your departure. If there are storms back East your plane might be a tinge delayed, I'd call US Airways before you get there to check there. Regarding the food, LAX is limited in Terminal 1, there's a California Pizza Kitchen, McDonalds, Starbucks, El Paseo (pretty good but a little pricey), and a Backlot Cafe. PIT is awesome, its like a mall in the terminals, im sure you'll be able to find something good there. Hope this helps.
C'Mon Mav, do some of that pilot sh**!!
modesto2
Mon Nov 21, 2005 12:26 pm
Arrive with plenty of time. In my experiences, LAX on Thanksgiving morning is ridiculously busy, especially the Southwest terminal.
Tornado82
Mon Nov 21, 2005 1:08 pm
Quoting Swabur (Reply 2):
It looks as if your plane will be an RON plane. Also, PIT is rarely affected by east coast ground stops/flow controls because it is laid out better (simultaneous parallels) and has less traffic so that should not be an issue either. Welcome to the Steel City for your Thanksgiving!! I'll be in SW PA as well for the holiday, except I'll be driving it on Wednesday, mountain snow permitting.
wjcandee
Mon Nov 21, 2005 5:19 pm
You should check-in online and print your boarding pass before you go to the airport. This gives you significant protection against being an involuntary bump, and also it means that the first line you get into is the security line, not the check-in line. (Tell me you're not checking anything.)
Best,
Bill
UNITED777ORD
Wed Nov 23, 2005 2:37 am
Tornado82- is it possible for me to fly standby on Wednesday evening if there is availability? I would like to arrive in PIT on Thursday morning if possible.
Tornado82
Wed Nov 23, 2005 3:15 am
You're asking the wrong person about actual seat availability I'm sorry to tell ya, I don't work for US. That said, I assume its worth a try, but that is probably the worst possible day to try a stand by on. The weather will be much better out here (PA) tomorrow (Wed) versus today, sans mountain snows, so if they try a goofy LAX-PHL-PIT routing it shouldn't be too bad for delays in PHL either. By Wed. evening there should be some light to moderate snow and some gusty winds at PIT, but nothing to significantly affect ops there. Like I said earlier, PIT is very hardy to weather with the simultaneous parallels and whatnot. However by Thursday morning that same clipper may be producing some snows and gusty winds at PHL if they give you that, and we all know what happens with bad weather at PHL. Have a nice trip, Happy Thanksgiving.
gilesdavies
Wed Nov 23, 2005 3:25 am
All I can say is good luck... You will need it!
We arrived at Terminal 1 at LAX at 5am for our flight to LGW connecting via CLT and the terminal was a nightmare.
We queued 1.5hrs for check-in and the queues were going outside the terminal to passenger drop off points. Once we checked in, had to go back outside and queue to get through security.
The staff in ther terminal were miserable and all seemed to have got out of bed the wrong side. We arrived at the boarding gate with 20mins to spare and had no time to get some breakfast or coffee
We was going to buy some food on the flight but the trolly had ran out by the time it got down to us. We were rather hungary by the time we got to Charlotte! The A321's they operate on the trans-con flights are very comfortable!
Matt D
Wed Nov 23, 2005 5:00 am
The best advice anyone can give you on flying at or on the Holidays is: DON'T.
If you must, you must. But if at all possible, try and time your flights to either the day before or after the rush, perhaps at odd times of the day. Plan on plenty of lines and be sure to have plenty of patience.
Byrdluvs747
Wed Nov 23, 2005 5:06 am
If you are elite(Gold and higher) on HP or US, you should be able to use the elevator to bypass all the WN vermon at the security line. I've done it a couple of times at LAX.
Otherwise, I wouldn't take the chance of arriving just two hours ahead. I'd get there at least 2.5 hours ahead of departure.
The 747: The hands who designed it were guided by god.
