iowaman
WN To Double PHL Departures By Next Spring
Fri Nov 25, 2005 6:27 am
PHILADELPHIA, Nov 24, 2005 (AP Online via COMTEX) -- Southwest Airlines Co.
plans to increase the number of gates it leases at Philadelphia International
Airport next year, allowing the low-cost carrier to significantly boost its
daily flight schedule.
By next spring, Southwest expects to lease a dozen gates at the airport, meaning
it could double the schedule of 53 flights a day it has now, according to
airline and airport officials.
Even with more than 100 flights a day, Dallas-based Southwest would remain
behind US Airways in Philadelphia departures. Philadelphia is US Airways Group
Inc.'s second-largest domestic hub and its primary international hub, with 475
daily flights to 110 destinations.
Southwest operates from six gates at the Philadelphia airport now. By early
January, the airline plans to take over leases on two gates used by UAL Corp.'s
United Airlines, said Steve Sisneros, Southwest's manager of properties. By
spring, Southwest will get four gates now used by Delta Air Lines Inc.
Southwest's expansion could further pressure US Airways to cut prices. In 2004,
when Southwest invaded US Airways' Philadelphia turf, average one-way fares here
dropped 26 percent.
flypdx
RE: WN To Double PHL Departures By Next Spring
Fri Nov 25, 2005 6:30 am
How can PHL deal with that kind of growth??? They have delays as it is!
727LOVER
Fri Nov 25, 2005 6:33 am
So WN will have gates on 2 concourses, correct?
Love Trumps Hate
iowaman
Quoting Flypdx (Reply 1):
That's what I was thinking. WN must be doing really good out of PHL to warrant that kind of growth.
vega
Fri Nov 25, 2005 6:58 am
Quoting Iowaman (Thread starter):
You might want to refer to this thread: RE: PHL The Great Terminal Shuffle... (by USflt1778 Nov 17 2005 in Civil Aviation)#ID2442598
DL is moving to "A", Air France to "A(West) and UA appears to be cutting back at PHL for now. "E" is going into a construction phase (adding gates). My guess is that eventually WN will move all of their operations to E and move away from D. Imagine being able to easily bypass the WN masses enroute to your flight. It remains to be seen if WN can achieve their required turns at PHL with 100+ flights/day.
We are but a moment in this vast Universe and when gone we will never have existed.
atrude777
Fri Nov 25, 2005 7:10 am
I hope to see STL-PHL with this expansion!
Alex
Kahala777
Fri Nov 25, 2005 8:51 am
Finally, Southwest Airlines, is becoming a major player in the East Coast!
For years the East Coast has suffered from the menacing service and inane pricing structures of Continental, American, and Delta Airlines. US Airways, has finally woken up and realized to survive in todays domestic market, you need two main things. Low Fares. Frequency.
KAHALA777
iowaman
Fri Nov 25, 2005 8:57 am
Quoting Atrude777 (Reply 5):
I could definitely see a couple STL-PHL flights happening.
floorrunner
Fri Nov 25, 2005 9:06 am
I would guess more frequencies to their Florida cities and when the Wright amendment goes down, service to DAL.
A330323X
Fri Nov 25, 2005 9:09 am
Clearly, you don't understand. US causing delays is bad, but WN causing delays is good. Follow?  Silly
Quoting Kahala777 (Reply 6):
Finally?  Yeah sure
On exactly which route at PHL has US *ever* offered less frequency than WN?
I'm the expert on here on two things, neither of which I care about much anymore.
Kahala777
Quoting Floorrunner (Reply 8):
Additional flights to the West Coast, Florida, East Coast, and Midwest.
That will be the greatest day in American aviation! Would love to see the boys in Ft. Worth when that happens!
KAHALA777
DfwRevolution
Fri Nov 25, 2005 9:55 am
Quoting A330323X (Reply 9):
Finally?
I also think "finally" doesn't do WN proper justice, Kahala...
BWI has been one of WN's largest stations for years now, and WN have served many north east destinations (ISP, BDL, PVD, MHT, ALB, BUF) for more than a decade. PHL is simply another point on the WN map.
N200WN
Fri Nov 25, 2005 11:07 am
What is the breakdown for US at PHL between mainline/express/international?
A330323X
Fri Nov 25, 2005 11:17 am
Quoting N200WN (Reply 12):
For December, the rough numbers are 158 mainline, 226 RJ, 91 turboprop.
International in December is 8 dailies to Europe, and about 14 to the Caribbean.
N200WN
Fri Nov 25, 2005 11:38 am
Quoting A330323X (Reply 13):
A nice size operation, thanks for the info. Just two more questions about US at PHL...what is the highest number of departures they've ever had and have they "depeaked" their hub operation to help relieve some of the ATC issues? I read that WN was working with ATC to alleviate some of the delays and I'm sure US has done the same.
With 158 mainline flights it is possible for WN to at least equal that in the not too distant future.
A330323X
Fri Nov 25, 2005 12:08 pm
Quoting N200WN (Reply 14):
They were in the 494-496 range from February through July of this year. As many as 225 mainline in February, before the mainline fleet count started plummeting.
They did depeak it back in February, to increase aircraft utilization. Didn't much help ATC and hurt connectivity more than anticipated, so they've since repeaked it a bit. They certainly do plenty of other things to help with ATC, like use alternate runways and such.
Not with 12 gates.
