airbusA346
A380 Construction
Fri Nov 25, 2005 7:05 am
What currently has, or being constructed for the A380.
-Like airport gates
-Hangars
-Runways
-Taxiways
-Bridges.
Tom.
Tom Walker '086' First Officer of a A318/A319 for Air Lambert - Hours Flown: 17 hour 05 minutes (last updated 24/12/05).
A360
RE: A380 Construction
Fri Nov 25, 2005 8:29 am
The A380 doesn't require as many changes in airports as most people think...
Regards:
A360
dw747400
Fri Nov 25, 2005 8:40 am
To the best of my knowledge, most changes to allow the A380 to operate are relatively small. More major changes can be helpful to the operators.
The A380 can operate from any runway the 747 can, and can use most taxiways (some minor fillets need to be added at many airports).
Most widebody gates fit the A380, but there may be clearence issues with adjacent aircraft. Specialized gates could dramatically reduce boarding time.
Obviously a bigger plane needs a bigger hangar, and some bridges will need to be strengthened or made off limits to A380s.
CFI--Certfied Freakin Idiot
TinkerBelle
Fri Nov 25, 2005 8:41 am
Quoting AirbusA346 (Thread starter):
Could you please support your statement?
Like airport gates
-Hangars
-Runways
-Taxiways
-Bridges.
Some airports will definately have to do all the above especially bridges. I read an article a while ago whereby LAS airport officials stated that they are not even sure the whalejet can land @ LAS as an emergency alternative because the bridges cannot hold up the weight.
I believe most airports that the whalejet will be flying to are already working on taxiways and runways especially the separation btwn the two coz of the whalejet's wingspan. Not too sure about hangars tho'.
If you are going through hell, keep going.
airbusA346
Fri Nov 25, 2005 5:12 pm
Quoting TinkerBelle (Reply 3):
I did not say this in the thread starter. A360, said it in the first post.
Tom.
A360
Sat Nov 26, 2005 1:04 am
I meant exactly what Dw747400 said in his reply:
Quoting Dw747400 (Reply 2):
Regards:
A360
Ruscoe
Sat Nov 26, 2005 7:28 am
That is probably true for Landing & Taxi, until something goes wrong such as miss the last taxiway. In some cases will need the tug to "back & fill" it out, and consequently be a nuisance to other traffic.
Also need to consider general airport facilities, such as parking, customs, checkin, baggage collection etc etc.
Another consideration is FOI by the outer engines, which wikk overhang the runway at many airpoprts.
These aren't showstoppers, and mean that there should be plenty of airports available as alternates, but a lot of airports need to spend a lot of money, to see the 380 on a regular basis.
Ruscoe
astuteman
Sat Nov 26, 2005 7:35 am
Quoting Ruscoe (Reply 6):
In reality, I guess, the regularity will dictate the level of investment.
siromega
Sat Nov 26, 2005 7:46 am
Wouldnt that really only preclude landing on the 25/7 runways? And the D Concourse? Granted, the D concourse is probably the only place you could dock an A380 since all the other gates are really setup for narrowbody (757/737/32x) jets. Maybe the international terminal as well..
RedChili
Sat Nov 26, 2005 12:31 pm
With worldwide air passengers predicted to double by 2020, many airports will need to construct additional parking spaces, check-in desks, etc. anyway. It doesn't matter if those additional passengers will fly on an A380 or a 787. A passenger flying on a 787 cannot park in a smaller parking place than a passenger with a ticket for an A380!
Quoting Siromega (Reply 8):
Gate space is the last thing you need to worry about if the A380 makes an emergency landing.
Top 10 airplanes: B737, T154, B747, IL96, T134, IL62, A320, MD80, B757, DC10
NAV20
Sat Nov 26, 2005 2:02 pm
Required improvements at Melbourne are estimated at $A50M. Sydney is initially spending $A46M. on operational needs, I believe the total budget (i.e, including extra terminal space and car parking) is over $A100M.
http://www.theage.com.au/news/Nation...iant/2005/01/18/1105810913948.html
"Once you have flown, you will walk the earth with your eyes turned skywards.." - Leonardo da Vinci
