Byrdluvs747
What Kind Of Plane With 4 GE90 Engines?
Sun Nov 27, 2005 9:25 am
Obviously one doesn't exist, but I was wondering what kind(size) of plane could one build with this kind of thrust?
Could one imagine a plane 1.5 times the size of an A380? Bigger? How much range would one get with four engines of that size?
The 747: The hands who designed it were guided by god.
Btriple7
RE: What Kind Of Plane With 4 GE90 Engines?
Sun Nov 27, 2005 9:29 am
As far as I know the engines on the A380 are larger and more powerful than the GE90s; so I would say the 747-8 would be the kind of plane to have four GE90s.
Btriple7
Just...fly.
zvezda
Sun Nov 27, 2005 9:34 am
Quoting Btriple7 (Reply 1):
No, the engines on the WhaleJet are less powerful than GE90s.
Quoting Byrdluvs747 (Thread starter):
The WhaleJet has a fuselage 281 inches wide and 331 inches tall. If one were to widen that to a circular 331 inches, four GE90s would provide about the right amount of thrust.
Range is not really a function of thrust.
AirRyan
Sun Nov 27, 2005 9:36 am
Ahh, that's a negative ghost rider. A380 engiens are around 75,000 to 80,000 lbs/thrust class where the GE90's are up to 115,000 lns/thrust. 4 GE90's on a fully doubled decker 747 or a new C5 "big-brother" might be cool but is there a need for such a plane?
KC135R
Sun Nov 27, 2005 9:38 am
Not hardly...
The Trent 900's are 70-76,500 lbs thrust
http://www.rolls-royce.com/civil_aer...ines/trent900/technology_flash.jsp
The GE90-115 is rated at 115,300 lbs thrust
http://www.geae.com/engines/commercial/ge90/ge90-115b.html
I see I got beaten to the punch twice while I was trying to find references!! Oh well...
[Edited 2005-11-27 01:41:20]
Thorny
Sun Nov 27, 2005 9:40 am
A380's engines are around 70,000 lbs thrust each. GE90 peaks at around 115,000 lbs. thrust.
dan2002
Sun Nov 27, 2005 9:41 am
Btriple7
The GE90-115B is also physically larger in diameter than the A380s engines.
Dan
A guy asks 'What's Punk?'. I kick over a trash can and its punk. He knocks over a trash can and its trendy.
B777200
Sun Nov 27, 2005 9:42 am
I was actually thinking of this same topic myself. That aircraft would have approximately 4 * 90,000 = 360,000Lbs of thrust.
Just to compare. (Approximate figures)
Boeing 747-400 = 4 * 62,000 = 248,000Lbs Thrust
Airbus 380-800 = 4 * 72,000 = 288,000Lbs Thrust
Antonov An225 = 6 * 52,000 = 312,000Lbs Thrust.
Instead of having 6 Engines on the Antonov An225, 4 General Electric GE90's would be more powerful.
Greetings to All
stuckinMAF
Sun Nov 27, 2005 9:55 am
Quoting B777200 (Reply 7):
Exactly what I was thinking when I saw the subject of the thread, ya beat me to it!!!
Now THAT would be worth seeing!
"A fear of weapons is a sign of retarded sexual and emotional maturity" -Sigmund Freud
A360
Sun Nov 27, 2005 10:11 am
A380F = 4* 76,500 = 306,000Lbs Thrust
The An225 wouldn't need 4 GE90's. 4 GP7200/Trent900 would do the job(both are certified to up to 80k lb)... and burn less fuel.  Wink
kanebear
Sun Nov 27, 2005 10:38 am
Saw the topic and was thinking B-52... until I educated myself. Heck, ONE GE-90 would be ALMOST enough to replace the EIGHT turbofans (TF-33/JT3D @ 17,000lbs thrust
[Edited 2005-11-27 02:42:42]
whitehatter
Sun Nov 27, 2005 10:50 am
An A380 technically could be built with four GE90 engines as there are lower thrust versions. British Airways had their 772A aircraft delivered with engines which are in the general ballpark.
It would need some redesign work and maybe higher undercarriage to cope though. The GE90 range starts at 74,000lbs thrust.
Lead me not into temptation, I can find my own way there...
RayChuang
Sun Nov 27, 2005 10:56 am
Technically, the A380 kind of uses GE90 engines because the Engine Alliance GP7270 engines on the A380-800 passenger model uses a lot of technology found on the GE90 engine.
whitehatter
Sun Nov 27, 2005 11:04 am
Quoting RayChuang (Reply 12):
It's an interesting hybrid of GE and PW technology which should be an excellent engine. Maybe in another universe that co-operation could have resulted in another engine being developed in the GEnx category.
GE does interesting work when in cooperation, look at its killer product as partner in CFM. It is also partnered with Rolls in the military field for the JSF powerplant.
malaysia
Sun Nov 27, 2005 11:14 am
3 Ge90 and a Tristar, would make the most lovely L-1011 NG
There Are Those Who Believe That There May Yet Be Other Airlines Who Even Now Fight To Survive Beyond The Heavens
Btriple7
Sun Nov 27, 2005 11:49 am
Quoting Zvezda (Reply 2):
Quoting AirRyan (Reply 3):
Quoting KC135R (Reply 4):
Not hardly...
Quoting Thorny (Reply 5):
Quoting Dan2002 (Reply 6):
My apologies. ashamed  I did get the facts wrong.  ziplip  I'll be sure to check next time.
Thanks for the correction,
Btriple7
Just...fly.
Sun Nov 27, 2005 1:45 pm
Quoting WhiteHatter (Reply 11):
Using the historical growth of the 747-100 to the 400, an approximate static thrust increase of of 20% yielded a MTOW increase of approximatly 16%.
The GE90-90B would increase the static thrust on the 380 by about 25% one would expect this to yield a MTOW growth of around 20%.
GE90-90B FAA certified dimensions:
Overall Length 7283 mm
Overall width 3871 mm
Overall Height 3952 mm
Mass 7892.5 kg (17400 lb.)
Trent 900 EASA certified dimensions:
Overall Length 5302.5 mm
Maximum Diameter 3944 mm
Mass 6271 kg
8mm differance in the maximum cross section as per the data sheets for the Trent 900 vs the GE90-90B, Trent 900 has a larger overall frontal cross section than the GE90-115B, however its 1978.50 mm shorter.
The GE90-115B would increase the static thrust on the 380 by about 52% one would expect this to yield a MTOW growth of around 46%.
GE90-115B FAA certified dimensions:
Overall Length 7281 mm (286,67 inches)
Overall width 3769 mm (148.38 inches)
Overall Height 3926 mm (154.56 inches)
Mass 8761.1 kg
Mass to static thrust comparison (kg/N)
GE90-90B = 51.05
Trent 970-84 = 51.46
GE90-115B = 55.85
The GE90-115B has a higher "power to weight" ratio of the earlier GE90s and current Trent 900.
The above raw engine data was extract directly from the FAA/EASA TCDS.
Lemurs
Sun Nov 27, 2005 2:01 pm
Quoting Zeke (Reply 16):
Not to pick nits but I am almost certain GE doesn't offer the 90B anymore, only the 94B. The 94B core has improvements pulled from the 115B program, and they offer a retro-fit kit to airlines who operate the 90B. (Continental signed up to upgrade theirs to 94B's during heavy checks, and I am sure their 2 new planes will come with them standard.) The 94B actually has better SFC and operating economics than the 90B to boot, and another 16,000lbs of thrust isn't easy to ignore...
There are 10 kinds of people in the world; those who understand binary, and those that don't.
kanebear
Sun Nov 27, 2005 3:49 pm
Quoting Malaysia (Reply 14):
I'd love to see how exactly you'd shoehorn a GE90 into the ass end of that airframe.
sabenapilot
Sun Nov 27, 2005 5:37 pm
I think the stretched (and thus heavier) A380-900 could very well see use of a derated GE90 (under the form of a higher thrust GP7270 that is).
Anybody here knows from memory how much thrust the A380-900 will require?
[Edited 2005-11-27 09:43:38]
iwok
Sun Nov 27, 2005 5:56 pm
GE90-90B = 51.05
GE90-115B = 55.85
Zeke,
not to nitpick... If you have a mass/thrust ratio I assume you mean mass of the engine to thrust of the engine. If this is correct, then 51.05 Kg/N is better than 55.85 Kg/N i.e. the first is lighter for the same thrust. Am I confused? Do you mean N/Kg?
iwok
Sun Nov 27, 2005 6:25 pm
Quoting Iwok (Reply 20):
Do you mean N/Kg?
Thanks Iwok, typo on my side, should have been kN/kg i.e. 402920/7892.5
Quoting Lemurs (Reply 17):
I did the comparison at static thrust, not takeoff thrust. The GE90-90B static thrust is the same as the GE90-94B. For takeoff thrust GE90-90B 418133 kN (94000 lb), GE90-94B 432811 kN (97300 lb), 3300 lb per engine difference at takeoff thrust.
Brendan03
Sun Nov 27, 2005 7:14 pm
I would love to see an A380F (Possibly HGW) with 4 GE90s, Seeing that take off empty would be very impressive!!! O_O!!
Coolier than thou.
DavidT
Sun Nov 27, 2005 7:27 pm
Has anybody seen the photo of that 747 with 3 normal then one GE90 engine? The GE90 looks absolutely huge compared wit hteh rest. Only just cleared the floor.
Could you put two of those on a 747 and fly it? I suspect not  Sad
shamrock350
Sun Nov 27, 2005 8:30 pm
Quoting DavidT (Reply 23):
I saw a picture of that in Airlinerworld magazine it was huge!!
zvezda
Sun Nov 27, 2005 8:56 pm
Would it fly? Yes. Would it be certifiable? No, but the person who did it would be.  Smile
henny
Sun Nov 27, 2005 9:53 pm
... and burn double the amount of fuel, not to mention decimate the efficiency of -225's amazing wing.  Wink
3, 2, 1... Now!
A360
Sun Nov 27, 2005 10:45 pm
Quoting Sabenapilot (Reply 19):
I guess 4*Trent900/GP7200 at 80.000lb will be enough.
Or maybe even higher thrust version of those engines...
Regards:
A360
Alessandro
Mon Nov 28, 2005 12:39 am
B777200, I think 3 GE90-115s would be enough for a re-designed AN-225, I would like to see an AN-124 with 2 GE90-115s and same wing as AN-225 (somewhere between the two existing wingspans of the AN-124 and AN-225).
srbmod
Mon Nov 28, 2005 1:04 am
I'd like to see them stick 4 GE-90s on the B-52..........
Geo772
Mon Nov 28, 2005 1:26 am
The number of engines required is not just based on max overall thrust but the thrust required when you have an engine failure at V1.
The 747, A380 and the like only need comparatively small engines compared to the 777 because they only lose 25% of the total power rather than the 50% a twinjet losses.
This also explains why twinjets that have a similar weight to a quad have better airfield performance. Just look at the A330 and A340.
Flown on A300B4/600,A319/20/21,A332/3,A343,B727,B732/3/4/5/6/7/8,B741/2/4,B752/3,B762/3,B772/3,DC10,L1011-200,VC10,MD80,
Boeing Nut
Mon Nov 28, 2005 1:34 am
I thought I saw one time a schematic for the 747-500X and -600X in which GE-90's were displayed.
P.S. If you want to see some very cool "L-1011NG" illustrations, check out this guys webpage. http://perso.wanadoo.fr/puck/ He's an A.net member that does great stuff. He's been quiet for a while though.
[Edited 2005-11-27 17:40:36]
sabenapilot
Mon Nov 28, 2005 1:39 am
Quoting Geo772 (Reply 30):
Twins might have better field performance, but they are ironically sooner and more often payload limited when departing from short runways or from airports with terrain clearing issues.
Best known example is AF and their SXM operations.
Although the 777 has a more spectacular take off profile when all goes well, it would still need to be severely payload restricted on a return flight to CDG to meet the one engine out performance requirements.
The A343 however, often called a poor performer by those who don't know much about aviation (or by those who spent too much time on this site and blindly believe all that is said here), can take off at its max payload without any restrictions, thanks to the 4 engines concept!
This is also the reason why you will always see AF with A340 or 747 in SXM.... Because the 777 (or in fact any other twin bound for a long haul flight) would be extremely weight limited and be the real underperformer here.
[Edited 2005-11-27 17:45:30]
KC135R
Mon Nov 28, 2005 3:26 am
You mean these?
Photo © Je89 W.
Photo © Jet City Aviation Photography
Impressive - the funny thing is, if I didn't know better, it makes the 747 engines look tiny. But those are big engines too - the GE90 is just that much bigger.
SonicZoom87
Mon Nov 28, 2005 3:52 am
how about a 777-300ER with four GE90s???
I know it would not happen is obvious but what consequences would this bring? A supersonic Jet? Who knows, most likely the structure won't permitted.
zvezda
Mon Nov 28, 2005 4:27 am
Quoting SonicZoom87 (Reply 34):
The buffetting would break it apart. For supersonic flight, a pointy nose is needed. For subsonic flight, a rounded nose is more efficient.
Mon Nov 28, 2005 5:11 am
Quoting Zvezda (Reply 35):
The space shuttle is the fastest aircraft around at the moment, being hypersonic and supersonic, it does not have a pointy nose.
AirPacific747
Mon Nov 28, 2005 5:42 am
Not hardly...
I think I will say it once more just to make sure that everyone knows:
umm, I think the GE90's are more powerful than the ones on the A380  Wink
zvezda
Mon Nov 28, 2005 6:03 am
Quoting Zeke (Reply 36):
Good point. Why is the space shuttle an exception? Does anyone here know? Is it just strong enough to withstand the buffetting?
upupandaway
Mon Nov 28, 2005 6:22 am
re shuttle, my guess is that at launch it is attached to a pointy main booster, by the time it detaches it is outside most of the atmosphere. Most of the reentry is a belly flop, ie the underneath bears the brunt, not the nose. (?)
Web
Quoting Zvezda (Reply 38):
Most likely because the design is not intended for fast speeds, but for slowing down. If you put a pointy nose on the space shuttle, you would lose the drag the rounded nose produces to slow its speed and descent, requiring other drag-inducing devices.
deltaguy767
Mon Nov 28, 2005 6:30 am
CAUTION: This is an educated guess only!!
Hello All,
The reson why the space shuttle might have a rounded nose is that it also travels in space which is a vaccum. Meaning of couse that there is no air resistance or airflow issues.
From BDL,  wave
DeltaGuy767
A Good Landing is one you walk away from!
A360
Mon Nov 28, 2005 6:55 am
Quoting DeltaGuy767 (Reply 41):
Well, if it traveled only in space they could even have made it with a square nose...
The problem is taking of and reentering in the atmosphere.
Regards:
A360
sllevin
Mon Nov 28, 2005 7:04 am
The reason the shuttle doesn't have a pointy nose is ablation. The same reason that capsule designs, like the old Apollo, descended blunt end first.
If you provide a sharp nose, then the heat gets focused on that tiny little area, and it is easier to burn away. By providing a blunt shape, it's much harder to burn away.
Steve
keesje
Mon Nov 28, 2005 7:07 am
http://www.cardatabase.net/modifiedairlinerphotos/photos/big/00005184.jpg
We tried it during a dull week-end some time ago, however the boss drove by & saw it & we had to remove them before monday  Wink
malaysia
Mon Nov 28, 2005 7:27 am
Quoting Kanebear (Reply 18):
Maybe make a fuselage with 3x3x3x3 seating width hehe that will be a super wide-body L-1011 and maybe the GE90 will then fit just fine in the tail.
A360
Mon Nov 28, 2005 8:18 am
Quoting Keesje (Reply 44):
 rotfl
Regards:
A360
washfam
Mon Nov 28, 2005 10:19 am
It was probably the tailhook that took it too far. laughing
Funniest post this week. Thanks.
 rotfl
bomber996
Mon Nov 28, 2005 10:22 am
Thats gota be one fo the best modifications I've ever seen! Good find. bigthumbsup
Peace  box
"We've recently upped our standards, so up yours." - Federal Aviation Administration
Rj111
Mon Nov 28, 2005 11:02 am
Acciording to GE the GE90 thrust range is 74,000-115,000. and the GP700 is offered at 81,500 lb for the A380F. So some A380 engines may be more powerful than the some GE90's.
But they also say the first GE90 was certified at 84,000 so i don't know, so i dunno if they've made an error.
