timz
Parallel Landings At SFO?
Mon Nov 28, 2005 6:55 am
That "Airliners" article in the current issue says "Aircraft landing on parallel Runways 28L and 28R are directed to land simultaneously in order to allow spacing for departing aircrtaft on intersecting Runways 1L and 1R."
By "directed" they must mean, by the approach controller or conceivably the tower-- right? Has anyone ever heard that on their scanner?
I haven't, and I thought someone told me controllers weren't allowed even to request that, much less direct it. If it happens, great-- but I thought controllers couldn't try to make it happen. Was I wrong?
modesto2
RE: Parallel Landings At SFO?
Mon Nov 28, 2005 7:17 am
As far as I know, controllers do their best to sequence arrivals together. They may keep aircraft together with speed restrictions, but I've never heard a controller instruct a flight to stay together with another airplane. Instead, both aircraft may be put together and instructed to maintain 180 knots to the bridge or something like that.
malaysia
Mon Nov 28, 2005 7:20 am
I have seen really freaky things happen on arrival into SFO, I was once in a CI 744 and we cut into the path of the Icelandair 767 and it was pretty damn close behind us then suddenly we start speeding up to increase distance then we actually land, I was assuming the Iceland Air would land parallel to us, but actuallly it used our runway and a US A321 just fly right below us at a higher speed to do the parallel, but I just wonder how we just cut into a 767 path and it would land behind us
There Are Those Who Believe That There May Yet Be Other Airlines Who Even Now Fight To Survive Beyond The Heavens
Goldenshield
Mon Nov 28, 2005 7:23 am
NorCal approach is the one that is synchronizing the approaches into SFO by using parallel visual approaches into the airport. SFO tower then takes the spaces between then arrivals to run departures off of the 1's.
Quoting Timz (Thread starter):
When flying IFR, the controllers call the shots as far as spacing and syncronization go.
OPNLguy
Mon Nov 28, 2005 7:32 am
Quoting Goldenshield (Reply 3):
Just a note to clarify that Goldenshield said "IFR" and not "IMC". When the weather at SFO get to be about 2500-5 (IIRC), the simultaneous visual approaches to 28L and 28R go "poof" and they go to the ILS to 28L -or- 28R (one, not both).
Goldenshield
Mon Nov 28, 2005 7:42 am
Quoting OPNLguy (Reply 4):
Since they put in the LDA PRM approach, SFO can be as low 1200-4, with 2400-4 needed at the bridge for simultanious offset instrument approaches.
OPNLguy
Mon Nov 28, 2005 8:11 am
Haven't kept up with the mins since we ceased service there, but that's better than it used to be, and undoubtedly why (come to think of it) there don't seem to be as many GDP messages off the wire as there used to be.
BTW, your TRS308 DEN-ATL helped us out with a radio relay the other night--very professional, and appreciated. Already put an "attaboy" in the pipeline...
Tom in NO
Mon Nov 28, 2005 9:07 am
As an aside, anyone who has a copy of the issue of "Airliners" in questions (November/December 2005) should check out two of the pictures in the article: both depict a UA 744 holding on a taxiway, and a US A321 and UA 757 about to touch down. One was taken at ground level, and the other from an elevated position off to the side of the runway. They couldn't have been taken more than a couple of seconds apart.
Tom at MSY
RayChuang
Mon Nov 28, 2005 11:20 am
One thing that the FAA is seriously considering is that SFO could become the first airport to use an autoland system based on GPS satellite signals and differential GPS signals from the ground. This will allow extreme precision in landing even in very bad weather conditions (how about accuracy within one meter of runway centerline Big grin ), and could even allow side-by-side landings in ICAO Category III conditions
freedomtofly
Mon Nov 28, 2005 12:44 pm
Of course this could happen on occasion.
And this happens sometimes too.
Btw does anyone know what altitude aircraft are at when overflying the San Mateo Bridge? I heard it's anywhere between 1500 and 2500.
Aaron
You are now free to move about the world.
AAR90
Tue Nov 29, 2005 6:40 am
Quoting Freedomtofly (Reply 9):
When instructed to maintain visual separation and "do not pass" the other plane, I prefer to fly formation on that other plane. It's fun and gives the pax a nice view. Attempt is to touchdown as close as possible to the same time. Helps SFO ATC and is.... fun.  Wink
On the charted visual approaches... 1900 ft. The ILS' show 1800 ft.
Aeri28
Tue Nov 29, 2005 7:36 am
There was a great shot in the photo section somebody had taking a pic of a UA 744 from inside a cabin of another aircraft while both were getting ready to land.
Ralgha
Tue Nov 29, 2005 7:58 am
Quoting Goldenshield (Reply 5):
Yeah, but they don't use the PRM approaches. I've heard it's because they're understaffed. Alas, when the weather is too low for visuals, they regress to the ILS 28R. Leads to the expression "one cloud, two airplanes, three hour delay".
Bigger airplanes are as said a couple responses back. The mighty Brasilia can cross the bridge at 4-5 thousand and still make the runway.
WindowSeat
Tue Nov 29, 2005 8:56 am
It happens more often than you think. Only yesterday I was at the airport and watched a CX744 come in with a UA A319.
I myself have a video of an America West A319 and a Lufthansa 744 in a parallel approach all the way to the threshold.
It is quite fun to watch. I have been frequenting the airport a lot recently to spot, sitting at the Bayfront park watching aircraft eating a In-and-out burger is my new thing Big grin
cheers
I'm all in favour of keeping dangerous weapons out of the hands of fools. Let's start with keyboards.
freedomtofly
Tue Nov 29, 2005 9:06 am
Quoting WindowSeat (Reply 13):
In N Out burger is the best burger place ever!! I go there so much, it's kinda sad, but so good. And second, where exactly is bayfront park? My camera doesn't have enough zoom so I was told to go to Bayfront park to get good shots.
Aaron
[Edited 2005-11-29 01:24:20]
hawaiian717
Tue Nov 29, 2005 10:02 am
Quoting Freedomtofly (Reply 14):
You need a pretty good amount of zoom for Bayfront Park, especially with a new fence ruining 1R shots.
To get to Bayfront Park, take the Millbrae Ave exit off the 101 and head east (towards the bay). At the end of the street is a traffic light, turn right and you'll see the park on your left. There is a small parking lot, make the first left you can into it. If you pass the Marriott hotel, you've gone too far.
WindowSeat
Tue Nov 29, 2005 10:46 am
Quoting Hawaiian717 (Reply 15):
That is right. Also, if the parking lot in the Bayfront park is full, there is reserved parking for the Bayfront park users in the Westin SFO lot.
I'll be at the in-N-out and then the park next Sunday if anyone wishes to join.
cheers
AMSSFO
Tue Nov 29, 2005 11:52 am
Quoting Tom in NO (Reply 7):
here they are ...from a.net!
Photo © I. Gunawan
Photo © Ben Wang
impressive!
and looking for those I found some more:
Photo © I. Gunawan
Photo © Vasco Garcia
Photo © I. Gunawan
Photo © Sven De Bevere
cschleic
Tue Nov 29, 2005 12:41 pm
I've been on a United flight when the pilot told everyone not to worry about the plane right off the right side...just the parallel landing. It happens a lot...also on a Brasilia once as an America West A-320 caught up and passed us on the right. Happens at LAX, too.
jacobin777
Tue Nov 29, 2005 1:03 pm
scumball security..can't take decent pictures up close anymore.. mad
MyAviation.net photo:
Photo © Jacobin777
Photo © Jacobin777
Quoting WindowSeat (Reply 16):
I didn't know the Westin allowed it...I wind up parking accross the street..if the parking lot is full..plus there is no time limit there..  Smile
hmm....maybe I'll be there on Saturday, but Sunday is reserved for Football.. biggrin
"Up the Irons!"
MarshalN
Tue Nov 29, 2005 1:18 pm
Wow.... I love that Delta+BA744 shot. The views on the DL plane (left side) must be incredible!!!
kiwiandrew
Wed Dec 07, 2005 7:19 pm
There is a great aerial photo of SFO at the moment under 'top of the last 24 hours' ( sorry , I don't know how to put the photo into my post ) but it has really confused me - both sets of parallel runways look very close - too close I would have thought for simultaneous parallel landings - and yet the photos in reply 17 clearly show them - what is the minimum runway separation required for this sort of thing , and what is the actual separation at SFO ?
AMSSFO
Thu Dec 08, 2005 1:14 am
Quoting Kiwiandrew (Reply 21):
post a pic: photoid:971612 between brackets <> (the ID can be found in the URL of the picture.
Photo © Bjoern Schmitt - world-of-aviation
Don't know the answers on your questions, though.
jacobin777
Thu Dec 08, 2005 1:18 am
Quoting AAR90 (Reply 10):
correct, I was @ SFO yesterday listening in to the control tower.....1900 ft. was the predominant number mentioned.....
"Up the Irons!"
timz
Thu Dec 08, 2005 2:51 am
Actual separation is 750 ft center-to-center, which supposedly means 550 feet edge to edge. Looking at the rule, 550 feet edge to edge seems to be too close for large airliners to legally land parallel-- but somehow they do it.
hiflyer
Thu Dec 08, 2005 3:14 am
Considering the FAA requirement for bad weather dual landing is 4300 feet runway sep getting what they have now is pretty good!
timz
Thu Dec 08, 2005 3:53 am
Found the rule again-- see where it says the runway edges are supposed to be 600 feet apart? And not just for landings, either.
http://www.faa.gov/atpubs/ATC/Chp3/atc0308.html#3-8-3
