drinkstrolley
What's This In This A340 Cockpit Pic?
Tue Nov 29, 2005 7:37 pm
Above the VDU showing the tailcam image you can see the reg of the aircraft (G-VMEG), but to the right are more letters - what are they??
Cheers.
Photo © Sam Chui
PhilSquares
RE: What's This In This A340 Cockpit Pic?
Tue Nov 29, 2005 7:42 pm
Quoting Drinkstrolley (Thread starter):
It's the SEL CAL identifier for that particular aircraft.
[Edited 2005-11-29 11:42:51]
Fly fast, live slow
PipoA380
It's the SELCAL code
The SELCAL system consists of a ground-based SELCAL encoder and a VHF or HF communication system and the airborne decoder. Each aircraft's "SELCAL decoder" is assigned a unique code. The airborne SELCAL decoder is connected to the aircraft's VHF and HF radios. When the aircraft is called, an aural alert is received and the active radio is identified on the cockpit annunciator panel, signaling the flight crew to monitor the company radio frequency.
Photo © Nils Alegren
[Edited 2005-11-29 11:45:20]
It's not about AIRBUS. it's not about BOEING. It's all about the beauty of FLYING.
CHRISBA777ER
Tue Nov 29, 2005 7:44 pm
Pilot's Initials?
Sorry thats a really lame suggestion!
EM - MP
Have no idea.
What do you mean you dont have any bourbon? Do you know how far it is to Houston? What kind of airline is this???
drinkstrolley
Tue Nov 29, 2005 7:51 pm
Quoting PipoA380 (Reply 2):
What's the difference between that and the transponder then?
(Thanks for answer btw!!!)
VirginFlyer
Tue Nov 29, 2005 8:14 pm
Quoting Drinkstrolley (Reply 4):
The SELCAL is used for communications. The transponder is used to identify the aircraft on radar, and provide some information (depending on the mode of the transponder). Whereas the an aircraft will have a distinct SELCAL code, the transponder is a device where you select the code (usually on instruction from ATS, but there are some specific reserved codes, such as for emergencies, and flights outside controlled airspace). The transponder code is made up of 4 digits, each 0-7 (giving a total of 4096 distinct codes).
V/F
"So powerful is the light of unity that it can illuminate the whole earth." - Bahá'u'lláh
PipoA380
Tue Nov 29, 2005 8:30 pm
Yes as VirginFlyer said, it's for communications only. For use with the radio frequencies, whereas the transponder is a signal sent so the radar can identify the plane on a radar screen.
