dogfighter2111
Skymark B767 Suffers Uncontained Engine Failure
Sun Dec 04, 2005 3:45 am
Hey,
Just found this:
Read Full Story: http://aviation-safety.net/news/newsitem.php?id=1537
After landing a 1.5-meter-long, 20- to 60-centimeter hole was discovered in the engine.
Now, ^ that must be unusual. What could've caused that?
Mike
cloudyapple
RE: Skymark B767 Suffers Uncontained Engine Failure
Sun Dec 04, 2005 4:02 am
A fan blade coming out at an angle.
A310/A319/20/21/A332/3/A343/6/A388/B732/5/7/8/B742/S/4/B752/B763/B772/3/W/E145/J41/MD11/83/90
dogfighter2111
Sun Dec 04, 2005 4:35 am
ahh, ok thanks.
Mike
ikramerica
Sun Dec 04, 2005 4:53 am
Quoting Dogfighter2111 (Thread starter):
it's why fuselages are reinforced in line with the engines with a missing window, so if a blade flies off uncontained, it hits a strong part of the plane and doesn't fly through a window or something.
dogfighter2111
Sun Dec 04, 2005 4:58 am
Quoting Ikramerica (Reply 3):
Therefore not causing decompression?
Mike
CCA
Sun Dec 04, 2005 6:45 am
P1 in A330, A340, A346, B742, B744, B748.
dogfighter2111
Sun Dec 04, 2005 6:54 am
Quoting CCA (Reply 5):
Great, thanks. Isn't that a bit far back for a Fan Blade to cause that damage?
Mike
DfwRevolution
Sun Dec 04, 2005 7:10 am
I believe you are mistaken. Missing windows are usually related to AC ducts, not engine placement. Because aircon packs are usually in the wing root area, the "missing windows" are often close to engine pylons, but not precisely aligned with anything in particular.
It's simply coincidence. If an engine failed, engineers would have no way to know if uncontained debris will strike on window or another:
Photo © Les Rickman
Photo © Gerry Stegmeier
Quoting Dogfighter2111 (Reply 4):
If the fuselage is punctured, decompression (to varying degree) will occur. Window reinforcements are designed to keep a local failure from weaking the surrounding structure. A "rip stop" if you will.
The "missing windows" however, are not localized reinforcement to protect from an engine failure.
DrDeke
Sun Dec 04, 2005 7:14 am
Looks to me like it would have had to have been a turbine blade. Probably the low-pressure turbine judging from that picture.
-DrDeke
If you don't want it known, don't say it on a phone.
miamiair
Sun Dec 04, 2005 7:21 am
Quoting DrDeke (Reply 8):
You are correct.
