1337Delta764
Why Did The MD-87 And MD-90 Fail?
Sun Dec 04, 2005 6:06 am
Can anyone give the reasons why the MD-87 and MD-90 failed? I would guess the MD-87 failed because of its weight, based on the fact that it is a shortened MD-80. But what about the MD-90? Delta originally wanted the MD-90 to replace the 727, but later ordered the 737-800 instead.
HS748
RE: Why Did The MD-87 And MD-90 Fail?
Sun Dec 04, 2005 6:28 am
Quoting 1337Delta764 (Thread starter):
What do you mean by 'failed'?
1337Delta764
Sun Dec 04, 2005 6:36 am
Quoting HS748 (Reply 1):
Poor sales, DUH
FlagshipAZ
Sun Dec 04, 2005 6:41 am
They were not entirely failures. 75 MD-87s and 117 MD-90s were built. Alot of other aircraft have been built in far fewer numbers & they were reasonably sucessful, Concorde for one example, so was the 747SP. The MD-87 & MD-90 were sold to fill a niche, that's all. You just have to look at the overall picture. Regards.
"Beer is living proof that God loves us and wants us to be happy." --Ben Franklin
HS748
Sun Dec 04, 2005 7:08 am
Quoting 1337Delta764 (Reply 2):
Poor sales, DUH
Don't be such a patronising prick. It was a courteously put question that should have resulted in a courteous reply.
Tarantine
Sun Dec 04, 2005 7:15 am
Mainly the reason that the MD-90 including the MD-95 (717)"failed" was because Boeing bought McDonnell Douglas in 1997 and did not want it to compete with the 737 line.
gigneil
Sun Dec 04, 2005 7:25 am
Quoting FlagshipAZ (Reply 3):
The MD-90 was not a niche aircraft. It was MD's future in the narrowbody space along with the MD-95.
The problem was Boeing, aside from horrible problems that plagued the MD-90. That, and it wasn't much of a redesign its wing was practically the same and it didn't feature the same transcontinental range as the A320 and much later the 737NG.
The MD90 was never really going to be much of a family, either. The MD95 was smaller, but not as capable (although that would have been fine for the market), and I'm not sure an A321 or 737-900 sized MD90 was a possibility. I also don't believe an A319 or 737-700 sized MD-90 was ever in the works.
N
N1120A
Sun Dec 04, 2005 7:34 am
Quoting Gigneil (Reply 6):
The 717-300 was a very workable design and would have featured ATL-LAX range along with 73G/A319 capacity, so that would have helped fill out the MD90/95 range quite well.
1337Delta764
Sun Dec 04, 2005 7:55 am
I believe that MD did have a plan to make a version of the MD-90 to replace the MD-80. I have never heard anything about an MD-87/737-700/A319 sized MD-90.
N1120A
Sun Dec 04, 2005 8:08 am
Quoting 1337Delta764 (Reply 8):
The MD-90 itself was a replacement for the MD-80
Horus
Sun Dec 04, 2005 8:14 am
Egypt's AMC Airline operated 5 MD-90s, but the aircraft were returned post-9/11 due to the high lease rates of the aircraft. I was told from a reliable source the airline were happy to see the back of the aircraft as they continuously had techincal problems. In addition the pilots' had quite a bit to say when it came to the aircraft's handling.
Horus
EGYPT: A 7,000 Year Old Civilisation
sllevin
Sun Dec 04, 2005 8:17 am
The reason that the MD-87 wasn't popular was the same reason the 717 met the same fate: simply too small.
The economics of both aircraft were limited. Few operators used the MD-87 when you could fly the MD-80 "long" types for just pennies more. In short, you gained about 14% more capacity for about 6% higher fuel burn.
The most airlines that ordered the MD-87 (like AM) used it because they wanted the 'hot and high' performance that would weight limit the larger airplane.
The MD-90 had some issues with the VCSF power system early on. The economics of the aircraft also suffered, and in the end, simply weren't all that great to make a compelling story. In truth, while some things were modernized, the MD-90 wing was still the same basic airfoil from the 1960's, and it was outstripped by more modern development.
Steve
srbmod
Sun Dec 04, 2005 8:26 am
Quoting N1120A (Reply 7):
Had the 713 had that range, FL would have had Boeing build it for them. The 713 was only going to have a marginal increase in range, but not enough to do ATL-West Coast. Had MDD stayed independent, the MD-95-50 and the MD-95-30ER would have had the legs to do such a flight. There was no way Boeing would have built the 713, as it really competed with the 737NG in terms of capacity.
N1120A
Sun Dec 04, 2005 8:42 am
Quoting Srbmod (Reply 12):
That is the point. The 713 as proposed would have had the range for FL, but Boeing had no intention of taking a bite into the 73G's sales, as the 713's lighter airframe and BR715 engines would have likely beaten the 73G (and A319 for that matter) on costs handily. This is likely one reason that the FL order was heavily competed for as opposed to being a shoe-in for Boeing.
gigneil
Sun Dec 04, 2005 8:43 am
It never turned out that way... but lets say it had, and independently. ATL-LAX range is not competitive with the 3000+ nm range of the A319 and the 73G.
N
N1120A
Sun Dec 04, 2005 8:45 am
Quoting Gigneil (Reply 14):
Of course not, but it would have suited FL and other carriers just fine. I mean, at the time, LH was also looking at it as part of a large Star Alliance joint order.
yyz717
Sun Dec 04, 2005 8:47 am
Compared to their initial sales targets, and the rip roaring success of the equivalent offerings in the 737 & 320 lines, they were actually failures.
As mentioned, the M87 was too heavy. Perhaps MDD should have developed an M87-lite as a true DC-9-30 replacement. The M87 was also a few years late to the market after the 733 which did not help.
The poor range of the M90 actually turned it into a niche aircraft (high cap, short haul) which limited its potential.
Neil, I do remember MDD showing models of a shrunken MD-90 (about the size of the DC-9-40) along side the larger M90. This was before the separate development of the MD-95.
I dumped at the gybe mark in strong winds when I looked up at a Porter Q400 on finals. Can't stop spotting.
Flaps
Sun Dec 04, 2005 9:04 am
McDonnell's main reason for aquiring Douglas was its military product line. McDonnell never had a lot of enthusiasm for the commercial market and they just kind of let it play out by concentrating on derivitives of existing programs. They never really put much R&D in the commercial line. Another reason for the MD90's low sales was price. MDD had run into financial difficulties and made the decision not to get into a bidding war vs Boeing and Airbus. Had they done more discounting they would have won a few more large campaigns. Whether or not that would have ultimately made a difference is a moot point.
The MD87 was a niche design to begin with. The MD90 had good potential if it were fully developed but with MDD's focus elsewhere it came off kind of half baked. There financial issues that complicated the situation and of course, the sale to Boeing was the killer. It really is a shame because I love the MD80/90 line. From a passenger perspective I think it is vastly superior to the 737 series, the only model of which I like is the 200.
1337Delta764
Sun Dec 04, 2005 9:16 am
Quoting Yyz717 (Reply 16):
Do you mean DC-9-50? The MD-87 and 737-300 are sized like the DC-9 50.
yyz717
Sun Dec 04, 2005 9:21 am
Quoting 1337Delta764 (Reply 18):
The DC-9-30 replacement market was far larger, the DC-9-30 fleet was much older than the -50 fleet when the M87 was introduced. Anyway, an M87-lite would have been a good DC-9-30/40 and -50 and replacement.
dl021
Mon Dec 05, 2005 1:27 am
The development of Douglas aircraft post merger/absorbsion by McDonnell was stunted as mentioned earlier but I don't think it was from a lack of serious interest by the powers that be.
Douglas began its slide when it focused too much on the DC-7 rather than pushing forward with jet transports as quickly as they could have. The DC-8 was a superior aircraft to the original Dash 80 design, but Douglas was preoccupied with other airplanes and did not capitalize on their market dominance, rather resting on it.
Despite producing incredibly fine products (i.e. DC-8/9/10) they were forever playing catchup, particularly with the jumbos and although their DC-9 series was a fantastic success, it was their last hurrah in terms of dominating a marketplace. In the competition between airlines enough of their marketshare in the large aircraft market was taken up by Lockheed (not enough to make Lockheed want to continue with commercial aircraft) and Airbus with the A300 that they could not find ways to capitalize and get ahead of the powercurve with new airplanes. By the time they got to the DC-10 replacement they came up with a derivative using one too many engines and not performing to specs (which is a killer among customers who have been very loyal and took your word for it that the airplane would do certain things).
When they decided that they could not afford to bet the company on an all new MD-11, or even the MD-12 they basically surrendered the commercial segment to Boeing and Airbus. Their inability to design a new replacement for the DC-9, instead following the failed derivative approach with the MD-90 series, that again failed to impress longterm and very loyal customers (Delta and American in particular). The MD95/B717 was a success in a very small niche and without stablemates that would make an airline want to create a family. With one exception this very fine airplane saw no large purchase customers, and is unfortunately going to be the last Long Beach produced commercial airplane and descendant of Don Douglas to be sold.
It's disappointing, but that's the way it happened. What's kind of funny is that Boeing came in and destroyed the tooling for MD-11s right before the cargo demand for that airplane exploded and they probably could have sold another 100 or so of that airplane to cargo lines......of course at the cost of 777 and 744 freighters so the business decision is logical, but again disappointing.
Boeing won by taking the huge risks, Airbus won by eliminating risks, Douglas lost by trying to minimize risks in an open market that rewards advancement and success.
Is my Pan Am ticket to the moon still good?
gilesdavies
Mon Dec 05, 2005 3:17 am
What about the MD-88? - Was this aircraft popular and successful?
I flew this type with Onur Air back in 2000, EMA-DLM. This was a route of about 1800 miles and 4.5hrs flying time - I would have thought this was pushing the aircrafts range.
In that time you have seen Onur Air dispose of their newer A320's and A321's and have continued to keep the MD-88's so assume they must be pretty pleased with them.
1337Delta764
Mon Dec 05, 2005 3:21 am
Quoting Gilesdavies (Reply 21):
I am not sure about that one. The MD-88 is merely an updated version of the MD-82.
Rick
Mon Dec 05, 2005 7:12 am
The MD88 was designed and built specifically for Delta Airlines eventhough a few other Airlines Ordered it.
MidnightMike
Mon Dec 05, 2005 7:40 am
Quoting Horus (Reply 10):
2 of the AMC's that I know about were confiscated for lack of payment, in fact I know the pilots that had to go get the aircraft. The aircraft were in terrible condition and had over 50 DMI's (Delayed MX Items), amazing what happens when you do not take care of the airplanes, lack of MX, & eventually the airplanes will break.....
As far as high lease rates, bad credits, lack of payments, you are going to have high payments....
NO URLS in signature
MidnightMike
Mon Dec 05, 2005 7:44 am
Quoting DL021 (Reply 20):
I like the way you summed that up, nicely done. Not sure that I agree with you as to number of aircraft though.
RAFVC10
Mon Dec 05, 2005 6:47 pm
I must remember that the MD87 and MD88 aircrafts are and were the battle horses in short haul routes of Iberia and its affiliate in the 90's Aviaco.
Spanair is buying now the MD87 of Iberia.
I don´t think that these planes were failed or were a mistake.
El dia que los gilipollas vuelen, no podremos ver la luz del sol!
