smeagol
Missile Assault At DHL Aircraft - Is It True?
Mon Dec 05, 2005 9:21 pm
Look at the pictures at the URL below:
http://www.teein.com/01/2/421348.htm (In Chinese, Sorry)
No intention to discuss any political related topics. Just for curiosity: is it ture? If it is true, TECHNICALLY, how to guarantee the safty of the a/c and passengers in today's given situation. Particularly when the aircrafts are taking off or approaching?
When you look at a pig, no matter from what angle you look at it, it is a pig...
A319XFW
RE: Missile Assault At DHL Aircraft - Is It True?
Mon Dec 05, 2005 9:24 pm
Yes it's real - this was a DHL A300 from Baghdad. It was an amazing feat of pilotry getting the aircraft down again with a hole in the rear spar.
SWA TPA
Mon Dec 05, 2005 9:27 pm
The DHL plane was true as far as I know.
I cant say anything for the validity of the picture of the man with the missle launcher being of the actual attack on the DHL plane.
SWA TPA
I believe I can fly.....
OHLHD
Mon Dec 05, 2005 9:28 pm
RE: Images Of Rocket Attack On DHL Plane (by Gearup Sep 9 2005 in Civil Aviation)#ID2317598
Although you could have peformed a search, I thought I will do it.
Link above contains pics.
NIKV69
Mon Dec 05, 2005 11:23 pm
It is true, there is a video of the man launching the missle on the internet somewhere.
Hey that guy with the private jet can bail us out! Why? HE CAN AFFORD IT!
litz
Tue Dec 06, 2005 12:00 am
Quoting A319XFW (Reply 1):
Considering in addition to the hole in the rear spar on the wing, they had a raging fire, no hydraulics, and probably were scared out of their wits, absolutely !
They had two things going for them :
- They hadn't cleaned up the plane; so they were still configured for low/slow flight (this is one of the factors that doomed ua232, if you rememeber ... it couldn't slow down, so when they slammed down, it was waaaaay too fast) ... this allowed them to turn around and land at a somewhat normal speed
- The crew had just attended a lecture by Al Haynes, captain of the above mentioned UA232 ... his talk is about his experiences on UA232 using engine thrust to control a jet that has lost all hydraulics. This is exactly what the DHL crew did to turn around and manage a landing.
They actually touched down on the centerline of the runway, too !
Their lack of hydraulics caused the plane to veer off the runway (no steering), which actually ended up being a good thing : the sand thrown up by the nose gear snuffed the fire.
The plane itself, I think, is still at the Baghdad airport ...
- litz
Tue Dec 06, 2005 1:26 am
A Fantastic Display of Flying.Hats off to the Crew.Great effort.
This is a Danger which will exist in the Future too.Hopefully Lighter Missile Shields can be developed for Civil Airliners.
regds
MEL
Morvious
Tue Dec 06, 2005 1:33 am
Quoting Litz (Reply 5):
no hydraulics
Well, did the DHL bird lost hausralics to all 3 systems, or "just" one?
The main problem of flight UA232 was that it lost haudralics over all 3 systems. They could only stear, climb and descend with controlling engine power.
I beleve the DHL had a few operational systems left.
Doesn't realy matter, the crew did an awesome job!!
I also heard the wing did hit the ground after landing, so that it slammed to the right, off the runway.
have a good day, Stefan van Hierden
tkcom
Tue Dec 06, 2005 1:39 am
There's a show called "Mayday" on Discovery Channel Canada that documented this event. It was aired like a few days ago. The episode name is "Attack Over Bagdad." It actually has the video footage of the attack.
I think the show's name is different in other countries, IIRC.
Quoting Morvious (Reply 7):
According to the show, all 3 were down.
[Edited 2005-12-05 17:45:25]
breiz
Tue Dec 06, 2005 1:45 am
The DHL's A300 lost all 3 hydraulic systems, due to the heavy damages sustained by the right wing. Fortunately the front spare was untouched and kept the wing attached to the plane.
A319XFW
Here is a presntation by Jacques Rosay, the Airbus chief test pilot, on the matter:
http://wingfiles.com/files/liaison/26baghdad.pdf
jeb94
Tue Dec 06, 2005 4:17 am
Does the A300 actually have 3 systems or just two? I thought most twin jets only had 2 systems as there are only two engine driven pumps (one per engine).
jeffry747
Tue Dec 06, 2005 4:56 am
I can't help but think the assailants thought they were shooting at a passenger plane. If they were hoping to kill 100+ passengers with that missile, then they must have looked like a bunch of idiots if and when they found out that the target was a cargo plane with less than a handful of souls on board.
C'mon Big B, FLY!
breiz
Tue Dec 06, 2005 5:03 am
Quoting Jeb94 (Reply 11):
This a quote from the description of the events by the DHL's crew:
"Vers 8000 pieds un choc ébranle l’avion, associé en quelques secondes à une succession d’alarmes sonores. Mario annonce la perte des circuits hydrauliques vert et jaune, et vingt secondes plus tard le circuit bleu perd à son tour sa pression."
Which translates into:"Around 8000 feet the plane is shakened by a shock, together with, a few seconds later, a succession of alarms ringing. Mario informs us about the loss of the green and yellow hydraulic circuits, and twenty seconds later, the blue one losses also its pressure"
bennett123
Sat Dec 10, 2005 6:20 am
Is the plane still at Baghdad.
I thought that it was being scrapped.
hmmmm...
Sat Dec 10, 2005 7:39 am
What is interesting to note is that the heat seeker missed the engine. Had it struck there, it would have destroyed the plane. A second missile was fired and it missed completely. They were firing from too far away. They just didn't know how to use their equipment. You can see in the footage, those disgusting cockroaches dancing up and down with glee when they think they just killed hundreds of people.
[Edited 2005-12-09 23:40:14]
An optimist robs himself of the joy of being pleasantly surprised
DarthRandall
Sat Dec 10, 2005 8:00 am
Thanks for the PDF, 319. Those pilots have much kung fu!
Quoting Jeffry747 (Reply 12):
Not to mention that one of them managed to miss it entirely. Nice shootin', Tex! You can't even hit an A300 on takeoff. I can just picture one of his buddies on the ground slapping the turbin off his head as the missile careens off course. "You dumbass! Those missiles cost more than a years pay for our whole unit!"
Ninjas can kill anyone they want! Ninjas cut off heads all the time and don't even think twice about it.
clickhappy
Sat Dec 10, 2005 8:22 am
Photo © Gary Chambers
Photo © Pete Hawk
Photo © Speedbird999
bigphilnyc
Sat Dec 10, 2005 2:39 pm
To answer the original post, I don't think anyone denies that this happened. I remember it being on the news when it occured.
It's just a shame that the pilots never got more recognition than they did. Of course, had it not ended as well, it would be all over the news.
Phil Derner Jr.
Blasphemystic
Sat Dec 10, 2005 3:27 pm
The true measure of a man is how he treats someone who can do him absolutely no good. -- Samuel Johnson
