KarlB737
ORD To Upgrade Equipment To Reduce Delays
Fri Dec 09, 2005 8:02 am
Courtesy: The Associated Press
ORD To Upgrade Equipment To Reduce Delays During Bad Weather
http://www.airportbusiness.com/artic.../article.jsp?siteSection=1&id=4535
FriendlySkies
RE: ORD To Upgrade Equipment To Reduce Delays
Fri Dec 09, 2005 8:14 am
Did I read that right...they want to add TWO MORE ATC towers? Interesting....I know the expansion called for one new one, but are these two in addition to that?
airportplan
Fri Dec 09, 2005 11:40 am
Quoting FriendlySkies (Reply 1):
The new outer north and south runways require new north and south supplementary towers. Construction on the north town begins in 2006. The new south tower is many years down the road in Phase Two of the O'Hare Modernization Program.
FriendlySkies
Fri Dec 09, 2005 11:42 am
So I'm assuming the current tower will remain the "main" tower, while these north and south towers will control mainly arrivals on the outer runways?
echster
Fri Dec 09, 2005 11:48 am
ORD North Tower will work the north runways, ORD South Tower will work the south runways, and the current tower will serve as a back-up down the road.
