IAH744
Contrail Question
Sat Dec 10, 2005 8:14 am
1. how powerful does a jet engine have to be to produce a contrail?
2. would a learjet 60 produce one?
3. about how high do they start forming?
Deliver Everyones Luggage To Atlanta
grimey
RE: Contrail Question
Sat Dec 10, 2005 8:27 am
Quoting IAH744 (Thread starter):
See my answer to number 3.
Maybe it could, depending on the conditions (see below)
Depends on tempreture, humidity and air pressure at the time, I think usually around 20,000 feet.
Correct me if I'm wrong on anything.
Grimey
c680
Sat Dec 10, 2005 8:29 am
1) It has nothing to do with a jet engine. Look at all of the pictures of WWII radial prop bombers leaving contrails for an example. It is the rapid cooling of water vapor that produces the condensation trail or "Contrail."
2) Yes, a Lear 60 could produce one, given the correct atmospheric conditions. I've seen a King Air make them.
3) They can form at ground level on up - again, it all depends on the atmospheric conditions. It is a factor of temperature and humidity, not altitude. But, to give you the answer your looking for - mid 20's and higher.
My happy place is FL470 - what's yours?
IAH744
Sat Dec 10, 2005 8:40 am
4. at supersonic speeds would aircrafts contrails be scattered?
like not in a straigh line
mjzair
Sat Dec 10, 2005 8:45 am
Interesting but useless trivia...
The level at which contrails will start to occur is called the Mintra Level.
SlamClick
Sat Dec 10, 2005 9:43 am
Quoting C680 (Reply 2):
I read a long time ago that a Twin Otter operator way up in northern Canada would have that problem. Because it was so cold (Resolute Bay?) the first takeoff in the morning would lay an ice crystal contrail down the runway. After that everyone was making zero-zero intrument takeoffs.
We have two major kinds today, the "chemtrail" that goes from one horizon to the other and eventually begins to spread out into a cirrostratus layer. The other is maybe only half a mile long - forms and dissipates in a few seconds. A friend of mine calls these "comets."
When I was a kid I never recall seeing the second kind, only the ones that went from horizon to horizon. I think I know why. The planes that were laying down "vapor trails" back then were B-29, Boeing 307, Connies and the like. Their radial engine exhaust was really oily and smoky. So lots more particulate matter = lots more contrail. That is just my best guess.
In answer to #2 yes, just as readily as an Airbus. I see corporate jets pulling cons all the time up there.
DLKAPA
Sat Dec 10, 2005 9:48 am
I've heard stories from my friends up at UND that on cold mornings when the piper warriors take off they leave contrails. Oh yeah and the contrails are actually chemicals created by the CIA to reduce brain function, make our physiology more susceptible to drugs, and keep Lindsay Lohan from gaining weight  duck
IAH744
Sat Dec 10, 2005 12:35 pm
Quoting DLKAPA (Reply 6):
you never said that, you will deny any knowledge that that statement ever existed
[takes out metal stick thingy, clicks button, makes big flash, you forget everything you know, he says did you have a good time at the carnival, and you say elephants are bigger in person]
jetmatt777
Crew
Sat Dec 10, 2005 12:44 pm
Yes, I agree 100% with that.  biggrin
During my brothers football game I saw a CRJ-200 on base for OKC 's RWY 17L and it was at about 3,000 - 5,000 feet AGL(Above Ground Level). I didn't know they could form that low but now I do.
-Matt  wave
Lighten up while you still can, don't even try to understand, just find a place to make your stand and take it easy
