DLKAPA
Is This A Noaa Flight?
Thu Dec 15, 2005 4:15 am
http://flightaware.com/live/flight/N677F
Has got to be one of the oddest flight paths I've ever seen, it's routing is BJC-BJC but it's covered at least a thousand miles today over the plains. Did alot of circling over Kansas and now looks to be heading toward the storm fronts over Texas. I ran the reg and it appears to be registered to the National Science Foundation, then I remembered that NOAA is based up in Boulder and BJC is basically Boulder's main airport. Is it a NOAA run?
JRadier
RE: Is This A Noaa Flight?
Thu Dec 15, 2005 4:39 am
on the website you gave it says:
"NATIONAL SCIENCE FOUNDATION"
faa.gov gives the same, with registration type 'government'. So I would say yes.
http://registry.faa.gov/aircraftinqu...t=677F&cmndfind.x=11&cmndfind.y=17
DLKAPA
Fri Dec 16, 2005 5:21 am
Any ideas on what they could be doing (besides just atmospheric research, that's a given  Wink )?
JRadier
Fri Dec 16, 2005 7:10 am
burning taxpayers money on jetfuel?
jgold47
Fri Dec 16, 2005 7:23 am
www.weatherwars.info
Check that out  Smile
FoxBravo
Fri Dec 16, 2005 7:30 am
Quoting Jgold47 (Reply 4):
Oh no, another "chemtrail" site...  crazy
Common sense is not so common. -Voltaire
Tornado82
Fri Dec 16, 2005 7:41 am
You're close. It's actually UCAR's. University Center for Atmospheric Research, based there in Boulder.
NOAA uses a G-IV, and their plane would show up registered to the US Dept. of Commerce.
http://www.aoc.noaa.gov/aircraft_g4.htm Typically seen near hurricanes flying high missions (hence the choice of a Gulfstream) while the Hurricane Hunter's go in at 10,000 feet.
UCAR is heavily funded by the federal gov't, but also many many universities and so forth. Here's more information, with a picture of the bird in question. Quite the snazzy paint job IMHO, and as a meteorologist and aviation geek it's my ultimate dream to be in that bird someday.
http://www.ucar.edu/org/posters/pdfs/HIAPERsm.pdf
[Edited 2005-12-15 23:44:01]
jgold47
Wed Dec 21, 2005 11:19 pm
Quoting FoxBravo (Reply 5):
There are others?
Tornado82
Tue Dec 27, 2005 5:24 am
Quoting Jgold47 (Reply 7):
There are others?
There are too many, and they are all BS.
The NSF/UCAR jet was just taking atmospheric measurements. a GV is chosen for it's high altitudes and long ranges.
