cessnalady
FL 44 On A MEX-GDL Flight. Why?
Fri Dec 16, 2005 10:11 am
Flight AM 108 on Dec/13, on a sparkling-new B73NG (XA-HAM): We took off from MEX (Elevation: 7144 Ft) on this beautiful, clear, no-clouds day... and climbed, climbed, climbed and climbed. 15 minutes into the flight the FP announced we had reached our cruising altitude of 44,000 Ft... And then, just 8 minutes later, (i.e., at 23 minutes after take off), we started descent into GDL (Elevation: 5,100Ft), where we landed exactly 21 minutes later. We were airborne for exactly 44 minutes.
Does it make sense to take the a/c to such altitude for 8 minutes just to drop down again? I'd really like to learn... why would you do that?
Opinions, fellow pilots?
Marie
XA744
RE: FL 44 On A MEX-GDL Flight. Why?
Fri Dec 16, 2005 10:29 am
Well, I am not a pilot, but could it have been a jet stream unusually traveling at between 25k to 35k ft ?
I was once on board a MAS 777 from EWR to DUB, and just when flying over Austria, the pilot requested ATC in VIE authorization to climb from 37,000 to 45,000 ft due to a jet stream that was on our path. I was in the cockpit and got this explanation from the FO.
No matter how you fly...just never get your wings clipped !
XA744
Fri Dec 16, 2005 10:31 am
Correction on the above please.
Trip was from EWR to DXB and then onto KUL, not to DUB
stuckinMAF
Fri Dec 16, 2005 10:39 am
Hmm, not sure why it was so high either, but I know this is a typical Southwest flight profile in Texas, too. Going from MAF to DAL, HOU, or ABQ, we'll climb like crazy, level off at FL3x0 for about 10 minutes (A little longer to HOU), then begin decending. I guess that margin of efficiency at the high cruise altitude and the long decent makes up for the time spent climbing!
"A fear of weapons is a sign of retarded sexual and emotional maturity" -Sigmund Freud
EGTESkyGod
Fri Dec 16, 2005 6:54 pm
Sorry to be pedantic, but FL44 is 4,400ft, so 44,000ft is FL440. Could be anything. Traffic? Jetstream?
I came, I saw, I Concorde! www.gofundme.com/lineupandwait
ghost77
Sat Dec 17, 2005 1:27 am
Quoting EGTESkyGod (Reply 4):
Sorry to be pedantic, but technically FL44 is not 4,400ft, that doesn't exist... ATC never mention you to decrease altitude to FL44.
Cessnalady - I'm sure this are efficiency test flights... you climb higher and faster with the B73G cruise faster and descent burning the less fuel... you gain more speed descending, save time and fuel!!!
ghost77 APM
Ricardo Morales - flyAPM - ¡No es que maneje rapido, solo estoy volando lento!
pr1268
Sat Dec 17, 2005 1:41 am
Just curious, I thought that the certified ceiling of the 737NG was FL410 and the 777 FL431 (43,100) feet (couldn't find those on Boeing's site, but I vividly remember reading those in a Jane's Aircraft book).
Granted, the planes are usually CAPABLE of flying higher than their certified ceiling, but doesn't that require some kind of bureaucratic process (variance from the airline's SOP or Pilot's Operational Handbook [POH])?
Also, don't these planes generally perform like crap at these rarified altitudes? I remember reading the TWA incident from April 1979 when the crew tried to extend the flaps 1 notch at FL390 (an unusually high altitude for the 727) to try to enhance the maneuvering performance.
Any others' thoughts?
The only time an aircraft has too much fuel is when it is on fire.
pr1268
Sat Dec 17, 2005 2:07 am
As for the really high short flights (reply 3), I've read that it is actually in the best interest of fuel economy to use the "bullet" profile (take off, climb unusually high, then descend) for short flights because the extra fuel used to climb higher is somehow offset by the savings of a longer, low-power descent.
Many South American airlines do it this way - LB, LA, PL, etc. especially on short-haul flights of 30 min - 2 hrs.
I did AUS-LAS on WN in May 2003 at FL390 - very nice flight indeed, plus my first flight in a 73G. Even when I did DAL-HOU on WN in 1999, we ascended all the way to FL330 for a 45 min. flight.
But, even WN can't get above FL250 even if they tried on a HOU-AUS flight these days (typically 25-28 minutes flying time).
Fly2HMO
Sat Dec 17, 2005 2:30 am
Quoting Pr1268 (Reply 7):
Correct. They'll usually wait until the last possible minute to descend, and it will be a steep descent so the plane basically glides down with engines almost at idle.
Geo772
Sat Dec 17, 2005 3:20 am
Everytime I've flown on a 73G it has involved a cruise above 40,000ft. The shortest flight was about an hour and ten minutes and the longest a little under 2 hours.
In days gone by it was quite common for flight crews to fly at a constant power setting and just steadily climb during the flight. The BAC1-11 benefitted from this and especially the VC10 which could break through the 40,000ft barrier.
Flown on A300B4/600,A319/20/21,A332/3,A343,B727,B732/3/4/5/6/7/8,B741/2/4,B752/3,B762/3,B772/3,DC10,L1011-200,VC10,MD80,
pr1268
Sat Dec 17, 2005 3:54 am
Replying to Geo772 (Reply 9): The Concorde did it this way, if I remember reading about this in some article. The Concorde would flatten its ascent (don't dare call it levelling off) at around FL520 or so and Mach 2.01, and climb at around 80-100 fpm x 90 minutes or so, then begin its descent from around FL600.
N1120A
Sat Dec 17, 2005 4:27 am
Quoting CessnaLady (Thread starter):
No you didn't. The 73G's max certified altitude is FL410, 41,000 feet.
Quoting Ghost77 (Reply 5):
There is no FL44, it is 4,400 feet or FL440 which is 44,000 feet.
juventus
Sat Dec 17, 2005 8:25 am
Sometimes pilots accept higher altitudes if ATC offers them a shor-cut.
adriaticus
Sun Dec 18, 2005 2:18 am
Quoting N1120A (Reply 11):
I don't think it was you, but her who was on board that aircraft. You are nobody to discredit her saying.
Quoting XA744 (Reply 1):
I concur with Ghost and XA744. Our own a/c ver often do this maneuvers for the same reasons.
__Ad.
A300/18/19/20/21 B721/2 B732/3/G/8 B741/2/4 B752 B762/3/4 B772/3 DC8/9/10 MD11 TU134/154 IL62/86 An24 SA340/2000 E45/90
luisde8cd
Sun Dec 18, 2005 2:29 am
I just flew MEX-MTY at FL380 in a Baby airbus. Isn't that too high for a 1 hour flight?
Saludos desde Caracas,
Luis
cessnalady
Mon Dec 19, 2005 7:56 am
Thanks for the different explanations; i.e., the "bullet profile", the jet streams, practice by other carriers...
44,000ft is FL440
I stand corrected. I could not edit the Topic line.
Quoting Adriaticus (Reply 13):
Thank you very much.  Wink
Marie
Luis777
Mon Dec 19, 2005 10:45 am
Impossible for a 737-700 to flight above FL410 on a regular flight, I don't want to discredit anyone, It's clear, the flight envelope for a 737 NG is 41,000 ft and all the 737 NG pilots know that and never would fly their plane above its limitations, maybe it could fly higher but only on test flights made by Boeing, It's possible that the flight attendant made a mistake when she had to announce the flight level. She understood FL440 instead FL410.
LG
N1120A
Mon Dec 19, 2005 10:47 am
This has nothing to do with discrediting anyone, just to say that she may be confused. The maximum certified altitude for any 737NG aircraft (737-600/700/800/900) is FL410. This is 2000 feet higher than the A32S and 4000 feet higher than the 737Classic. If you go above FL410, you are in violation of the law, your insurance policy and good sense.
gigneil
Mon Dec 19, 2005 12:07 pm
Well, except it doesn't matter who was on board the aircraft. The plane's service ceiling is 41,000 feet. It is illegal to operate it higher than that.
Hence, the plane wasn't there. Certainly not 44,000.
N
cessnalady
Tue Dec 20, 2005 3:32 am
Now the fun has started...
Quoting Luis777 (Reply 16):
Not impossible. We were there.
The FP, not the FA, made the announcement... Together with a series of remarks pointing out cities (like Toluca and Morelia), external temperature (-64°C), and landscape features. As I said before, it was a remarkably clear day.
Quoting N1120A (Reply 17):
Nice and sharp dictum!!... And which jurisdiction is this that you seem to know so well? (Just FYI, we were in Mexican airspace). banghead
Quoting Gigneil (Reply 18):
Hence, the plane wasn't there. blockhead
I should not even answer this stupid sophism (Reminded me KL 007 shouldn't have been where it was  Yeah sure )... But indeed my plane was there...
Or go tell the FP his altimeters were off for a few thousand feet!!
Marie
Airlinerfreak
Tue Dec 20, 2005 3:36 am
Well often times through Mexico you find turbulent weather. I have found in on such flights from PVR-MEX multiple times. We have often had to make deviations or fly above the storms so weather could always be a possibility.
N1120A
Tue Dec 20, 2005 5:51 am
Quoting CessnaLady (Reply 19):
It doesn't matter what airspace you were in. The 737NG is certified for a max altitude of 41,000 feet. That is what it is designed for, that is what Boeing recommended to all of the regulatory bodies and it is what the aviation authorities have certified it for. This is the same in Mexico as it is anywhere else
Or tell him he made a simple mistake
Edited to add this: http://www.boeing.com/commercial/bbj/flash/index_flash.html
That site gives you the max cruise altitude for the highest performance version of the 737, the BBJ. It is FL410, same as all other 737s.
[Edited 2005-12-19 21:59:25]
adriaticus
Tue Dec 20, 2005 6:08 am
N1120, Gigneil and CessnaLady have gone personal here. I think the point of the original question has been answered, made and well taken... Climb high to glide down with overall greater fuel efficiency, and/or avoidance of turbulencies / jet streams.
With reference to Boeing's manufacturer recommendation becoming the law everywhere... I wouldn't take that for granted. I am indeed an attorney for an airline, and I can attest there are many loopholes and omissions in that respect in many regulatory systems. Saying "it's the Law" just because Boeing "recommended" something, is, to put it mildly, far-fetched.
IMHO, that should be it.
__Ad.
N1120A
Tue Dec 20, 2005 6:13 am
Quoting Adriaticus (Reply 22):
That is not what I am saying. I was stating that, in addition to FL410 being the max certified altitude of the 737NG by any regulating body in the world, it was also Boeing's recommendation.
Max certified flight altitude is not one of them. It is not only in contravention of aviation regulations all over the world, it is also going to lose an airline their insurance policy on the aircraft. Further, given that AM leases many of their 73Gs, it will break their lease contract.
This is nothing personal, it is a correction of a mistake.
nosedive
Tue Dec 20, 2005 6:18 am
It also is a great opening for a lawsuit!
ghost77
Tue Dec 20, 2005 6:52 am
Well, it's then time and place to disclose names, hours, flights and dates, Luis777 is a first hand ground instructor and responsible for all those AM73G pilots and more....
ghost77 APM
gigneil
Tue Dec 20, 2005 7:26 am
I'd be pleased to. As Ghost suggested, it would be awfully nice to know the name of said pilot that would risk his career, your lives, and Aeromexico's insurability.
Absolutely not, and I find the assertion somewhat ridiculous.
Flying up to and above the service ceiling of an aircraft killed those two Pinnacle pilots, some people on the ground, and destroyed a several million dollar CRJ.
N
BBJII
Tue Dec 20, 2005 7:30 am
Not impossible.
The BBJ (which is a 700series) has a optimum Altitude of FL440.
We normally fly @ FL390 and not above, unless we van get a good tail wind to save fuel and time.
 wave
Remember: The Bird Hit You, You Didn't Hit The Bird.....
Luis777
Tue Dec 20, 2005 7:33 am
I need proves, did you read the altimeters and were inside the cockpit?, besides maximum certified altitude is determined during certification and is usually set by the pressurization load limits on the fuselage, so, if you fly above FL410 on your sparkling brand new 737 NG surely would blow up like a fat balloon and explode, or by minimum you could damage the structure severely. Maybe the pilot was joking telling they were flying FL440, anyway 99% of travelers don't have any idea of an airliner parameters.
LG
N1120A
Tue Dec 20, 2005 7:43 am
Quoting BBJII (Reply 27):
According to the FAA, all 737s, including the 737-700IGW on which the BBJ1 is based, have a maximum certified altitude of FL410. Other than the strengthened wing (738 wing), standard winglets, increased MTOW and fuel capacity, there are no differences in the airplane.
MTY2GVA
Tue Dec 20, 2005 11:46 pm
If it happened congratulations your alive you should make a T-shirt that says " I survived flying at FL440 on a 737-700"  smile
Tengo orgullo de ser del norte del mero San Luisito...
Tornado82
Wed Dec 21, 2005 12:01 am
Quoting Gigneil (Reply 26):
They didn't kill anybody on the ground in that crash, and since when did they get above FL410 either?
