widebodyphotog
747-8 Information Update
Tue Dec 20, 2005 4:25 am
I thought some here may find this information useful so here are some excerpts from the latest 747-8 Planning Manual augmented by my own cast-down data.
Original Boeing document here:
Boeing 747-8 Airport Compatibility Brochure
General Arrangements:
747-8
747-8F
Interior Arrangements:
747-8
747-8F
Payload Range Capability:
Payload Range Chart 747-8
http://theaviationspecialist.com/748f_prc.gifPayload Range Chart 747-8F[/url]
Airplane Characteristics:
747-8 Airplane Characteristics
747-8 Airplane Cast Down Data
747-8 And A380-800 Family Data
This stuff is free people. There are no warranties expressed or implied. Actual mileage may vary...Now talk amongst yourselves. But on a personal note those GEnX's on the 747-8 look pretty cool.
-widebodyphotog
[Edited 2005-12-19 20:34:06]
[Edited 2005-12-19 20:35:48]
If you know what's really going on then you'll know what to do
DIA
RE: 747-8 Information Update
Tue Dec 20, 2005 4:29 am
Quoting Widebodyphotog (Thread starter):
Agreed.
*good compilation of info - thanks.
Ding! You are now free to keep supporting Frontier.
TheSonntag
Tue Dec 20, 2005 4:42 am
Why does the 748 seem to have a higher cruise thrust, even though it is lighter?
Interesting figures, thank you for sharing.
SNATH
Tue Dec 20, 2005 4:43 am
Yeah, I second this.
BTW, the link for the range chart of the B747-8F looks wrong (I think you didn't bracket it properly). You might want to do a bit of editing in the HTML...
But thanks for posting! This is very interesting indeed!
Tony
Nikon: we don't want more pixels, we want better pixels.
SNATH
Tue Dec 20, 2005 4:52 am
BTW, something that I noticed in the data you provided is that the cruising altitude of the B747-8 is 35,000ft (as opposed to 39,000ft for the A380; the B737NGs reach 41,000 I think, right?). Is the lower cruising altitude for the B747-8 inherited from the current B747s? Any reason why it can't fly higher?
Tony
Boeing Nut
Tue Dec 20, 2005 4:59 am
Widebody,
As usual, excellent post.  bigthumbsup
B2707SST
Tue Dec 20, 2005 5:02 am
Quoting SNATH (Reply 4):
The A380-800 has an enormous wing for an aircraft of its weight and therefore much lighter loading than the 747, so it should have higher cruise altitudes at any given stage. I would be very surprised if the 747-8 isn't certified up to 41,000 feet, which (IIRC) is the current ceiling for the -400.
--B2707SST
Keynes is dead and we are living in his long run.
gorbidog
This plane rocks big time!
I think the stretch will do this design perfectly, as the plane will be longer, sleeker, and with the extended wingtips, will truly give the plane a cooler look, much more attractive than the ungainly A380.
Don't flame me anyone, but IMHO (as a former automotive designer), when comparing the 747 vs. the A380 from strictly a design analysis standpoint, it's like The Beauty and the Beast.
[Edited 2005-12-19 21:12:51]
Sticks and stones may break my bones, but please don't throw stuff 'cause our bamboo floor is delicate!
Glom
Tue Dec 20, 2005 5:04 am
wbp, is there a place where we can find all these cool tables and charts you produce?
Glom
Tue Dec 20, 2005 5:12 am
I note in the Boeing document, that the raked wingtip spills over the edge of the stand. Wouldn't this affect the compatibility advantage it has over the A380?
I don't think that was reflective of ceiling. I think it was reflective of the optimal cruise altitude (whatever). IIRC, the service ceiling of the 744 is 450.
zvezda
Tue Dec 20, 2005 5:20 am
Wow! Boeing are already claiming an 8270nm range with 450 passengers -- up from earlier claims of 8000nm. Given Boeing's history of extremely conservative performance predictions, it seems likely that actual range will be even greater. The range advantage over the WhaleJet may be enough to sway some sales to the JumboJet. Of course, CASM will be a more important factor than range for most airlines.
jacobin777
widebodyphotog..once again, thanks for the great info... thumbsup
"Up the Irons!"
Glom
Tue Dec 20, 2005 5:26 am
Quoting Zvezda (Reply 10):
On that note, can anyone figure out how to calculate the seat mile fuel burn for each of the two aircraft. First Boeing claimed to be able to beat the A380, then they published figures that looked unlikely to do that, and depended on reducing the Airbus estimate to maintain that position. What's the verdict now?
atmx2000
Tue Dec 20, 2005 6:37 am
Quoting Jacobin777 (Reply 11):
Agreed.  yes  I'm thinking of starting a widebodyphotog chart fan club.  praise
N1120A
Tue Dec 20, 2005 6:50 am
Quoting TheSonntag (Reply 2):
I don't see how the 748I can really be lighter than the 744, or especially the 744ER. It is larger and doesn't make much of a change in current building techniques. It needs higher thrust to achieve the same performance.
I think he based the information on a middling crusie altitude of FL350, not withstanding a higher cruise. Remember, as it is, to get maximum efficiency, the 744 flies lower (FL290-FL320 or something of the sort) at high speed to burn off fuel, then glides up to a higher altitude at a slower speed to end the flight. Hence you take an average of that. I am betting a fully loaded 748I would have trouble getting to FL350 until fuel was burned off. I sincerely doubt that Boeing would certify it that low.
Quoting B2707SST (Reply 6):
I believe the 744 is certified to FL430
Quoting Atmx2000 (Reply 13):
Agreed. I'm thinking of starting a widebodyphotog chart fan club.
Can I be the President?
BTW, I find it very interesting that the 748I will be so efficient that it will use 3000 gallons less fuel to fly 500-700nm farther than the 744ER while carrying more passengers and cargo.
PlaneDane
Tue Dec 20, 2005 6:57 am
Quoting N1120A (Reply 14):
That's really cool! Thanks for pointing this out for us, N1120A. Thanks also to WBP for the info...
widebodyphotog
Tue Dec 20, 2005 7:32 am
Corrected link:
Quoting Glom (Reply 12):
Boeing has claimed a 6% seat/mile cost advantage vs A380. That was before a few tweaks to the design, namely a higher MTOW for the 787-8 Intercontinental. Initially it seems that the 747-8 will build on that by another 1% or so. The increased range, payload and overhead space options really gives the passenger airplane some competitive advantages that will be hard to match by the A380 despite it's capacity advantage. For the freighter, dramatically lower tonne/mile costs are already proving very attractive for the general cargo operators who can't utilize the higher volume of A380-800F. All told, if you don't need absolute capacity in your network the 747-8 looks like a very competitive alternative to the Airbus offering.
I have had my own personal misgivings about 747-8, but it seems like the response is right along what Boeing has hoped for. They have been able to offer some very attractive enhancements to the aircraft using 787 technology and that has made all the difference in the world. It's too bad that this product could not have been developed five years ago...
-widebodyphotog
N1120A
Tue Dec 20, 2005 7:35 am
Quoting Widebodyphotog (Reply 16):
Not to mention the payload/weight advantages that give heavy lifters like Cargolux and perhaps soon Lufthansa Cargo a major advantage over the A388F
DAYflyer
Tue Dec 20, 2005 7:45 am
Now if they were only able to make the fuselage all composite we could have a 787 on steroids!
One Nation Under God
N1120A
Tue Dec 20, 2005 8:00 am
Question, why has Boeing designed the 748F with less range than the 744ERF?
Quoting DAYflyer (Reply 18):
Unfortunately, that would require more money than Boeing wants to spend and a likely full recertification and new type certificate, which Boeing wants to avoid.
atmx2000
Tue Dec 20, 2005 8:19 am
Well, I suppose we would have to have some by-laws and a nomination process followed by an election first.
I suppose since you are a legal eagle, you could draft the by-laws. And if you put in a clause in their that makes would make you President-for-life, I won't raise a fuss.  Wink
Of course, if that had been the case, the A388 might have a higher thrust version of the same engines on it.
jeffry747
Tue Dec 20, 2005 8:28 am
Widebodyphotog
Thank you for satisfying my voracious appetite for info on my favorite airplane
Delicious stuff man!
 Big grin
C'mon Big B, FLY!
Max Q
Tue Dec 20, 2005 9:03 am
The 747-400 is certified to 45000 feet, as was the classic.
prebennorholm
Tue Dec 20, 2005 9:24 am
Quoting N1120A (Reply 19):
The ERF was launched when crude oil was $15/barrel. At $60/bl it makes little sense to haul along a hundred thousand lbs of fuel long distance when you can take a hundred thousand lbs more cargo instead and make an extra fuel stop.
A fuel stop with a cargo plane is much simpler than with a pax plane simply because you don't have to wake up hundreds of sleeping passengers.
Very little cargo has such a hurry that it cannot take a fuel stop on a 4,000+ nm sector when there is a significant price incentive. At least there isn't enough to warrent the design of such a plane. If you have got such cargo, then go and buy your own Gulfstream.
You see the same trend on the 380. The 380F has a much shorter range than the 380 pax plane.
lightsaber
Crew
Tue Dec 20, 2005 9:25 am
Sign me up. If there was a higher tier RU list, widebodyphotog would be on mine. Let's see President is already taken... I want to be in the founder's circle!
Good question. I believe the flaps are being redone, but that wouldn't cover the 11.7 foot stretch... There is quite a drop in fuel required due to the engine/wingtip improvements where much of the range comes from.
Gotta love it.
Lightsaber
trex8
Tue Dec 20, 2005 10:15 am
can you put the galleys above the main cabin and free up space for more seats rather than using it for those skylofts???
zvezda
Tue Dec 20, 2005 10:48 am
Quoting Trex8 (Reply 25):
I know there has been consideration of putting galley cart storage upstairs. I'll bet most of the Economy lavs also could be put upstairs.
F27XXX
Tue Dec 20, 2005 11:06 am
Will the wings really swish upwards that way while inflight? Not sure how i feel about that quite yet .. it looks kinda effeminate to me ..
I'M BAAAAAAAACK!
sunrisevalley
Tue Dec 20, 2005 11:33 am
Operators like SQ will be less likely to "misuse" the A380 with this alternative being available
Here here !
I am not sure about on a seat mile basis, but by my figuring based on max.useable fuel/max.payload the A380 passenger uses 2.9897lbs. fuel to cover a distance of 6550nm. The 747-8 uses 2.585lbs to cover 6740nm which converts into 2.513lb for 6550nm.
On a seat nm basis l figure the 747-8 as consuming the max. standard useable fuel of 403146 lbs divided by 450 seats divided by 8270nm range. This gives a figure of about .1119 lb/nm/seat. On the same basis the A380 number is .12359lb/nm/seat.
If this methodology is incorrect I am sure someone will correct me.
put me down as a charter member.
Perhaps Widebodyphotog would be kind enough to do a typical mission chart for west bound LAX-MEL for each aircraft .
sunrisevalley
Tue Dec 20, 2005 11:38 am
Quoting SunriseValley (Reply 28):
OOPS , these fuel useage figures should show "per nm."
atmx2000
Tue Dec 20, 2005 11:52 am
Quoting Lightsaber (Reply 24):
Well, that's 4 prospective members. Maybe we need an official place to meet, like a dedicated thread, to engage in adulation. We could link and embed all of widebodyphotog's charts and figures. I hate wrestling with the A.net archive search engine to try and find a particular graphic that was linked to in an old thread. However, that may a lot of larger images to embed in a single thread, considering how prolific widebodyphotog has been.
[Edited 2005-12-20 03:55:19]
sunrisevalley
Tue Dec 20, 2005 12:06 pm
Quoting Atmx2000 (Reply 30):
I have been bookmarking many of them and trying to print them out but my old HP printer is limited to a meg and those color ones take much more than that.
atmx2000
Tue Dec 20, 2005 12:11 pm
Quoting SunriseValley (Reply 31):
I would try that except I use different computers and accounts at home and at work and don't want to spend time sync-ing them. Unfortunately, widebodyphotog's website doesn't have a index, as that would solve the problem.
kaitak744
Tue Dec 20, 2005 12:17 pm
Well, looking at the drawings, it seems the flaps will no longer be tripple slotted. It will be 777 style. (1 sloted outside flaps and 2 sloted inside flaps)
Yet I am greating disapointed with the seating and aircraft width. The 747-8 has less pitch AND less seat width than the A380. This is horrible. Last time I flew on a 747, I was so cramped due to the seat width. As a passenger, I would prefer the A380 any day.
DfwRevolution
Tue Dec 20, 2005 12:48 pm
Quoting Kaitak744 (Reply 33):
Yes, flaps will be redesigned to help meet QC.2 requirements. This was part of the 747-400XQLR offering.
Pitch is a function of what the opperator installs regardless of aircraft type.
The 747-8 is quite a bit heavier than the 747-400 series.
ikramerica
Tue Dec 20, 2005 12:50 pm
Yes, galley can go upstairs, not just cart storage, as well as crew rests and crew only lavs. It would be like having an entire length and width of a 738 (roughly) for cooking, sleeping and crapping.
If these numbers are correct, the 748 beats the A388 in all ways: fuel per pax, max range, max payload range, fuel per pax+cargo, max cargo with max pax, etc. The only thing the A380 wins at is that the 748 will cost almost as much to buy and about the same to maintain, which will be spread over a smaller customer base (450 vs 555, though Airbus shortchanges premium to get there). Depending on loads and fuel costs though, the 748 looks to range from about the same to operate to much cheaper to operate.
It's amazing what some new engines can do.
For the millionth time, SEAT PITCH IS NOT PART OF THE AIRCRAFT DESIGN.
Seat pitch is at discretion of the airlines. Frankly, width is as well, though they do have to work in a restricted space. 17.2" is not the greatest. Airlines could choose 9 abreast at 18.5", but it would wreck the economics.
And just wait until EK puts 3-5-3 Y in the 380...  Wink
Molykote
Tue Dec 20, 2005 1:01 pm
And here we have the reason behind the 748 CASM advantage over the A388 - It doesn't need engines to climb!
Speedtape - The aspirin of aviation!
StuckInCA
Tue Dec 20, 2005 1:03 pm
Well, you must understand the pickle I'm in. He's the only one on my RU list. I haven't quite felt that anyone that deserves his company yet. If there were a 2nd tier, well then that'd be different  Smile
Aircellist
Tue Dec 20, 2005 1:06 pm
May I join as the fifth member?
"When I find out I was wrong, I change my mind. What do you do?" -attributed to John Maynard Keynes
N1120A
Tue Dec 20, 2005 2:05 pm
Quoting Prebennorholm (Reply 23):
It am well aware of how cargo economics work, but it makes absolutely no sense that the 748F, an aircraft that is more efficient and that is built to have a longer range would actually have a shorter range than the plane it is supposed to replace
I am well aware of how cargo flights work
The difference is not nearly as much. Now, a lot of the A380F's range comes at the penalty of heavy lift, but its range is actually longer than that of the 748F even though that is reversed in the passenger versions of the aircraft
Yes, they are being redone to be double and not triple slotted, but that doesn't really make all that much difference in weight. It is being done for noise
The RWD as opposed to winglets are not really making an incredible amount of difference. It is the use of the new engines, as well as more efficient use of fuel capacity, that is really doing it.
Quoting Molykote (Reply 36):
LOL. Funny, but that is not what I meant. At certain weights, it is inefficient or impossible for an aircraft to exceed a certain altitude until it has burned off some of the fuel. For example, a 648,000 pound MTOW United 772ER with PW4090 engines with a full passenger and cargo load is limited to say FL310 until it burns off enough fuel to move up. It will then be able to climb up to a new altitude with much less effort and efficiency.
sunrisevalley
Tue Dec 20, 2005 7:23 pm
I thought step cruise was a standard operating proceedure for all types.
zvezda
Tue Dec 20, 2005 7:32 pm
Quoting Ikramerica (Reply 35):
Length and width, yes, but not the height. The ceiling will be about a foot lower than in the B737.
art
Tue Dec 20, 2005 9:00 pm
Quoting F27XXX (Reply 27):
The "Queen of the Skies" looking effeminate... Doesn't seem too wrong to me!
TinkerBelle
Tue Dec 20, 2005 11:44 pm
...and I wanna be the sixth member. What would we ever do without widebodyphotog's technical charts and links?
If you are going through hell, keep going.
ikramerica
Tue Dec 20, 2005 11:56 pm
Quoting N1120A (Reply 39):
The ERF has 400 gallons more fuel, and a 50,000lb lower MTOW. But I would assume that if you loaded the ERF with 400 less gallons and the same actualy cargo weight as the 8F, you'd get a similar range.
The 777F is designed as the LRF, not the 748F.
Quoting Zvezda (Reply 41):
Still high enough to stand and walk, according the Boeing stuff. Maybe best for Asian airlines. I'd probably be a little cramped at 6'3.
BlueSky1976
Wed Dec 21, 2005 12:03 am
Quoting Gorbidog (Reply 7):
They're both ungainly ugly. A380 does have a better looking wing when viewing directly from the front.
777 and 787 eat both of those for lunch in looks department. Young and lean owns both old fat lady and the young fat girl.
POLAND IS UNDER DICTATORSHIP OF JAROSŁAW KACZYŃSKI AND HIS PUPPET GOVERNMENT. DEMOCRACY SHALL PREVAIL.
zvezda
Wed Dec 21, 2005 12:12 am
Quoting Ikramerica (Reply 44):
No. Given equal fuel and equal payload, the B747-8F has much better range than the B747-400ERF -- mainly due to the efficiency of the GEnx engines, though aerodynamic tweaks help as well. The greater structural weight does not overcome the engine and aerodynamic improvements.
Have you tried standing at the back of the upstairs galley on a B747?
MKandiah
Wed Dec 21, 2005 1:39 am
While aesthetics may be a matter of personal tastes, the 747 deserves better than to be called an 'old fat lady'.
Quoting BlueSky1976 (Reply 45):
 box
miamix707
Wed Dec 21, 2005 2:02 am
I don't like those wings either for the 747-8, will take a while to get used to them if they'll have this much of a bend. Would like to hear from a Boeing designer what the advantages are of the bent wing.
It's still the best looking new jetliner in 20 years. On the other hand the 787 looks almost as boring as an A320 so the wing flex actually helps  Wink
na
Wed Dec 21, 2005 2:03 am
Whitebodyphot,
thanks for this collection of data on the world´s greatest airliner!
Ahemm...
You better don´t mess with the world´s favorite aircraft. Most people will disagree with you. For me the 747 in all versions is still miles ahead of the 777 and 787 in looks and far more distinctive. Just unique and impressive, where the twinjets are generic (and the 773 even is ungainly looking, out of proportion). The newer Boeing twins are certainly good-lookers just like the A330, but they are twinjets, the most boring basic concept out there.
