JasYHZ
Who Flies Between BOS And TPA
Thu Dec 22, 2005 3:22 am
Hi everyone,
I'm using miles to fly from YHZ-BOS and then looking for the cheapest RT fom BOS-TPA. I know CO, DL, UA, AA, US, B6 and AirTran (code?) do but is there anyone else I'm missing that I can check fro a cheap fare?
"That's it! You just made the list!"
atrude777
RE: Who Flies Between BOS And TPA
Thu Dec 22, 2005 3:30 am
While it isnt BOS, there is also , PVD and MHT are boston areas, and fly to TPA n/s on SWA. Check them if you are willing to go out there.
Alex
[Edited 2005-12-21 19:31:20]
Logan22L
Thu Dec 22, 2005 3:36 am
Two others are Independence Air and Midwest, but neither is direct. Independence Air will route you through IAD, while Midwest through Milwaukee or Kansas City, so Independence will be shorter and likely cheaper.
"The deeper you go, the higher you fly. The higher you fly, the deeper you go."
ExpressJet_ERJ
Thu Dec 22, 2005 3:39 am
Jetblue, Song, and Airtran all do Non stop BOS-TPA
ETOPS...Engines Turn Or People Swim
DeltaMIA
Thu Dec 22, 2005 3:40 am
Why not use your award to get you all the way to TPA?
It's a big building with patients, but that's not important right now.
crogalski
Thu Dec 22, 2005 4:29 am
jetblue! we use our E190 on the last BOS-TPA flight daily, flight #1249!
the other two flights are A320's, usually the flighs are pretty full.
A319 A320 A321 A330 B717 B727 B737 B747 B757 B767 CRJ200 CRJ700 CRJ900 DC9 E145 E190 MD88 Q400 | AA AB B6 CO DL EI FL NK
ejmmsu
Thu Dec 22, 2005 4:46 am
For many dates in Jan and Feb, NW is offering BOS-TPA connecting in DTW or MEM for $149 r/t total cost.
"If the facts do not conform to the theory, they will have to be disposed of"
JasYHZ
Thu Dec 22, 2005 5:36 am
I have enough miles for one long haul or two short haul. And leaving the sometimes-better-half behind while I go to the sunny south in January will go over like a lead balloon.......
surfdog75
Thu Dec 22, 2005 5:52 am
Try Song. It's by far the best way to travel, unless your in first class, and you'll get to check out the new Boston and Tampa terminals. Have a great trip.
chase
Thu Dec 22, 2005 6:04 am
Regarding the PVD/MHT option...I am pretty sure that the Boston subway/lightrail goes out to PVD airport now. And although I'm not sure, I would imagine it must go to BOS as well. They call it the "T" there, FYI.
iowaman
Thu Dec 22, 2005 6:05 am
Quoting Ejmmsu (Reply 6):
Just a warning, that is out of the way quite a bit.
I'd take B6, just because your pretty much guaranteed a newer plane with good seat pitch and Direct TV.
layzhon
Thu Dec 22, 2005 10:12 am
Airtran does not do fly nonstop from BOS to TPA. Your best bet is on Song. Three flights a day that tend to be pretty much always on time. 9am,3:30pm,8pm
"Rectum? Damn near killed 'em!"
deltairlines
Thu Dec 22, 2005 11:39 am
I'd take Song...earn DL miles, and the inflight service is great...I fly DL Domestic First quite regularly, and honestly, I'd rather take Song than DL domestic F on a flight of this length...service is great, and you can't go wrong with them.
Jeff
navairjax
Thu Dec 22, 2005 3:04 pm
Quoting Layzhon (Reply 11):
Interestingly FL flies BOS-SRQ n/s instead
B752OS
Sat Dec 24, 2005 5:07 pm
Quoting Chase (Reply 9):
My sister lives up in Boston and a couple of times I have flown up to see her I have had to use the subways. The blue line of the subway connects right to the airport as does the silver line which in turn connects to the rest of the system. There are also water shuttles that make stops at the airport.
BOS would be the best option for you as there are more than one carrier on the route and BOS offers more direct flights. Both Song and B6s product is much better than WNs, I never was a fan of waiting in line to get a seat. The prices out of BOS are the same if not cheaper in a lot of cases than PVD or MHT. Add in the fact that there are not flights between either PVD and MHT and YHZ and BOS would be the logical choice for the region as it is for any other travel need.
InTheSky74
Sat Dec 24, 2005 5:10 pm
Definitely take JetBlue. Depending on when you are going, the Song product may be gone... Because it will be phased out of the NE to Florida markets starting this spring and put on long-haul service east-west coast mostly.
Jetblue has a fantastic product, and I suggest it highly.
Rob
