airnz777pilot
CHC Extensions To Be Completed By 2009
Thu Jan 05, 2006 5:27 pm
Starting in 2006 CHC is going to make major extensions to the airport. Apparently they are going to combine the domestic and international terminal. Does anyone know new airlines that will start services between 2006 through to 2009
Plane fanatic
planemanofnz
RE: CHC Extensions To Be Completed By 2009
Thu Jan 05, 2006 5:35 pm
In the June 2005 edition of 'Australian Aviation', it said that apparantley Thai is going to start services to CHC in 2006 - now this year. The magazine said : "New services are planned to Moscow and Johannesburg later this year, Christchurch next year, Hiroshima and Shenzen in 2007, and Manchester and Berlin after that.
On another note I hope to see either Cathay Pacific or Air New Zealand operate a CHC-HKG route.
airnz777pilot
Thu Jan 05, 2006 5:43 pm
Ya thanks for the info really helpful, and i'd also like to see a direct flight between CHC-HKG
Plane fanatic
Kiwi dave
Thu Jan 05, 2006 5:57 pm
Any idea what aircraft type TG would send to CHC? my money is on the 772ER
planemanofnz
Thu Jan 05, 2006 6:03 pm
Quoting Kiwi Dave (Reply 3):
It could just be an add on from Australia or Auckland even though TG said that the reason it was exiting the trans-tasman market was because they believe that there is no place for a full service carrier to fly between Australia and New Zealand. If it were direct I would expect something with not too much capacity. Possibly an A340-500?, or a 346?
ZKNSJ
Thu Jan 05, 2006 6:08 pm
perhaps a a330 from perth?, there was talk of cathay coming via brisbane with the a330.
[Edited 2006-01-05 10:13:32]
Thu Jan 05, 2006 6:28 pm
How about re-continuation from SYD like how AKL was served only last year?
I'm thinking that the Moscow route could result after CX get a route to CHC, and the MAN through the HKG-Moscow-MAN flight.
Does Shenzhen Airways have long haul flights? It seems weird to think that AKL doesn't even have a flight to JNB, yet CHC are planning getting a route like that.
planemanofnz
Thu Jan 05, 2006 6:36 pm
Quoting NZ107 (Reply 6):
Johannesburg? Since when are CHC getting a route to JNB?
airnz777pilot
yea it seems a bit like CHC is catching up id not already cought up with AKL with new services and international terminal size. I wonder if air nz will base any 777s in CHC also
Plane fanatic
777ER
Crew
Thu Jan 05, 2006 6:39 pm
There was a topic on here months ago when it was first announced. Maybe this link will provide good answers for you http://www.airliners.net/discussions...general_aviation/read.main/2259560
Head Forum Moderator
moderators@airliners.net for all Moderator contact
NZ1
Crew
Quoting Airnz777pilot (Reply 8):
Thats a negative, for now. The only 777 flight planned out of CHC in NZ colours is the CHC-LAX flight later in the year,
NZ1
NZ1
airnz777pilot
Thu Jan 05, 2006 6:51 pm
that a shame. I'd like to see a few more air New Zealand planes in CHC
Plane fanatic
Kiwi dave
Fri Jan 06, 2006 6:17 am
Will flights to LAX from CHC increase with the 777s taking over?
Oz777
Fri Jan 06, 2006 6:40 am
Quoting Airnz777pilot (Thread starter):
Last time I flew out of CHC (a couple of weeks ago) the Dom terminal and the Int terminal were all in the same building. A simple 3 minute walk on the ground floor.
So just what is the work to be done. I think you will find the TERMINAL is going to be extended, not joined.
OZ777
airnz777pilot
Fri Jan 06, 2006 6:46 am
I'm not sure how but at the moment the domestic flight are at one end of the terminal and the international at the other end. And I think that there going to make it SO that both international and domestic flights are in the same area. This site might help www.airportcity.co.nz
Plane fanatic
planemanofnz
Fri Jan 06, 2006 8:44 am
Quoting Kiwi Dave (Reply 12):
From what I have heard here on a.net apparantley the flight will go daily.
Fri Jan 06, 2006 1:15 pm
Will we ever see any domestic 777 routes like the current flight from Japan to CHC via AKL?
planemanofnz
Fri Jan 06, 2006 1:30 pm
Quoting NZ107 (Reply 16):
Probably when the 777 takes over the 747/767 on the NRT-CHC-AKL route in April.
777ER
Crew
Fri Jan 06, 2006 2:24 pm
The original plans were daily B777s
