MidnightMike
Long-Range Jets Threaten Singapore Airport's Hub
Fri Jan 06, 2006 4:00 pm
Long-Range Jets Threaten Singapore Airport's Hub Status
Amazing how things work out, and with technology, there is always going to be unforseen problems, that will arise later.
http://sg.biz.yahoo.com/060105/15/3xo8j.html
"Airlines with the B777-200LR can fly nonstop London to Sydney in 18 hours and there's very little any airport, be it Changi or Bangkok, can do if an airline decides to bypass," Shukor said.
SIA is already making nonstop flights to the U.S. using Airbus' (ABI.YY) A340-500 aircraft. What worries Singapore's Changi, Asia's sixth busiest airport by arrivals, is the 777-200LR (long range) that rival aircraft maker Boeing Inc. (BA) is developing.
The long-range version of the 777 is fitted with raked wingtips, a wider wingspan and is powered by higher thrust engines, giving additional cruise altitude and range. It has been designed to compete with the A340-500, which has a flight range of 16,700 kilometers.
With a list price of US$209 million to US$232 million, the 777-200LR has an advantage over the slightly cheaper Airbus A340-500 as Boeing claims its plane burns at least 20% less fuel, even as airlines are getting squeezed by high oil prices.
NO URLS in signature
LTU932
RE: Long-Range Jets Threaten Singapore Airport's Hub
Fri Jan 06, 2006 5:49 pm
Quoting MidnightMike (Thread starter):
I don't see how this can negatively affect an airport such as SIN or BKK. I believe it has already been discussed that if the 777-200LR was introduced by say QF, they would only serve a high yielding passenger base with these flights, while regular flights with such stopovers would continue for the rest, who want to pay less or just want the convenience of a brief layover to stretch their legs.
The A345 and 772LR are niche aircraft. I don't think this small C-Market they represent would put those airports in "danger". Besides, we don't even know if QF (or maybe even BA) is going to order the 772LR or not, otherwise, we won't see ULH flights from LHR to SYD/MEL for a while.
MidnightMike
Fri Jan 06, 2006 9:26 pm
Quoting LTU932 (Reply 1):
Maybe they are getting concerned with the future, what we have a niche aircraft now, could be the norm in the future?
xiaotung
Fri Jan 06, 2006 9:46 pm
Personally I can't stand the long hour flight. I would prefer a stop somewhere in the middle.
zvezda
Fri Jan 06, 2006 9:54 pm
The B787 will open up a lot more city pairs (bypassing hubs) than will the B777-200LR. However, hub carriers also benefit as they can then profitably serve more cities using newer generation aircraft, so it cuts both ways.
roseflyer
Sat Jan 07, 2006 12:31 am
Eroding some of the high yielding passengers would definitely hurt SQ. SQ does well with all of the connections that it gets, but nonstop flights between Europe and Australia would hurt the bottom line because SQ would be flying comparatively more economy passengers where margins are less.
But that is not to say that SQ will lose a lot of its traffic. When the 744 came around the number of flights transiting through HNL shrunk. But it doesn't look like the ultra long haul jets will do the same since they are more expensive to operate since they have a fewer number of seats than the 747s and A380s. Transiting through hubs will still happen.
If you look at the New York to Singapore market, SQ has a nonstop EWR-SIN and a one stop JFK-FRA-SIN. If you price it out in economy, you are likely to find better fares on the more economical 744 flight through FRA.
If the 772LR can do Europe to Australia nonstop and take the elite passengers away from carriers like SQ, then SQ will suffer a bit. Profits will be down, but that probably doesn't mean that the carrier will be hurt too much.
PhilSquares
Sat Jan 07, 2006 1:39 am
Quoting RoseFlyer (Reply 5):
Not to nitpick, but the article is about Changi Airport, not Singapore Airlines.
Fly fast, live slow
sllevin
Sat Jan 07, 2006 4:41 am
I don't believe that's true, given that QF felt that the economics of a 200 passenger 772LR (which Boeing said could do the nonstop) was unsatisfactory. Admittedly, they aren't looking to get 325 passengers, I suspect, but even if you go with 240-250 as a required passenger load, that's going to have a fair number of Y seats.
Ultimately, QF and BA will offer nonstops. It's just a matter of time and aircraft. Not having to stop in SIN/KUL/DXB is going to be their big differentiator in the end. Otherwise, they might as well hand the route over to EK.
Steve
N79969
Sat Jan 07, 2006 4:52 am
Singapore's government has wisely leveraged their strategically excellent location to make the city into an important destination unto itself.
I think scheduled ULR flights will become a reality someday but I think the expense of them will keep one-stops around for a long time to come for the majority of passengers.
Who knows-- perhaps more and more businessmen will, after a few runs on the non-stop LHR-SYD run, ask their counterparts to meet them halfway--in Singapore. It could happen.
LTU932
Sat Jan 07, 2006 5:24 am
Quoting Sllevin (Reply 7):
The 772LR can make the route I believe with a only J and Y+ cabin and the just 200 PAX you mentioned, but not year round as it is (due to the strong headwinds on westbounds in the winter if I'm not mistaken). I recall Boeing did propose a 777-200ULR with an over 10,000 nm range but would in this case the economics still be unsatisfactory and what about possible weight restrictions on SYD-LHR during the winter?
N79969
Sat Jan 07, 2006 5:43 am
Quoting LTU932 (Reply 9):
Whose winter?
roseflyer
Sat Jan 07, 2006 7:06 am
Quoting PhilSquares (Reply 6):
Very true, I didn't really bring up the point that a 772LR operated by British Airways or Qantas would affect SIN because fewer 744s would stop through there. I think the bigger factor will be the affect on traffic drawn by SQ. QF and BA already have much of the traffic and will only keep if not take more traffic if there are nonstop flights. SIA is the reason why Singapore is an air hub, not the few transiting BA, SQ and EK flights.
Ken777
Sat Jan 07, 2006 7:55 am
While a non-stop between Australia and the UK would work for some people I don't think that most travelers will pay the extra money. SIN has been a very handy hub for QF, with flights from, say, PER feeding the SIN-LHR flight. I think that will continue for a long time.
lightsaber
Crew
Sat Jan 07, 2006 10:33 am
Good example. Slowly but surely the role of hubs deminishes. I'm not saying they'll disapear. Eventually, we'll have a number of "super hubs" around the world to service the "regional" markets. But the days of less viable hubs will drop. Since Changi has good O&D (anyone have the numbers?), it won't disapear. But this could be like HNL where the # of overflights impacts the economy.
I actually thought with the a330 HNL would be used as a hub more... but it seems I was wrong and that the 787/350 will be out soon enough allowing mega bypass of hubs.
from the article, I foung this interesting:
Currently, only one of the top 10 destinations from Changi - London - is long haul.
I guess LAX and NYC don't count as most of the traffic is with a stop? Or are they true niche markets?
More ULH aircraft will appear. It is only a matter of time. Personally, I think around 2012 (or earlier) we'll see a 788HGW that will rock the ULH world. Will Airbus counter? I hope so!  bigthumbsup  There is some speculation that the 787-10 will get a wing extension. If so, imagine if you will the 788 or 789 with that wing doing ULH.  Smile  Smile  Smile
Lightsaber
swissy
Sat Jan 07, 2006 10:39 am
I think so too that the high end traveler will shift to these ultra long flights and
surly will effect some airlines like SQ, CX......... but PhilSquares pointed out
some airports will feel the effects even more.
I always enjoyed stopping in BKK, HKG or SIN stretch my legs for a short time and take my connection to .......... Most people can handle 10 to 14 hrs.
in a AC, but 17 to 22 hrs. ????? Not me I still will stop somewhere in between.
LTU932
Sat Jan 07, 2006 11:01 am
Quoting N79969 (Reply 10):
Whose winter?
I meant European winter, or at least the time where headwinds are the strongest.
N79969
Sat Jan 07, 2006 11:18 am
Quoting LTU932 (Reply 15):
Thanks. How about the Australian winter?
sunrisevalley
Sat Jan 07, 2006 12:40 pm
You guys don't get it... instead of flying west bound you fly east bound and take advantage of the +- 40k tail wind.
Taking the tail wind into account there is very little in it east bound or west bound on the basis of still air.
atmx2000
Sat Jan 07, 2006 1:26 pm
Quoting Lightsaber (Reply 13):
Except when the super hub becomes too large and requires higher landing fees and slot restrictions.
jacobin777
Sat Jan 07, 2006 1:54 pm
Quoting Swissy (Reply 14):
the whole "shopping" thing gets a bit old after a while.....a few times here and there is nice...but after a while, I just prefer flying nonstop.....and 20-30 years ago, who would have thought even a 10-15 hour flight...now those are becoming standard......
"Up the Irons!"
zvezda
Sat Jan 07, 2006 4:10 pm
Unless you mean different raked wingtips, I doubt that the B787-10 will get a wing extension. I think it is more likely that Boeing would fit fuel tanks to the horizontal stabilizers (for a B787-8ER also). In the (I think unlikely) event that Boeing build a (A340-600 length) B787-11X, then a wing root extension would be almost mandatory -- as would a new undercarriage.
atmx2000
Sat Jan 07, 2006 4:55 pm
Quoting Jacobin777 (Reply 19):
And then it hit me. Airbus is obviously catering towards the womenfolk who like shopping. Boeing is screwed.  Smile
LTU932
Sat Jan 07, 2006 5:32 pm
Quoting N79969 (Reply 16):
That would be the European summer IIRC, and that's a time where headwinds aren't that strong if I'm not mistaken.
Quoting SunriseValley (Reply 17):
Yes, but can it make an eastbound SYD-LHR flight nonstop? I tried to find a possible eastbound route SYD-LHR with the Great Circle Mapper but I get the impression that eastbound SYD-LHR is just too far away, even for the proposed 777-200ULR or without ETOPS compliance. I don't see how tailwinds can help in that direction with such distance.
cloudyapple
Sat Jan 07, 2006 6:09 pm
Why can't it be -
Long Range Jets Open up new Oppoertunities for Singapore Airport
Imagine being able to fly direct to so many more places?
A310/A319/20/21/A332/3/A343/6/A388/B732/5/7/8/B742/S/4/B752/B763/B772/3/W/E145/J41/MD11/83/90
zvezda
Sat Jan 07, 2006 6:10 pm
The only flights I can see SQ losing out to as a result of longer range aircraft are North America to India. OZ/NZ to Europe are a hypothetical possibility in the future. On the other hand, SQ benefits from being able to offer nonstop service to North America. On balance, I think the advent of longer range aircraft is a net benefit for SQ and Changi.
cloudyapple
Sat Jan 07, 2006 6:13 pm
I think Dubai is a bigger threat than ULRs.
zvezda
Sat Jan 07, 2006 6:24 pm
Quoting Cloudyapple (Reply 25):
I agree that DXB is a bigger threat to SIN than ULRs are. However, URLs are a bigger threat to DXB than to SIN.
cloudyapple
Sun Jan 08, 2006 12:24 pm
Quoting Zvezda (Reply 26):
However(!), ULRs are a bigger opportunity than threat to Dubai. Imagine Emirates flying to 50 gateways in North America, and 25 in South America, non-stop. Imagine seeing an Emirates A357 (future derivative) in Hawaii daily~
zvezda
Sun Jan 08, 2006 2:11 pm
Quoting Cloudyapple (Reply 27):
I can just as easily imagine nonstop flights from BOI to HRE (bypassing DXB). Neither seems more or less plausible than the other.
sunrisevalley
Sun Jan 08, 2006 11:07 pm
Quoting LTU932 (Reply 22):
If you input into Great Circle Mapper : SYD- 89.5N 110W-LHR you will get a distance of about 9754nm. The shortest great circle distance over Russia is 9188nm. Assuming a cruise speed of 485K with a tail wind of 40K the 9754nm translates into a still air distance of right around 9000nm.
There are no ETOPS limitations on Northern Pacific routes.
David_itl
Mon Jan 09, 2006 3:51 am
and in the case of the UK, there are tens of thousands of passengers who already bypassing hubs....specifically LHR! A recent survey by the CAA suggested that some 180,000 travellers flew on the MAN-Australia sector with only around 35,000 of them going on BA/QF via LHR. One wonders how may passengers EK is attracting on the BHX-DXB-Australia and GLA-DXB-Australia sectors. To the majority of the British population, any LHR-SYD non-stop would not mean bypassing any hubs for them as they'd have to get to a hub, so can we just drop the idea that the 772LR is a "hub by-passer"!
