NZCH
Air NZ Under Fire Again
Sun Jan 08, 2006 3:47 am
Air New Zealand is under fire again - this time from a passenger caught up on a New Year's Eve flight which narrowly avoided disaster.
Flying from New Plymouth to Auckland when 30 minutes into the flight, there were two loud bangs and one of the engines stopped.
The plane landed safely that evening in Auckland - with emergency services on the scene in case they were needed.
the passenger said the crew did not appear to be any less frightened than the passengers.
And now she says she has been angered by the customer service after the incident - someone from the company called her saying it was only turbulence which affected their flight.
She says it is disgusting she was dismissed in such a way.
Air New Zealand has confirmed an investigation is underway into what happened to the engine.
http://www.xtramsn.co.nz/news
If I was on that flight and the engine did cut out then I would be worried but not that worried because we would have been flying over land and could have easily diverted to Hamilton Airport which looks like closest to the route which it takes. plus there was still the other engine to go on and the flight is only a 45 minute flight which if the engine did cut out about 30 minutes into flight then there should have only been 15 minutes or so left of the flight. and I'm presuming the aircraft was a Saab 340 aircraft. Any replys would be appreciated.
Airlines flown: BA,BD,NZ,SQ,FR,ZB,EK,JQ
ZKSUJ
RE: Air NZ Under Fire Again
Sun Jan 08, 2006 7:32 am
15 minutes out. Would they have already started their descent? Hence diverting may not be a necesary alternative? (I.E. TOD for Hamilton would be well before the plane reaches TOD for AKL)
In saying that...
We do not know what went on in the flight deck in that occasion, best to wait and see what the report says before we speculate too much. As we all know, pilots are well trained for these situations and the main thing is the plane landed safely.
*I presume it landed safely as I didnt hear anything about it until now!
SUJ
NZCH
Sun Jan 08, 2006 8:30 am
Quoting ZKSUJ (Reply 1):
They would have most proberlay started there decent into AKL by then, but still if it was a major emergency then the captain/s would have consided diverting to Hamilton wouldn't they or would they. I don't know.
And yes the aircraft landed safely in AKL.
Thanks for the reply
Regards NZCH
TG992
Sun Jan 08, 2006 8:47 am
Quoting NZCH (Thread starter):
What an absolutely disgraceful and inaccurate comment from the gutter industry that calls itself the press in this country. The Air France flight in Canada is a flight that REALLY "narrowly avoided disaster". An engine failure is NOT!  banghead
NZCH
Sun Jan 08, 2006 8:51 am
You know what the press is like they always exaggerate things to get people worried.
Regards NZCH
777ER
Crew
Sun Jan 08, 2006 9:00 am
Quoting TG992 (Reply 3):
I totally agree with TG992. Its surprising what the medial will do to get peoples attention (well not really surprising).
I would be interested to know what the media describes as a near disaster
Not to flame the thread starter but these engine incidents happen every day around the world and they don't warrent any media coverage, unless of course there was an injury on board or the worst happened, the aircraft crashed.
Well sorry to tell this women, but these things can happen from turbulance
Head Forum Moderator
moderators@airliners.net
Flown: 1900D,S340,Q300,AT72-5/6,DC3,CR2/7,E145,E70/90,A319/20/21,A380,F100,B717,B733/4/8/9,B742/4,B752/3,B763,B772/W,B789
With: NZ,SJ,QF,JQ,EK,VA,AA,UA,DL,FL,AC
NZCH
Sun Jan 08, 2006 9:07 am
I have been on many flights with servier turbulence but just get on with it, I know the pilots are doing there best to fly the plane, and once I was unaccompanied Minor on a flight from Glagow Scotland to Manchester England with BA on a 737 400 I think, and our number 2 engine cut out during bad turbulence but the crew managed to get back working it was only out for several minutes.
ikramerica
Sun Jan 08, 2006 9:21 am
Exactly, if turbulence is so severe that it disrupts airflow, the engine can stall. Sounds like nothing major happened (ultimately), and some woman who doesn't understand anything about airplanes is all bent out of shape because she was scared. I would have been scared too, but I wouldn't go to the newspapers about it.
NZCH
Sun Jan 08, 2006 9:25 am
Some people are scared of because of terroists or an aircraft problem but just put out of there minds or keep it to themselves, I'm always scared flying as unaccompanied minor but I just get on with it.
777ER
Crew
Sun Jan 08, 2006 9:31 am
Quoting NZCH (Reply 8):
Well thats what the FAs are for, there to look after the UMs and make sure there are not worried
NZCH
Sun Jan 08, 2006 9:35 am
Quoting 777ER (Reply 9):
Well that's what the FAs are for, there to look after the UMs and make sure there are not worried
Yes that is true they are there to reassure that everything is OK.
Except on Ryanair with there 737 200's an absolute rust can ( flown with Ryanair as an UM many a times)
NZ1
Crew
Sun Jan 08, 2006 11:50 am
Wrong, they are there to stop the hundreds of male sicko's from sitting near them.  Smile Remember.
NZ1
NZ1
antskip
Sun Jan 08, 2006 12:19 pm
The precise link to the news item quoted is http://www.xtramsn.co.nz/news/0,,11964-5230129,00.html
NZCH
Sun Jan 08, 2006 1:14 pm
Sorry I didn't put he correct link in, I forgot that you have to put in all of those numbers.
Regards NZCH
roseflyer
Sun Jan 08, 2006 2:57 pm
First off that is an interesting picture for the news agency to pick for a topic about an Air New Zealand incident.
I was in AKL that evening, but saw nothing. Overall an emergency landing because of an engine failure is not the end of the world, but it would scare a lot of people. Pilots are trained so well that instincts will kick in and checklists will be followed, but I can understand some tension in the cabin. It is possible that the flight attendant wasn't the calmest. There is only one flight attendant on the Saab 340 as would be the case on almost all New Plymouth-Auckland flights. Hopefully it won't be too much of an issue and that Air New Zealand will be able to find out the cause.
One thing that irks me is when companies lie or hold back information. An airline trying to belittle a concern like this woman's would make me mad. If I saw an engine fail (and on a prop, it is pretty easy to tell), I would want a reason. If I was given a simple explanation like turbulence, then I would feel as if I was lied to and be even more angry. This seems to be the case here, presuming that the reporting is true.
Oh well, I feel sorry for Air New Zealand. There seems to be some bad press floating around ever since the announcement of job cutbacks.
777ER
Crew
Sun Jan 08, 2006 4:58 pm
Quoting NZ1 (Reply 11):
Wrong, they are there to stop the hundreds of male sicko's from sitting near them.  SmileRemember.
Please don't get me started on what I think of that discrimination rule mate.
ikramerica
Sun Jan 08, 2006 5:46 pm
but severe turbulence can stop a turboprop. it's rare, but it happens. if that is what happened, is it NZ's fault that the passenger isn't happy with the truth?
jafa39
Sun Jan 08, 2006 6:18 pm
I've done that flight, the route it takes makes AKL the best option for quite a large part of the flight as it cuts straight across the sea, you can see Mt Taranaki the whole way on a clear day.
Still, not many people wouldn't be scared, it always seems worse in a little a/c.
We, the undersigned, do hereby consent.....
Mr AirNZ
Sun Jan 08, 2006 6:22 pm
Quoting 777ER (Reply 15):
Im a male and NZ staff and im more than happy with the rule. I hate kids and if it means I don't have a talkative 6 year old beside me then GREAT  Wink
In reality I wont discuss my feelings on this rule in an open forum (weather I agree with it or not).
777ER
Crew
Sun Jan 08, 2006 6:49 pm
Quoting Mr AirNZ (Reply 18):
Well if you don't like kids beside you then it obviously will suit you fine. I wonder what would happen to the male passenger at the arrival airport if they refuse to move, because they are offended by the request
