1337Delta764
Winglets On 737/757-200 Replacement
Sun Jan 08, 2006 11:56 am
I do not intend on creating this thread as a poll, but just to discuss it.
Should the 737/757-200 replacement feature winglets (or raked wingtips) as standard? The 787-3 has blended winglets, and the 787-8 and 787-9 have raked wingtips. Since Boeing has been using these recently to improve performance of these aircraft, I think Boeing should perhaps consider using it on the 737/757-200 replacement.
What type of winglets:
Conventional winglets would probably not be the best option as it would extend the wingspan too much, and the 737 replacement is likely to have a new larger wing.
Raked wingtips may be better, but for an aircraft this size, would probably not be as good as blended winglets.
I personally think blended winglets would be the best option for this new aircraft family.
The Pink Delta 767-400ER - The most beautiful aircraft in the sky
Oykie
RE: Winglets On 737/757-200 Replacement
Sun Jan 08, 2006 8:47 pm
Quoting 1337Delta764 (Thread starter):
I think you are quite right. The blended winglets makes more sense. I am curious to see how the long the wingspan on the 737-E and A320NG will be. If the span is to long it will not fit into the existing 737 gates on allot of airports.
Dream no small dream; it lacks magic. Dream large, then go make that dream real - Donald Douglas
zvezda
Sun Jan 08, 2006 9:50 pm
Y1 will not have enough range for raked wingtips to offer optimal performance. In shorter range aircraft, cruise performance is less important than weight.
Shenzhen
Sun Jan 08, 2006 11:08 pm
One would think that if they can build a suitable wing that can fit in the current gates, then it would have a raked wing tip, if it couldn't fit in the gate, then it would have a blended wingtip. Raked is more efficient then blended, but blended goes up instead of out.
1337Delta764
Mon Jan 09, 2006 3:22 am
A question that I mentioned is whether they should be included as standard or optional. On the 737NG, they are optional, but I think they should be standard on the replacement.
Oykie
Mon Jan 09, 2006 6:16 am
I believe they should be standard. Maybe there will be an option regarding if the airlines will opt for a raked wingtip or blended winglets. The 737-E will probably match the range of the A319LR which is 4300 Nautical Miles.
