anandt
How Can An Old Plane (738) Better A New One (A320)
Thu Jan 12, 2006 1:26 am
How is this "technically" possible. The 738 being old wine in new bottle outperforming a much modern A320???  Confused
From a boeing press release - "Known for its reliability, fuel efficiency and economical performance, the 737-800 has been selected by leading carriers throughout the world. The 737-800 with Blended Winglets is 1,500 pounds lighter, can fly 260 nautical miles farther, fly 1,100 feet higher and climb to 35,000 feet 3.2 minutes faster while carrying 12 more passengers than the competing A320. "
http://www.boeing.com/news/releases/2006/q1/060111a_nr.html
jmy007
RE: How Can An Old Plane (738) Better A New One (A320)
Thu Jan 12, 2006 1:28 am
Oh man, not another A vs B thread.
They're both newly built planes, and the Airbus 320 desgined is push 20 years old already.
Cookies are the Gateway pastry. They lead to Éclairs and Bear Claws.
mauriceb
Thu Jan 12, 2006 1:29 am
the first A320 flew in 1988 while the 737-800 made its first flight in what? 1997/1998????
whó's old now ?
anyway, both A320 and 737-800 had some modifications through the years, and are both great planes
[Edited 2006-01-11 17:30:43]
krisyyz
Thu Jan 12, 2006 1:31 am
The B737-800 series is way newer than the A320 family.
First A320 in service- 05/1989
First B738 in service- 08/1998
Krisyyz
anandt
Thu Jan 12, 2006 1:32 am
Quoting KrisYYZ (Reply 3):
I meant the 737 series is much older than the A320 series.
kappel
Thu Jan 12, 2006 1:36 am
Quoting Anandt (Thread starter):
This is just PR man, the a320 has been outselling the 738 last couple of years, so the point is moot.
L1011,733,734,73G,738,743,744,752,763,772,77W,DC855,DC863,DC930,DC950,MD11,MD88,306,319,320,321,343,346,ARJ85,CR7,E195
jonathan-l
Thu Jan 12, 2006 1:40 am
Quoting Anandt (Reply 4):
The 737NG are hardly similar with the Classic 737: wing, engines, weight savings, flight controls...
It is like the first 747 being as common 747-8.
mauriceb
Thu Jan 12, 2006 1:41 am
Quoting Kappel (Reply 5):
well not totally true. because the 737-700 and 800 both compete with the A320, and the 700's also competes with A319, 737-600 with A318 and 737-900/757 do/did with A321
i
Joost
Thu Jan 12, 2006 1:50 am
Well, the basic design of the 737-800 is older, but the modifications make it newer than the A320. The 737-engines are newer for example, a very important factor with respect to fuel burn and performance. The cabin is slightly smaller, making it lighter. The wings are brand new, also very important.
It just shows that a "warmed over" design can be as good as a newer design. In my opinion, this is a good sign for the A350.
Also, the blended winglets are an even newer modification - that only became interesting after fuel prices went up so much that you save more on fuel than it costs to build the winglets. Rumours say Jetblue will be testing this kind of winglets on their A320s too soon. Does this mean Airbus was wrong? No, 20 years ago the balance with fuel costs on one side and construction costs on the other side just was different.
kappel
Thu Jan 12, 2006 2:09 am
Quoting MauriceB (Reply 7):
No it isn't. Just look at the dimensions. The -700 was a direct competitor to the a319. It's about the same size in lenght (a319 is 33.84m long and the -700 33.63m) so that makes it smaller than the a320 at 37.57m.
Scorpio
Thu Jan 12, 2006 2:15 am
Make that 03/1988.
N766UA
Thu Jan 12, 2006 2:46 am
Last I checked, wine gets better as it ages...  silly
Seriously, though, the 737NG is a new airplane. You aren't saying the A350 can't compete since its fusulage is still basically the A300.
This Website Censors Me
Joost
Thu Jan 12, 2006 2:54 am
N766UA, I can't agree more  Smile
More interesting thing in 737/320 is, IMO, that the 737NG has not been equiped with FBW, and still competes very will, even beating the A320 in certain ways.
swissy
Thu Jan 12, 2006 3:11 am
[quote=Joost,reply=12]More interesting thing in 737/320 is, IMO, that the 737NG has not been equiped with FBW, and still competes very will, even beating the A320 in certain ways.
I spoke with mx personel witch work on these 737's and they explain the reason for no FBW on the 737NG's is the re certification of the 737 and that
it would mean the pilots would need a new rating on these birds, as they
mentioned it the 737 basic ac is over 30 years old so changes made over the years are little, compare to a brand new concept.
Maybe someone here has a deeper inside in regard of "Why no FBW on 737's"
pavlin
Thu Jan 12, 2006 3:23 am
A320 doesn't not outsell A320. That was discussed a million times
phollingsworth
Thu Jan 12, 2006 3:24 am
Quoting Swissy (Reply 13):
When Boeing created the 737NG they did a very detailed cost/benefit and NPV analysis to determine what changes to make. Remember one of the driving customers was WN who had/has some very specific ideas of what they want. It was determined that minimizing certification cost was important. That and keeping the same basic systems approach, e.g. no FBW was a good option. However, the new wing was required to truely compete with the A320 family. The 738 is larger then the 734 so that it could act as a true 727 replacement.
As for FBW requiring a new type rating for the flight crews, there is nothing requiring that. Boeing could have demonstrated that the same knowledge was required, that the plane still handled sufficiently like an old 737, etc, and the FAA would have included the new a/c in the same type rating.
One interesting note, if the 738 had come under a new type certificate the max passenger capacity would equal that of the A320 and not be greater.
seanp11
New engines, a new wing, and new avionics can do tons. It is fairly irrelevant that the fuselage is 40 years old, as the A320 is still made out of aluminum, so there are only small aerodynamic advantages to the newer A32x fuselage.
I would not say the argument for the 737NG really works for the A350, however, as the 787 has a drastically different fuselage, which may offer many advantages over AlLi, as well as there are different requirements for short haul, opposed to long haul.
11Bravo
Thu Jan 12, 2006 3:39 am
Quoting Joost (Reply 8):
That all depends on what the nature and degree of the difference is between the two types to begin with. The A320 was superior to the B737 Classics primarily because of aerodynamic efficiency (wing) and better engines.
The principle advantage of the B787, however, is the weight savings that results from composite construction. The preliminary numbers suggest that the A350 will be much heavier than the B787, and that disadvantage is impossible to remedy unless Airbus builds a composite fuselage.
WhaleJets Rule!
N1120A
Check again.
The 73G and A319 are direct competitors, the A320 and 738 are direct competitors (with the 738 being bigger).
Quoting Joost (Reply 12):
Read below.
The thing you said about the type certificate was correct. Another major reason for not using FBW is the fact that one of the main reasons for using FBW over direct hydrolic controls is weight savings, which the 737 doesn't need given that it already is noticably lighter than the A320. Another reason is the dispatch reliability gains that FBW is supposed to add, but since the 737 already has a better DR than the A320 family, that also wasn't a concern
Quoting Phollingsworth (Reply 16):
Not especially. The 738 is physically longer than the A320, which allows more seat rows. Actually, the 738 could potentially fit more than 189 if it had the 739ER's exit configuration.
A319XFW
Thu Jan 12, 2006 3:46 am
As people have said, if FBW would have been incorporated, the NG would have needed to be certified as new and not under the "Grandfather rules" which it was.
A reason the 737-900 wasn't selling too well was that the authorities wouldn't allow for the greater passenger numbers with the same exits as the -800, as I guess it wouldn't have managed the 90 second evacuation time. That's why the 900ER has got the new doors.
What I wonder is will the 747-8 be allowed to be certified under grandfather rules or not. But I think that isn't allowed anymore. But this is for another discussion!
JAM747
Thu Jan 12, 2006 4:04 am
Quoting N766UA (Reply 11):
Very good point. Boeing have kept the name of their types even when they do significant updates to them, for example the 737 and 747. This can give the impression to some people that the new versions are 'old' because it still has the original type name even though there are new series names such as --800(B737) or -400 and -800 (B747). Airbus have changed the name of a type when they have done sigificant changes or updates such as the A310 and A330 which originated from versions of A300 concepts. The A300B10 became the A310 and the A300B9 became the A330.
Glom
Thu Jan 12, 2006 4:12 am
Oh dear! One of those extragalactic farts that were mentioned before.
Quoting Seanp11 (Reply 17):
The key question is, could the 737NG have been as effective against the A320 if it hadn't had the benefits of ten years of advancement? The A350 is being developed at the same time as the 787.
N1120A
Thu Jan 12, 2006 4:16 am
Quoting A319XFW (Reply 20):
It is not a matter of grandfather rules. If the type is an evolution of a design.
KaiGywer
Crew
Thu Jan 12, 2006 4:19 am
Quoting Pavlin (Reply 15):
Yeah, my guess is that they both sell the exact same amount  Silly
A319XFW
Thu Jan 12, 2006 4:20 am
Quoting N1120A (Reply 23):
If the type is an evolution of a design, then it will be certified under the so-called "Grandfather rules" (à la 737NG) but I think now the FAA has has changed those rules.
See the 747-8 thread.
N1120A
Thu Jan 12, 2006 4:25 am
Quoting A319XFW (Reply 25):
The term grandfathering would relate to more significant changes than evolution. Remember, the 737NG can be made to read just like a 737Classic
A319XFW
Thu Jan 12, 2006 4:33 am
Quoting N1120A (Reply 26):
Yes the 737NG can be made to read as the 737 Classic as it was certified under the grandfather rules.
But I was wondering how much this applies to the 747-8. the same would go to the A350.
From the FAA
FAR 21.19
Changes requiring a new type certificate.
Each person who proposes to change a product must apply for a new type certificate if the Administrator finds that the proposed change in design, power, thrust, or weight is so extensive that a substantially complete investigation of compliance with the applicable regulations is required.
[Edited 2006-01-11 20:36:25]
VEEREF
Thu Jan 12, 2006 7:12 am
If it ain't broke..............
Airplanes are cool. Aviation sucks.
Max Q
Thu Jan 12, 2006 8:37 am
The 73NG is a good ship, could have been a lot better if Boeing had not decided that Southwest would have such an influence on the design.
A quick look at the cockpit overhead will show the ancient technology carried forward from the -300.The 'round dials on glass' is a strange and less than optimal display option on the forward panel.
It is also the only modern aircraft I know in which the engine driven generators have to be manually placed on line after engine start. Even the DC-9 did that automatically!
Classic case of a customer being allowed to dumb down available advances in technology for the 'benefits' of a common type rating.
atmx2000
Thu Jan 12, 2006 8:48 am
Quoting Glom (Reply 21):
Boeing would likely have made more changes to the 737NG. On the otherhand if the A320 wasn't available 10 years before the 737NG, the A320 would have won less RFPs, including perhaps the UA RFP, whose loss spurred the NG's development.
prebennorholm
Thu Jan 12, 2006 9:00 am
Wrong. At least when we talk CFM engined planes.
CFM powered 320s got a new engine around 1995, the CFM56-5B replacing the CFM56-5A. A very substantial upgrade, in many ways an entirely new engine.
With the 737NG the CFM56-3 was replaced by the CFM56-7B. The -7B is for all practical things a reduced fan version of the -5B, fan diameter reduced to 61 inches instead of 68.3 inches in order to fit the lower landing gear on the 737.
The fact is that CFM made their latest, real technology leap 10 years ago from which the 737 benefitted with the arrival of the NG in 1998, 3 years later than the 320.
You can see drawings and specs tables of all those engines on http://www.cfm56.com
EMBQA
Thu Jan 12, 2006 9:18 am
Quoting VEEREF (Reply 27):
Ditto...!!
AR1300
Thu Jan 12, 2006 9:26 am
The 738/NG are completely new designs, based on roughly the same good ol' structure with proven excellent results, plus modifications to make it even better.
So technically, is a new plane.Just have a look at the wings, the NG wings are made with the same technollogy as the 777.
And like they said, the A320 is almost 20 years old....But it didn't suffer any major improvments, besides the wingfences and the central fuel tank, between the original -100 series and the -200 ones.
Mike
You are now free to move about the cabin
jush
Thu Jan 12, 2006 6:15 pm
Oh jesus yet another rubbish thread. They both perform well and any airline has to decide which one they want. But they're both great.
Regds
jush
There is one problem with airbus. Though their products are engineering marvels they lack passion, completely.
N754PR
Thu Jan 12, 2006 7:17 pm
The standards on A.net have fallen over the years but now its getting silly.
MODERATORS, Care to delete the MANY, MANY pointless topics??
Bush, your a sad, sad man.
kappel
Thu Jan 12, 2006 7:49 pm
Quoting Prebennorholm (Reply 30):
Doesn't the a320 CFM (5B) also have a higher bypass ratio due to the larger diameter, making them a bit more efficient than the 737 CFM (7B)?
pilot kaz
Thu Jan 12, 2006 8:15 pm
Quoting N754PR (Reply 34):
Have you suggested Deletion of the Many Many pointless Topics?
swissy
Thu Jan 12, 2006 10:17 pm
AR1300, I have to agree with you, I think we can compare the 320 family with
the 737 but we should look at sales numbers since 1989 as the 320's were
not available before that.
garpd
Thu Jan 12, 2006 10:28 pm
Quoting Swissy (Reply 37):
I don't think anyone is trying to suggest otherwise.
However, now that you mention it, it is interesting to note that the 737 is currently head to head with the A320 on sales, despite the age difference.
Speaks volumes for Boeings baby and volumes for Airbus' cash cow alike.
arpdesign.wordpress.com
swissy
Fri Jan 13, 2006 1:13 am
GARPD you are absolutely right, I would say the 737 and 320 are the cash cows for B & A and I hope they continue that way once they are bringing
on the replacement types and keep us nutty A. Neter's as happy as we can be.
