levent
A330 Vs A340 - Differences / Preference
Fri Jan 13, 2006 12:19 am
Hello all,
I flew on an Emirates Airbus A330 from DXB to IST, then IST to DXB and next Saturday again from DXB to BKK. I think it's a great airplane.
I was wondering - why would an airline prefer the A340 above the A330? What are the differences? (alright, alright, one has four and the other two engines... duh)
I suppose the A330 is cheaper to operate - re: THY's choice to get A330's instead of A340's?
Has the choice to do with ETOPS regulations?
All input appreciated.
kappel
RE: A330 Vs A340 - Differences / Preference
Fri Jan 13, 2006 12:25 am
Quoting Levent (Thread starter):
Well, it depends on wich a330 or a340 you are talking about. The a332 is similar in size as the a342, but smaller than the a343, which is the same size as the a333. However the a333 has about 10.000 km range and the a343 about 14.000 km. (or was it 13.000?)
And then there's the a345 with a much bigger range and a bit bigger than the a343, and the a346 with a range of 14.000 km which is also the biggest a340. (about 773 size). If you don't need the range of the a343 the a333 is cheaper to operate, which is why NW took the a333. It is also cheaper to operate than the 772A, according to NW because it is a much lighter aircraft.
L1011,733,734,73G,738,743,744,752,763,772,77W,DC855,DC863,DC930,DC950,MD11,MD88,306,319,320,321,343,346,ARJ85,CR7,E195
aircanada014
Fri Jan 13, 2006 12:48 am
However don't forget several airlines like AC and LH orderd both /ac
330-300 and 340-300. 330-300 is good for high density medium and long range a/c while 340-300 is good for long range a/c. For example, AC uses 340-300 to ASIA and Brazil and Europe while 330-300 uses for mainly Europe.
Glom
Fri Jan 13, 2006 2:48 am
The A340-300 is essentially the A330-300ER. It has all the hallmarks: same fuselage but strengthened. Same landing gear but enhanced (in this case with an extra bogey), extra tankage and uprated power plant (in this case by giving an extra pair).
Oykie
Fri Jan 13, 2006 4:49 am
Quoting Glom (Reply 3):
I wonder if Airbus at some times thinks about puting bigger engines ala GE90-115 on a A340-500/A340-600 design, but with only 2 engines and named it A330--500/A330-600?
Dream no small dream; it lacks magic. Dream large, then go make that dream real - Donald Douglas
Richard28
Fri Jan 13, 2006 5:12 am
Quoting OyKIE (Reply 4):
Erm, is this not essentially what the A350 will be?
YULWinterSkies
Fri Jan 13, 2006 5:24 am
The choice has also to do with range. Any 340 has a longer range than its 330 equivalent.
In which regards ETOPS, the only problematic route I have in mind is the Southern Pacific (SCL/EZE-AKL), operated by LA and AR on 343s and 342s respectively. I don't think a 333X would have the range anyway to operate SCL-AKL, and I'd say the same about a 332 and EZE-AKL. Both are longer I think than the current longest route operated by each type.
Yes indeed as pointed out by Richard28, the thing will be called an A350.
When I doubt... go running!
Oykie
Fri Jan 13, 2006 5:45 am
Quoting Richard28 (Reply 5):
Yoy and YULWinter Skies are both right. The A330-500 was proposed to airlines. 8 frames shorter than the A330-200 and 7000Nm range. At one time before offering this A330-500 Airbus offered an A330-100, 9 frames shorter than the A330-200. This was intended to be an A300 replacement. Both offerings did not end up in orders for the plane.
So I should not have used the name A330-500. But instead asked if Airbus before launching the A340-500/600 did think about offering a twin engine in this size instead of the 4 engine A340-500/600. They should at this time be very aware that the A330 was ceaper to operate.
ikramerica
Fri Jan 13, 2006 6:31 am
Again, the 350-800 was initially envisioned as a 330-800, basically what you describe, once they saw that A340 maybe wasn't going anywhere even with the 345/6 flying. Not a GE90, but a newer engine from the GENEx family, but nearly the same size (just less thrust and more efficient).
Airlines wanted more than this, so they made some more changes and called it the 350, but it's still not as capable payload-wise as the 345 is.
trex8
Fri Jan 13, 2006 10:06 am
if you us the SAS emissions calculator http://www.sasems.port.se/,
on a flight eg LHR-JFK, a A330 uses 39000kg fuel, a A343 45000kg
Rj111
Fri Jan 13, 2006 1:56 pm
The two craft are interesting. The idea was the A340 would sacrifice take off burn performance for better cruise perfromance, and the A330 visa versa. Hence the longer flights favoured the A343. I've studied the SAS data, on a 500km the A333 would burn more than 30% less than the A343 with max pax payload. However once we get to the end of the A333's range (near 9700kms) that's down to about 12%, and if one traces a ghost estimation of the A333 beyond it's range it down to about 10% at the A343's max range (12000km). You may say, what's the point in the A343 then if it would never burn less than the A333? If the A333 was modified to mimic the A343's range/payload performance, it would weigh more and resultingly have higher fuel burn. Whether it would have been higher than the A343's i couldn't tell you, but had the IAE superfan gone through as promised it most certainly would have. Unfortunately, it didn't and the A340 suffered, which is a shame, becasue the whole 2-engine 4-engine complement is a real smart idea.
Answering the orginal question with that data in mind. The A343 is only better at missions which require a better range/payload performance than what the A333 offers. Both have a maximum structural payload between 50.8-50.9, but the A333 only flies 3000nms or so with that, the A340 can get up to about 5500nm. But you don't necessarily need all that payload, so somewhere inbetween 4,000nms and 4,500nms is a realistic threshold.
[Edited 2006-01-13 05:57:36]
