WA727
HP 920 And 932, Convoy To Hawaii?
Sat Jan 14, 2006 7:56 am
I noticed on various flight trackers that both HP flights to HNL and OGG from PHX leave within minutes of each other and are in almost the same location about an hour into the flights. I know it's a big blue sky out there, but does anyone know if the planes follow each other until they get near the islands? Any pax or crew been on these flights?
WA727
socalfive
RE: HP 920 And 932, Convoy To Hawaii?
Sat Jan 14, 2006 9:04 am
They would obviously be routed TO Hawaii on a particular VOR radial, however at different altitudes, then be split off to their respective destinations.
Tornado82
Sat Jan 14, 2006 10:07 am
I thought they did that to draft off each other, you know, like NASCAR.  Wink
N1120A
Sat Jan 14, 2006 10:18 am
Quoting Tornado82 (Reply 2):
You don't want to draft off of a 757. Bad things happen
APFPilot1985
Sat Jan 14, 2006 10:21 am
Quoting N1120A (Reply 3):
no kidding, they spin off some NASTY vortices
Stand Up and Be Counted Visit Site Related to Voice your opinion
OPNLguy
Sat Jan 14, 2006 10:41 am
Slightly different routes...
920
MOBIE2 GBN J18 MZB C1156 MALIT FICKY R578 FITES OGG V24 LNY JULLE4
932
MOBIE2 GBN J18 MZB C1156 MALIT C1177 FICKY R578 FITES
av8rphx
Sat Jan 14, 2006 10:55 am
HAL35 PHX-HNL also leaves within 10 min of those departures.
727EMflyer
Sat Jan 14, 2006 11:45 am
If you dig a bit deeper you will see that there are are concentrations of flights leaving for hawaii by many airlines from places such as LAX, SFO, and NRT at similar times as well. We get strings of arrivals all at once here in HNL, and I believe it is the same story at KOA, OGG and LIH although not as heavy. If you fly on UA to/from the islands and are able to listen to Ch. 9 during cruise you will hear the same 7 or 8 flights chattering, then as you approach your destination you will hear them sequentially check in w/ center. Listen enough and you will recognize the flight by the pilots voice.
OPNLguy
Sat Jan 14, 2006 12:20 pm
Quoting Socalfive (Reply 1):
You don't mean the overwater portion, do you?
quickmover
Sat Jan 14, 2006 1:34 pm
I believe TED have MCO and TPA flights from DEN that leave within minutes of each other.
Bridogger6
Sat Jan 14, 2006 3:47 pm
Yeah these arent the only two flights HP has that leave at similar times, or in the case of Hawaii the same scheduled departure time. PHX to all three bay area cities are all scheduled within ten minutes of each other during all the flight banks.. JFK and EWR leave at about the same time.. MCO, TPA, FLL, and MIA all leave within a ten minute period.. and the list goes on. Then there are cities like SAN, LAS, and LAX where there are two flights scheduled to leave at the exact same time, multiple times throughout the day.. interesting schedules.
