airbusA346
Bare Metal Aircraft
Sat Jan 14, 2006 8:25 pm
I know that JAL Cargo have 747 Cargo aircraft in a bare metal livery.
But who else does it on there 747's.
How do they make an aircraft look like that. / Whats the process.
Are there any pictures of the process and are there any of CX's 747's in bare metal yet.
Tom.
Tom Walker '086' First Officer of a A318/A319 for Air Lambert - Hours Flown: 17 hour 05 minutes (last updated 24/12/05).
Daleaholic
RE: Bare Metal Aircraft
Sat Jan 14, 2006 8:59 pm
I'm not sure how they do it, but I know they did a bad job on this one...
Photo © Mark Kopczak
Religion is an illusion of childhood... Outgrown under proper education.
Go3Team
Sat Jan 14, 2006 10:15 pm
Quoting Daleaholic (Reply 1):
Someone went against the grain on that one. Horrible job.
Yay Pudding!
Mack8994
Sat Jan 14, 2006 10:39 pm
I agree! I think there is another thread on here discussing the why (i.e., pilot program for cost reductions). But IMO, it really does not look good at all.
 scratchchin
Courage is the power to let go of the familiar!
Gr8Circle
Sat Jan 14, 2006 11:01 pm
Quoting Go3Team (Reply 2):
I think the AC aircraft pictured above is done quite well....reasons why it doesn't look good in this pic are:
1. Sudden change of appearance - people take time to adjust to anything new..
2. The sky is cloudy, but with broken clouds....what seems to be a 'bad job', on closer inspection, is actually the reflection of the cloudy sky...take a closer look at the pic...
wedgetail737
Sat Jan 14, 2006 11:12 pm
It all has to do with the quality of the skin that the airline decides to buy for their airplanes. Some order the polished skins like AA and AM. Most others buy the unpolished skins. You will not get that imaculate (sp?) polished look when you try to polish an unpolished skin.
The maintenance cost is higher for polished skin because you have to keep in polished. At a certain point, the airline will have to replace the old skin with new skin.
474218
Sun Jan 15, 2006 6:33 am
The reason the bare aluminum AC 767 looks like it does is because it was previously painted. Paint does not adhere well on aluminum, and several steps are required for good paint adhesion. One step is to etch the surface. Etching can be done in several ways, both chemically or mechanically. Chemical treatments actually open up the pores of the aluminum allowing the paint to stick. The mechanical method can be as simple as rubbing the surface with an abrasive compound or scotch brite pads. When the paint is removed and the surface is polished the pure aluminum (alclad) surface appears dull, because of this prior treatment. Look at the pictures of the Eastern L-1011's and DC-9's they stripped and compare them to the 757's which came from the factory polished. The L-1011's and DC-9's just do not shine like the 757's.
EMBQA
Sun Jan 15, 2006 6:43 am
Quoting 474218 (Reply 6):
That is exactly the reason....!! Previously painted aircraft and skin panels are all but impossiable to get looking good again if you choose to go to polished. The process to paint an aircraft actually etches the surface of the of the skin panels and if it has been striped, sanded and re-painted you'll have that to deal with.
Quoting AirbusA346 (Thread starter):
I really can't think of anybody today that does... but way back when, American was bare metal on their 747's...
bohica
Sun Jan 15, 2006 6:48 am
A great example were the Western "Bud Light" paint jobs.
Photo © Jim Lawrence
Photo © Frank C. Duarte Jr.
eilennaei
Sun Jan 15, 2006 6:51 am
Photo © Jaakko Ypyä
nosedive
Sun Jan 15, 2006 1:52 pm
Quoting Gr8Circle (Reply 4):
Hmm.....
Photo © Youri Thonon - Contrails Aviation Photography
And the excuse here is...
N1120A
Sun Jan 15, 2006 3:30 pm
How about the ex-QQ MD-80s at AA. They don't look bad at all
ReidYYZ
Sun Jan 15, 2006 7:54 pm
take a closer look
I have.....It ain't pretty.
buckieboy
Sun Jan 15, 2006 8:45 pm
Quoting Wedgetail737 (Reply 5):
I studied Industrial Chemistry at University and I have to contest this statement. I know, you shouldn't believe everything you read on the internet, however the first sentence of the second paragraph explains why the aircraft's surface will never be 100% "shiny".
"A clean aluminium surface is reactive and will react spontaneously with water or air and form aluminium oxide."
http://www.alu-info.dk/Html/alulib/modul/A00100.htm
For anyone old enough to have aluminium kitchenware, try a simple experiment: make a small scratch and you will shiny, bare metal. Leave in a moist environment and the "wound" will heal. This due to the formation of the oxide layer, which gives excellent corrosion resistance as can be read in the attachment.
Buckieboy
I'm taking orders from bottles of wine
andz
Sun Jan 15, 2006 9:04 pm
this is beautiful...
Photo © Lukas Kirchner
airbusA346
Sun Jan 15, 2006 11:03 pm
Quoting Andz (Reply 14):
I agree with you there.
The JAL 744F's look better than the 742F's
Also
aren't CX surposed to be going bare, with the 744BCF's
Tom.
474218
Mon Jan 16, 2006 1:02 am
Quoting Buckieboy (Reply 13):
What you say is true and that is why the airlines with bare aluminum in their livery have to polish them periodically to remove the oxide. By the way, it is that oxide that prevents the paint from sticking to aluminum.
